Question about Humminbird Matrix 97 Combo Fish Finder And Gps Chartplotter
Need a new screen for matrix 97
Screen has big round black circle in middle of screen. Am I better off just replacing the unit, can this be repaired reasonable or there something that I can plug up to that is interchangeable
How to fix the big dark circle in the middle of the screen
I think you may be having a problem with the projection bulb.
Jun 09, 2014 | Sony VPL-ES1 Multimedia Projector
Big black circle spot appears on the upper left side of the lcd
It seems your screen is bleeding. If it is not acceptable, then you can replace this screen.
Mar 10, 2014 | Sony VAIO Notebook
I have a 37 in sharp lcd tv. it has a black line in the middle of the screen. looks like it burnt into the screeen. is this repairable?
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this help.....
Jun 22, 2010 | Sharp Televison & Video
BLACK LINE on screen and see-through Pink Bar!
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
Apr 12, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Red circle in middle of screen color is way off
You have a problem with the light engine. Hitachi has extended the warranty on some of these. This is a major expense with major labor charges. Better get in contact with a local Hitachi authorized repair facility.
Apr 30, 2009 | Televison & Video
I have a hummingbird matrix 67 gps chartplotter fish finder. It developed a problem with the screen. The outer edges are legible, but the center is damaged. Is it worth repairing. Are there any other...
Hummingbird will refurbish that one for around 150US dollars, better then 500+ for a new one. If the screen is subjected to direct sunlight and heats up it can go out. This is why they discontinued the 67 model and replaced it with the 767.
Apr 21, 2009 | Humminbird MATRIX 67 GPS Receiver
Image has big yellow
Hi Zenmast
This is a burnt LCD that will need replacement. If the circle is yellow on a white screen , then it is your blue LCD that will need replacement.
Apr 22, 2008 | SharpVision XV-Z1U Multimedia Projector
Black spots
If you hit the screen, then there is noting you can do. the lcd matrix would need to be replaced.
Apr 05, 2008 | Dell E173FP 17" LCD Monitor
Tv has a big black in yhe middle,does that mean that the picture tube is going out
no that is not the sympton of picture tube failure. please give the details of your problem so we will get you solution.
Oct 07, 2007 | Philips Magnavox 27MS343S 27" TV
Humminbird Matrix 97 Combo Fish Finder And Gps Chartplotter Logo
Top Humminbird Boating Experts
Phil Walker
Phil Walker
Steve
Steve
fordexpert
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
