How to record, will only record for one minute and 16 seconds
Have formatted the external hard drive and it will only record for one minute and 16 seconds no matter how you set up to record
  • Audio Player... Master
  • 1,267 Answers
How does an external hard drive have anything to do with a CD player?
Posted on Dec 11, 2012
Funlux surveillance hard drive issue. 1 tb, is full, need formatting , it takes 5 minutes plus to format. Every 2 minutes it reboot, trying to record, won't finish formatting. Disconnected cameras,
You did not post the model of the unit. There is a port for external drive support and there is an internal drive depending on the model. You can try formatting on a computer if you would like or you can select OVERWRITE recording when the HDD is full
1. Access the [General Settings] and open the [Disk Drive Info] page. 2. Open the drop-down menu at the top next to the "Hard Disk Drive Full", select "Overwrite" and press save.
Jan 07, 2017 | Hard Computers & Internet
How to recove Seagate external hard drive data?
Probably, the new operating system cannot recognize your Seagate external hard drive. You can connect the Seagate external hard drive to another computer to copy data to another device. If the problem still exists, you might need to perform data recovery. You can free download the data recovery software: http://www.icare-recovery.com/seagate-recovery/seagate-external-cannot-be-recognized.html
May 14, 2014 | Seagate FreeAgent Pro 500GB External USB...
How can I transfer recordings to a hard drive?
Any external USB hard drive that uses a 3.5" hard drive (the larger drives they use in desktops) will work. These all come with an external power adapter you must plug into the wall.
The external hard drive units that use the smaller 2.5" hard drives are the ones they use in laptops. These require much less power, and can be powered by the PC's USB port although some do come with an optional power adapter. However the Dish receiver does not send enough power to its USB port to power the hard drive, which is why the tech told you to get one that has an external power supply.
Even then the DVR uses a drive format that your computer may not recognize. I don't know if there are tools out there that will let you connect a hard drive from a DVR, read and convert the TV shows stored there.
Another option is to buy a DVD recorder. This is like a VCR, only it uses a DVD disc and not a video tape. Connect the DVD recorder to the outputs on the DVR, and then set the DVD recorder so it will record from its input. (on my DVD recorder this is "IN2")
Put a blank DVD into the DVD recorder, start playing a show on the DVR, and hit record on the DVD recorder. When the show is finished, hit stop on the DVD recorder to stop recording. The advantage here is you can then play this DVD on any DVD drive. The disadvantage is DVD recorders only record in non-HD. You can still play a show in HD, but the recording you get won't be in HD. Also, the show has to record in real time. So if it's a 60 minute episode, it will take 60 minutes to record.
You can also check this steps:
May 11, 2014 | Televison & Video
Formatting a external harddrive RC-6236
click start right click on my computer select open you should see your external hard drive
right click then select format
another way is to click start control panel administrive tools computer management disk management right click on your drive select format
hope this helps
Jun 15, 2012 | Computers & Internet
What hard drive is used in wj-hd316a
The hard disk is divided into three partitions: "Normal Recording,"
"Event Recording," and "Copy." Image data is automatically
recorded to the appropriate partition according to the recording
mode. For the normal recording partition, the data is overwritten
when the capacity is full. The event recording partition prohibits
overwriting to protect data. Copy partition prepares data for
retrieval to external medium.
Hard Disk Partitioning Function* automatically
selects the partition to be recorded.
RAID5 distributes image data to multiple hard disks in the
extension unit. Upon hard disk breakdown, lost data can be
restored from other hard disks. When using one WJ-HD300A
Series unit, mirroring function is available for data backup.
RAID5 / Mirroring Function
Playback VMD
One VMD area can set one
playback image for motion
search.
WJ-HD300A Series
Conventional
(* 10, 13, and 16 screens are available only with the WJ-HD316A.)
Even when images from multiple cameras are displayed on a multi-screen,
live monitoring can be achieved on all cameras at a full rate of 60 ips
(image per second). Experience real-time,
full surveillance with
full-rate video images.
Full Rate Live Multi-Screen
4-window 7-window 9-window 10-window* 13-window* 16-window*
Multi-screen in versatile variations
GUI Setup Menu
Time Table
Actual recording result (Example)
hope it helps
Feb 25, 2012 | Panasonic (WJ-HD316A/500) (WJHD316A500)...
I have a brookstone brand record player with the ability to convert records to mp3/wma files via a sd slot and a usb slot. Every time I plug in an empty flash drive/ usb toward an external hard drive, or...
External drives require to be formatted before use on somewhere else..
Pls "format" it on your Pc and than try again....
Sometimes proper formatting is possible on the equipment itself (like Digital Cameras )
I was not able to get into your units detailed specs to see if such feature is existed..
if its exist ,you must access thru "set up menu"
Secondly ,if the display recognizes the HD than your Record player will create its own Files/ folders..try to record something even it reads "no file" and than plug it into your PC to see what has been recorded..
Hope this helps!
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 24, 2011 | Audio Players & Recorders
Old DM Sprite 2, 16 Ch. C: - HItachi Deskstar 500GB Boots ok, no problem. Just installed a second drive, exactly same type as C, as a slave. Initializes ok, boot loader comes up for a second. Soon as...
format on the new hard drive has to be in FAT32 new hard drives are not formatted. psu should be fine as long as the fan is working and none of the capacitors have blown. the way you are doing. putting the cable on slave drive after is just making it a dead drive and is not being read at all from the system. when installed properly it will start up and a message should come on the screen 5 seconds after the cameras are seen on the screen to say new drive and merging files. then it puts 2 folders on the slave drive for recorded film files and advents .
Jun 08, 2011 | Dedicated Micros Digital Sprite 2 RS Video...
I dropped 500gb verbatim external drive. It wants me to format the drive. How can i get the data back before i format it? Please help Thank you
Because the first few records stored on the disk-drive have been corrupted (or are physically unreadable), you get the "please format" message. Hopefully, the other 99.9 percent of the data-blocks stored on the disk-drive are OK.
Search online for 'data recovery' software -- it reads through the disk-drive, block-by-block, trying to merge blocks of data back into files that can be copied onto your 'C:' drive.
Sep 17, 2010 | Verbatim External, USB 2.0, 750GB...
IBM deskstar 120 GXP 40GB will only format to 22GB. Its an old drive setup in an external usb enclosure
sounds like you're trying to format with FAT 16 or 32 which limits the partition size.
Try formatting with NFS which has no limit on partition sizes
Oct 25, 2009 | IBM Deskstar 120GXP 40 GB Hard Drive
Recording stops within 10 minutes
Hi G-DyBiec
If the video capture automatically stops capturing at approximately 18 minutes (17 minutes and 55 seconds), then most likely the drive that is being capture to, is formated using Microsoft's FAT32 file system. Microsoft's FAT32 file system has a maxium file size of 4 GigaBytes (4 GB), which equates to a DV video clip of nearly 18 minutes. (18 minutes = 1080 seconds, @ a data rate of 3.6 MB/sec is approximately 4GB). So for hard drives that are formatted using FAT32, this behavior is normal. This is not a limitation of Studio..
To see what file system your hard drive uses do the following:
1. Right click on the Start button and choose Explore
2. Under My Computer, locate and highlight the drive you are capturing to
3. Right click and select Properites
4. On the General tab, towards the top, it will say "File System". It will be listed as either FAT32 or NTFS.
There are a few solutions if your drives are formatted using FAT32:
  1. Convert your FAT32 hard drive to NTFS *
  2. If you can copy any important data from this drive to other drives, it may be faster to re-format the FAT32 drive using the NTFS file system. **
  3. You can do multiple 18 minute captures and string them together in the Edit mode of Studio.
    • Since the first 18 minutes is already captured, rewind the camcorder or VCR to 5 - 10 seconds before the initial capture stopped (which can be edited out later in Studio).
    • Start a new capture to a new file name.
    • Repeat this process until all the desired video is captured from the tape.
    • After all the files have been captured, go to Edit and assemble the captured files from the Album to the timeline in the order you desire.
This is a manual method to workaround Microsoft's FAT32 file system and if this is too time intensive for your needs, then steps 1 and 2 above may be more suitable and should be considered.
* Note: If you need assistance with step 1 above, go to the Microsoft web site at http://www.microsoft.com/ and search on "convert FAT32 to NTFS".
** Note: If you need assistance with step 2 above, go to the Microsoft web site at http://www.microsoft.com/ and search on "how to format a drive in XP".
NOTE: Microsoft's NTFS file system is only supported on Windows 2000, Windows XP and Windows Vista. NTFS support a file size of 4 TB (terra bytes), which is larger than any current consumer hard drive capacity, so if NTFS is used, the capture file size will only be limited by the size of the hard drive.
Aug 13, 2008 | Pinnacle Dazzle DVD Recorder
20 people viewed this question
 Grubhead
Grubhead
