Question about HP Compaq DC7900 Small Form Factor PC Desktop
After installing winxp3 on my hp dc7900 small form factor, im having problems with the vga and no sound
The vga or display on the monitor is not smooth and the the sound card i.e. the creative labs and the inbuilt hd sound cards are all disabled
  • HP Master
  • 7,627 Answers
Reinstall win xp drivers.http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=3784892&taskId=135
Posted on Dec 09, 2012
Benimur
  • 6966 Answers
SOURCE: hp compaq dc5000 small form factor
Hi, uninstalling the onboard video will only be reinstalled by Windows next time you boot up. Disabling it in the Device Manager might and mght not do the trick if your mb is set on using the onboard. You might want to try and disable the onboard video in the CMOS/BIOS set-up. In some instances, you are asked in the BIOS what video will be used such as onboard, AGP or PCI or a selection of something like that. Also you can try and not allocating any memory to the onboard video. Hope this be of some help. Pls post again how things turn up. Good luck.
Posted on Apr 28, 2007
lolita
  • 385 Answers
SOURCE: Installing a firewire pci Card onto my HP Compaq dc5000 Small Form Factor PC
Hi, Actually there are various types of customized firewire connections for your computer. Here is a link to view some products that might work with your computer. http://www.firewire-1394.com/firewire-usb-combo.htm Also, there are different sizes of PCI cards available. You have to shop around to find an apropriate size.
Posted on May 04, 2007
JonwVBFL
  • 56 Answers
SOURCE: new sound card for HP d530 small form factor..
You just have to look for a "low-profile" PCI card. Creative makes one, Audigy SE SB0570LPVP
Search that for a vendor, or low-profile for other manufacturers.
Posted on Jan 29, 2008
  • 31 Answers
SOURCE: soundcard
Hey there, the HP bios is pretty smart - it should automatically detect a new sound card and switch off the internal one when installed - alternatively you can go to the 'system devices' panel and disable it in the software as well.
hope this helps
cheers
Posted on Nov 19, 2008
  • 906 Answers
SOURCE: sound card download hp compaq dc 7600
compaq sound and audio drivers
hp sound and audio drivers
The links above are sites where you can download audio and sound drivers.
Download the file, install it and run the program. It will automatically give you a choices of drivers needed in your computer.
If you have any questions and concerns regarding the link given and the said problem, kindly update this post.
Thank you and have a great day.
Posted on Mar 28, 2010
My hp Compaq DC7900 has 5 beeps with 5 red light flashing does this 3 times. then the fan kicks on. That's all it does. Anyone know what this is?
This is a sign of a pre-video memory error. If your DC7900 has a video graphics card, that card has probably failed or doesn't have enough power. On at least some of HP's Compaq DC7900, the video card uses a PCIe x16 slot.
There are two things to consider when you choose a new video graphics card: 1) it must fit in a slot in your case and 2) your power supply must meet the requirements of the card. The small tower format of the HP Compaq DC7900 came with a 240W power supply. Most modern video graphics cards often need more power. You may need to upgrade the power supply.
I hope this helps.
Aug 13, 2014 | HP Compaq DC7900 Small Form Factor PC...
We have windows server 2003 system installed on HP dc7900 Small Form Factor. When we connect Segate Expansion Portable 1 TB drive with it, the drive is accessed in read only mode. Can any body help us in...
You may have to go into the properties of the drive itself to change it to read and write mode Go to My Computer tick on the drive select properties and select read and write. Allow files to be indexed as well. Unpick the read only selection.
Apr 10, 2012 | HP dc7900 Business Desktop Small Form...
Connect 2nd monitor to small form factor dc5800
Hello.
You have 2 options to connect an additional monitor to your desktop:
1. install a low profile video card that has multiple video outputs
2. purchase a USB to VGA/DVI device to allow a 2nd monitor to be connected.
Your model PC does not have a DisplayPort on it (newer PC's have this and this provides another monitor connection). So you will need to add hardware to the PC so you can connect the 2nd monitor.
Because you have the "Small Form Factor" model, standard height video cards will not fit in it. You would need to get the shorter model video card - typically labeled "low profile".
The other option is to purchase a USB to VGA or USB to DVI adapter that would allow you to connect the second monitor to your PC. The only thing to watch for when getting this type of adapter is to make sure your current Operating System is supported by the adapter. Many adapters that work on Windows XP will not work with Windows 7 or 8.
Mar 07, 2012 | HEWLETT-PACKARD Compaq DC5800 Small Form...
I'm having a problem with HP DC7900 SFF. The Video
The amount of allocated shared video memory is configured in the BIOS configuration - video memory.
Jun 20, 2011 | HP Compaq DC7900 Small Form Factor PC...
After formating my compaq d510 small form factor the resolution of my computer is bad,looking in the device manager i see that the vga controler is not installed where can i get this drivers?
You can download all of the drivers (not just the display drivers) for your system from the HP web site.
Your specific system's drivers are available on this page.
You will probably benefit from downloading and installing most of the drivers listed on the page linked above. There are a number of drivers that are specific to the D510 small form factor.
Dec 28, 2010 | Compaq System brd w tray for Evo D510 SFF...
I have dual monitors and the secondary one (DVI) is not one on occasion. I have to go into properties to reacquire the second display. What can be causing this? I ahve a HP DC7900 desktop with built in...
The first thing to try is either installing the latest video drivers or the re-installing the current drivers. Reboot and use the driver software settings to acquire the monitor and establish extended desktop (or whatever). You most likely have Intel integrated graphics (this page will link to your drivers, depending on your version of Windows:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3785039&lang=en&cc=us&prodTypeId=12454&prodSeriesId=3785404&taskId=135).
Jun 08, 2010 | HP Compaq DC7900 PC Desktop
HP Compaq DC7900 Small Form Factor  PC Desktop Logo
363 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
