Question about Dyna-Glo Double Tag-a-long Heater
Dyna glo regulator won't
The regulator on my dyna glo propane tank top double heater does not want to turn. it appears to be stuck in the off position.
  • Dyna-Glo Master
  • 2,463 Answers
Does it turn anticlock wise ?
Posted on Dec 09, 2012
  • 7 Answers
SOURCE: dyna-glo rmc tt30dgp wont turn on
Your regulator has failed, just like mine did. Contact GHP Group Inc, (877) 447-4768 to order a replacement regulator - MAKE SURE YOU HAVE THE PROPER HEATER MODEL NUMBER. Replacement Part Number: S2TT0001B for the RMC-TT30DGP.
Replacement cost including shipping is a couple bits over $21.
When talking to the technician on the phone, he cautioned me against rapidly opening the tank valve, which hammers the regulator (the replacement one is more robust than the original), kinda' like how water-hammer can cause damage to water pipes and/or water appliances. Open the tank valve gently, don't just whip it open (like I used to), your regulator will last a lot longer that way.
Because of the press-fit and pins used in the regulator construction & assembly, self-repair is not possible or recommended since the regulator may not seal correctly afterwards.
Posted on Jan 12, 2011
  • 108 Answers
SOURCE: Dyna-Glo natural gas space heater to propane gas.
Yes it is possible and a good idea. You need to have a regulator installed to reduce the pressure to the heater and this is a simple procedure. Contact your local Propane distributor and they will probably do this free to get your business.
Ray
Posted on Dec 09, 2008
steve_lima
  • 181 Answers
SOURCE: PHONE # FOR DYNA-GLO PRODUCTS
the number i have for them is 847-324-3753 let me know
Posted on Feb 17, 2009
steve_lima
  • 181 Answers
SOURCE: were can i get a 16oz to 20lb propane tank conversion kit for a
try this http://www.portableheaterparts.com/ they carry parts for these units
Posted on Mar 23, 2009
  • 148 Answers
SOURCE: pilotlight will not light, getting spark, but no propane.
make sure you have the gas valve knob on turned to pilot while pressing that down while pushing the spark it should light or it is tripped on a safety like rollout switch or oxygen depletion sensor if equipped which all ventless heaters are
Posted on May 12, 2009
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Where can I buy a regulator for 2 burner tank top heater
Our "old fashioned" local hardware store carries a line of several regulators. So, you might try all of your local hardware and/or building supply stores.
Jan 09, 2015 | Dyna Glo 18,000 - 30,000-BTU Liquid...
I have a dyna-glo double tank top propane heater. turned it off by on/off valve and now the switch won't turn on..just turns..no propane coming out and it doesn't work..Please Help?
Don't them heaters have a safety thermacouple? You gotta push in on the heater and light it and hold in the knob a minute for the heat to get the magnet to hold open the gas valve? Then advance it over to where t will burn in single r dual mode right?
Dec 17, 2010 | Heating & Cooling
Need a control knob for: dyna-glo pro propane heater. model: # rmc-tt30dgp-01, # rmc-tt30dg, # rmc-tt30gd. this is the off/low/med/hi temp. control knob.
I AM TRYING TO FIND A PROPANE REGULATOR FOR A DYNA-GLO PRO. THE MODEL # IS RMC-TT30DGP. THERE IS A NUMBER ON THE OLD REGULATOR. THAT # IS S2NTT0002-2.THANK YOU.
Dyna glo tag along propane heater pilot stays on but when turning
sounds like either a bad thermocouple or more likely a pressure regulator problem. should have unit checked by someone familiar with propane systems.
Jan 13, 2010 | Dyna-Glo (PPH16-LP) Utility Heater
Broken adjuster for propane heater
Broken adjuster for two burner attachment. Cant find a replacement.contact budmtzgr@sonic.net
Jan 30, 2009 | Dyna-Glo Double Tag-a-long Heater
Ray
Dec 08, 2008 | Dyna-Glo Heating & Cooling
Nov 20, 2008 | Dyna-Glo Double Tag-a-long Heater
Dyna-Glo Double Tag-a-long Heater Logo
524 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
drifterray
Level 1 Expert
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
