Question about Memorex 64GB MINI TRAVELDRIVE 98515 USB 20 Hard Drive
Memorex 64GB MINI TRAVELDRIVE 98515 USB 2 CRASHES WN XP
SOURCE: Memores 4G Mega Traveldrive doesn't read
Step one is try it on another computer. This will seperate issues....is it the drive or the USB port (hardware or software actully in both cases are possible.
Step two, if it works elsewhere, is to check under device manager, and reinstall the driver (if not embedded in the drive which most are)....both USB and the disk.
Step three is to download (again assuming it did not work) the disk diagnostics from Memorex (most drive manufacturers have a host of utilities and they may exist even for flash drives - they use them internal to their mfg operations as well). Check to see if it's good. It is possible that it just lost the embedded driver by the way in which case you need to put it back on the drive...haven't done that but assume it's possible and available.
Can give you more "stuff" to do but this will probably solve the problem....and I am guessing it died. If it did they are not expensive...and even cheaper if you really don't need 4 gb...few people do for personal and even work data.
Check at pricewatch.com (not a seller) for pricing. This site is used by GEEKS United for finding "stuff".
This gives you some options.....Tango
Posted on Jan 25, 2008
  • 51 Answers
SOURCE: how do you remove the data from the traveldrive memorex 256 mb
just format it
Posted on Aug 20, 2009
  • 211 Answers
SOURCE: I have just upgraded to a Windows 7 system. My
  1. break all ur partations and recreate them ... and then format the usb drive
Posted on Jan 10, 2010
jose_v17
  • 227 Answers
SOURCE: can I erase the info on my memorex traveldrive and
  • Yes you can its quick and easy
Start by clicking on the Start Panel, this will open a new window, find your drive and then right click on it, a menu will pop up and and towards the bottom, choose format, you will be warned by windows that all data will be lost which is what you want. just click OK and a few minutes later wallah a fresh Hard Drive. let me know if yo need anymore help
Posted on Apr 03, 2010
JaxPlanet
  • 922 Answers
SOURCE: I need the driver for
TEST
Posted on Feb 08, 2011
I cannot get my Memorex 64GB USB flash drive to open on my computer. I have windows 7 and when looking at my control panel and under drive status, it says this device cannot start (code 10). What do I...
Trouble shooting steps I would probably take:
1) Power cycle the computer (unplugged), and try it again, when it is COMPLETELY booted.
2) unplug it and plug it into a different port(s).
4) Try it on a different computer (both PC and MAC, as it could be a formatting issue) (if it doesn't work, entertain the reality that I may have lost everything and may have to format the drive and/or buy a new one)
Oct 22, 2013 | Memorex Mega TravelDrive 4 GB USB Hard...
Memorex ultra traveldrive usb 2.0 driver windows 7
it looks like is empty but i now it has my records!!! what I must do?
Feb 27, 2013 | Memorex Ultra Traveldrive - 160GB USB Hard...
I deleted all the memory in the flash drive, its a 2 gb, but it tells me that theres only 41mgb in it.
Try emptying you trash on the computer that you deleted the information on. Or recycling bin depending on the type of computer. When you "delete" the information from the flash drive, it does not permanently delete it until the "Trash" is emptied.
May 20, 2011 | Memorex Mini TravelDrive - USB flash drive...
I have a Memorex Ultra Drive connected via USB to a Windows XP machine. It shows up in My Computer as a folder but then disappears again. It does this repeatedly. The drive is formated as a FAT32. How...
As you have described that your Memorex Ultra Traveldrive re-appears repeatedly, indicates that the communication between your computer and your external hard drive is intermittent. The FAT32 format does not produce these types of issues. What we can do first is identify what causes the problem.
Assuming that the hard drive in your Memorex Ultra Traveldrive is in good shape:
Troubleshooting Method #1. Try connecting your Memorex Ultra Traveldrive into another USB port. If the problem persists, use another USB cable for your external hard drive. If the problem still persists, you will have to replace the external casing of your external hard drive. If your external hard drive works with the other USB port perfectly, most likely, the USB port where you originally plug into of your Windows XP machine needs to be checked. That USB port might need some repairing.
Troubleshooting Method #2. Try connecting the external hard drive into another computer and perform the same troubleshooting as Method #1. If your external hard drive works with other computers perfectly, most likely, the USB port where you originally plug into of your Windows XP machine needs to be checked. The USB port might need some repairing.
If the problem only occurs with your Windows XP machine, assuming all USB ports are in good shape, your Windows XP needs to be checked for some software issues.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Apr 06, 2011 | Memorex Ultra Traveldrive - 160GB USB Hard...
Need software for 512mb traveldrive using Windows 7
The TravelDrive is a "plug-and-play" device, and Windows 7 supports Plug-and-Play.
So, any device-drivers are included, and will automatically be used when you connect the TravelDrive.
What problems are you having? Symptoms? Error-messages? Does the TravelDrive work in some other computer? Does any other USB device work in the USB port that you are using for the TravelDrive?
Dec 18, 2010 | Memorex Mega TravelDrive 4 GB USB Hard...
How to use
you can download your memorex mega travelDrive 4 manual from this link
http://www.memorex.com/PageFiles/1180/manual.PDF
and learn well how to use hope that was helpfull
Sep 11, 2010 | Memorex Mega TravelDrive 4 GB USB Hard...
Memorex 64GB MINI TRAVELDRIVE 98515 USB 20 Hard Drive Logo
53 people viewed this question
Top Memorex Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Piyal Perera
Piyal Perera
Jax Planet
Jax Planet
Are you a Memorex Computer and Internet Expert? Answer questions, earn points and help others
