Question about GE Washing Machines
Older Model GE Energy Star Front Loader 8 cycle Heavy Duty Deluxe Quiet. Drum makes loud thumping on spin cycle what could it be?
I wanted to add that my Energy Star is most likely an older model. However we have never had a problem until this horrid thumping. Just wanted to add that info if it helps. Thanks!
  • 575 Answers
The drum is supported by springs. Maybe one of them broke. You might have to open it up to visually inspect it. You can find videos on YouTube on how to do it. Good luck!
Posted on May 19, 2016
5 Suggested Answers
SOURCE: agitator will not work on wash cycle
Order the upper aggitator clutch/dog kit $15. Now top half of the aggitator is doing its thing just like the bottom half. Hope this helps someone else too.
Posted on Oct 28, 2008
ftw1952
  • 10319 Answers
SOURCE: my washing machine started making a very loud
The drum has coiled springs to secure the drum in place while it spins. You will need to remove the top and the front panel to see if they are securely attached
Posted on Aug 25, 2010
dr appliance
  • 266 Answers
SOURCE: I have a GE front
check your owners manual for warranty on inner tub and seal warranty parts may be covered in some cases but labor may not be....
Posted on Jan 27, 2011
SOURCE: I have an older model
no esprime
Posted on Aug 18, 2011
How do you get to the belts on a ge 8 cycle heavy duty dryer. It's an older appliance.
Remove the top/cover and then remove the front assembly and you will have the drum and belt in front of you.
Jan 30, 2015 | GE Dryers
Kenmore 43142 front loader bangs during spin cycle any ideas on what the problem might be?
always check the load to the drum is not to heavy on one side, this could cause it to bang.
Aug 25, 2012 | Kenmore Washing Machines
Kitchenaid quiet care washing machine
not enough information. there may be a loose or broken drum spring, or the belt may be loose and or worn. If its a two speed one of the gears may be worn.
Dec 31, 2011 | KitchenAid Washing Machines
My GE GCVH6260FWW front load washer made a load snap while spinning. Repair man couldn't find anything. So we ran a load through and at the end of the wash cycle it started thumping and vibrating on high...
If the drum is also loose, it is dead. The plastic your are finding comes from a part inside. It will cost more (or close) to fix than to replace and you risk breaking other critical parts if you DYI.
Mar 01, 2011 | GE Energy Star WCVH6260F Front Load Washer
I have a GE front loader washer model # WHDVH626FWW inner drum making loud thumping noise while washing and spinning
Jan 27, 2011 | Washing Machines
Thumping/Screeching sound, MD:LDE8616ACE. Rollers? Idler Pulley?
Your description sounds like one or both of the rear drum supports (rollers) is bad. A quiet thumping is almost always present as the weld in the drum comes in contact with the drum supports. A binding support will squeal, and the thumping could be worse at that time. After running the dryer until the noises are present, once disassembled, you can tell if a support is bunding or rolling normally by spinning it by hand. The same goes for the idler pulley. Make sure power is disconnected from the unit befor attempting any repairs.
While the unit is disassembled for repair, make sure your your old cat is not inside.
Sep 11, 2009 | Maytag PYE2300AY Electric Dryer
Spin Cycle doesn't work on our GE Energy Star frontloader, please help
You may have to remove the lower panel and clean the drain pump filter. Easy job, once the panel is removed the filter will be right in front. Get a bucket and unscrew the filter cover (3 very small screws at the bottom of the front panel) and you should find a ton of lint and stuff in there. This model has a pressure switch that detects if there is water in the tub. If so it will do this pause and slow spin. Once the pump filter is clean you should be good again. It worked for me.
Apr 08, 2008 | GE Energy Star WCVH6260F Front Load Washer
Extremely Load spin cycle
Mine was doing this and my husband tightened the huge bolt on the back of the drum. This is where the belt attaches. Evidently this bolt when loose can cause that outrageous sound.
Mar 03, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
305 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
