Question about Samsung Televison & Video
Samsung LE32A4566C2D flat screen tv wont turn on?
I was wondering if anyone can help me, i have a samsung LE32A4566C2D flat screen tv, and recently there was a power surge in my area and ever since it wont work, it wont turn on, not even the power light comes on, i have had a quick research and a common problem with these tvs is the capacitors swell and fail, i have had a look and none of them seem to have gone, so i was thinking maybe it could be the internal fuse which is a T6.3H 250V so i have ordered one of them , i have also obviousley tried new fuse in the plug etc and a different power lead, any help would be great as to what else it could be
  • Samsung Master
  • 933 Answers
There is a chance the power supply is fried. However, I've seen some Samsung power supplies that have fusible resistors in the power supply for added protection. So your main fuse could be ok, but there could be an additional fusible resistor in the board as well. Also be aware, depending on where the surge entered the TV, you could also have a defective main board. Not trying to rain on your parade, but surge damage can sometimes be severe.
Posted on Dec 09, 2012
  • 4 more comments
  • Ryan Raz Hughes
    Ryan Raz Hughes Dec 09, 2012
    thanks, by power suppy do you mean the power lead? because i have tried another one with it, my ps3 one has the same socket type, that wouldnt work either, i have a very basic knowledge of electrics, but dont know what the resistors look like or how to tell wether they have blown, also i dont have a volt tester or the knowledge in using them, i will have another look today inside the thing, and have a good proper look, see if anything is burned charred etc
  • Ryan Raz Hughes
    Ryan Raz Hughes Dec 10, 2012
    i have checked and there is nothing burnt, i can get a new power board, will that sort it out?
  • Back2life Electronics Dec 10, 2012
    most likely your power supply id fried, I would prefer you do some basic troubleshooting. If you have access to a multimeter, set it for DC volts and clip the black lead to any metal frame on the casing. DO NOT USE A HEATSINK ON THE CIRCUIT BOARDS. On the power supply board, there will be several connectors. The connectors pins should be labeled. Look for a pin that is labeled 5vsb, or standby. With the TV plugged in, you should get a 5v reading on the meter. If you don't, its time to replace the power supply board.
  • Ryan Raz Hughes
    thanks for getting back to me, samsung have actually got back in touch and they are sending an engineer out to do a free inspection and if it is one of the common problems will fix it for free, if not and he says its gunna cost me , then al just try what u suggest and if its bust, buy a new power board,
    If you purchase a replacement power supply, make sure you order the exact part #
  • Ryan Raz Hughes
    will do, thanks pal
5 Suggested Answers
  • 98 Answers
SOURCE: My samsung TV won't show any picture/sound.
When the TV is on, need to check the back light is on(go back side & look into through)
If the back light is on -- need to exchange the Main Board
no back light -- exchange the Power Board --- 95%
exchange the LCD panel --- 5%(inverter)
Posted on Feb 06, 2009
  • 230 Answers
SOURCE: No longer turns on
It's well worth replacing the capacitors, but this problem can be caused by a short on the power supply (Which is what the caps do). Most shorts that arise in power supplies are result of a shot transistor or diode and of course the electro caps. Check these while your changing the caps.
Good luck with it.
Posted on May 25, 2009
  • 257 Answers
SOURCE: wont turn on
The power supply board has been defected. Replace it with a new one.
Posted on Aug 18, 2009
  • 117 Answers
SOURCE: Samsung LN52A650 lcd will not turn on after power
open it up / there should be a glass fuse replace it/ull find it were the mains lead goes on the board/also try new lead just incase
Posted on Dec 26, 2009
Samsung LN46D630 Wont turn on
http://www.tvrepairdoctor.com
Oct 26, 2012 | Samsung LN46D630 LCD TV
Samsung Plasma tv pn43d450 tv wont turn on
If caps there not puffed or leaking voltages in and out of the power board must be checked next (right at turn on of the set) to see which come up and or instantly go off....this is the place to begin.
Mar 27, 2012 | Samsung 43 PN43D450A2D Plasma TV
Samsung Lcd tv-sound but no picture-comes back after being off for long
hi i have condensation in the back of my samsung lcd tv it turns on but it just flickers anyone can help thanks
Feb 29, 2012 | Samsung LA46A550 46 in. HD-Ready LCD TV
Samsung tv wont turn on stand by button just keeps
hi,
your lcd tv got to replace the ip board (power board) the capacitor has already exhusted.
Apr 19, 2010 | Samsung LE40M91B 40 in. LCD TV
Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Jul 20, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Help: My tv picture has started going blurry
The picture tube is going bad,not worth repairing,better invest in a new set. The rating response is important to the person helping you.
Oct 11, 2006 | Samsung TXN2734 27" TV
Televison & Video Logo
317 people viewed this question
Henry  Thomas
Henry Thomas
