Question about Dryers
Can I run the heating function on my Garrison 5451 without venting to the outside?
I live in Winnipeg, so in winter we insulate the windows. I don't want to have to open one to use the heating mode on my Garrison Portable Home Comfort System. Can I simply run it standing free in the room?
  • 69 Answers
NO!!!
Posted on Dec 09, 2012
rogrrabbit
  • 986 Answers
SOURCE: My Fisher & Paykel dryer is not putting off
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Sep 12, 2009
  • 248 Answers
SOURCE: doesnt dry clothes, every opening i have
Hi, I experienced the same problem with my Maytag electric dryer. I finally fixed the problem after I checked the actual vent pipe (which allows air to discharge to the outside of your home). What I found was quite surprising. I found was a mouse nesyt in this pipe. Once I removed the mouse next,m my electric dryer worked fine. Just a thought. Good Luck!
Posted on Jan 09, 2011
wrightly
  • 140 Answers
SOURCE: Recently moved to new house. Dryer was working
more than likely the heating element is not working. if there's no heat at all, this is probably the culprit. you have to gain access to the heating element to test it for continuity. no continuity=bad element=needs to be replaced. if you can get this far, then it's easy to change it out.
Posted on Jul 06, 2011
heatman101
  • 43501 Answers
SOURCE: The dryer runs but there's no heat. The vent
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101\[
Posted on Aug 12, 2011
hunter19_46m
  • 7482 Answers
SOURCE: my neptune dryer seems to
Hi twokids90s
Check and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is not running hot anymore.
Make sure your lint screen is in place and has no tears or holes in it and is still firmly attached to the frame.
If you are running too hot you are not moving enough air thru the system.
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Please take time to rate me.
Posted on Aug 20, 2011
I am looking for a umbrella cap to cover my 15 inch attic exhaust fan
Many people just use large black trash bags secured with duct tape or bungi cords. Black bags won't deteriorate as fast as the white ones with the UV rays of the sun and should last one full winter.
If you're concerned about the neighbors complaining about the lack of asthetics....I can't help you.
I never cover attic vents nor recommend them to be covered, because a properly vented attic all year long ensures moisture removal from the attic area and from the insulation. Also if you have shingled roofing, each nail point extending through the sheeting will condense moisture and drip into the insulation in a non vented attic space. This happens many times each winter when the air temp and the moisture content collide on the dew point scale. It does NOT happen daily.
The nails conduct the warmth to the outside, cool down and attract the moisture from the non vented air on their exposed length and slide down to the tip dripping into the insulation. Moisture detracts from the insulations ability to do its job, and that's to insulate the living space from abnormally cold or hot temperatures.
Apr 20, 2014 | Speedi-Products 6" Galvanized Umbrella...
What would cause moisture to collect on the inside of my house windows. Im in illinois, its cold and the furnace is running. It cant be good to have this water on the windows. It drips on the wood. Does...
Hello, if you have a humidifier running along with your furnace than it is set to high and must be turned down. Usually this is what causes condensation to form on the windows due to a big temp differance and humididty between the indoor air and outside air.
Feb 09, 2011 | Heating & Cooling
I live in Winnipeg, Manitoba. I have an old Kenmore upright freezer. I would like to leave it in my unheated patio over the winter. Should I leave it plugged in, or can I unplug it and just watch the...
Leave it plugged in. It won't over freeze. If the outside air is cold then it won't need to run as much to bring down the temp-nature is doing that. So when the weather gets warm it will run to keep everything frozen. Hope this helps. Google burdfrenzy
Nov 25, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Asko Dishwasher insulating liner (sound or heat? not sure)
This is insulation to retain heat as well as sound dampening. If you are in the south where it is rarely cold you can get by without it save the noise increase. If it gets pretty cool then operation will be severely affected. You can use any insulation method available to you to accomplish the task. Styrofoam, cork, fiberglass. If cost is no object the material for putting in car doors works nicely. I've seen them so insulated you cannot hear them running at all.
Eric
Dec 23, 2009 | Dishwashers
Have a large new house with lots of vinyl clad wood double hung windows on a lake temp today this am is 0 F we have a HRV system house temp is 66 downstairs and 58 upstairs heating with a heat pump and...
Really not efficent to run a heat pump at those temperatures. Below freezing is not good for the compressor in the outside unit. The humidity in the house with the low temp. is causing the condensation on the windows to freeze. Kinda like an air conditoner does in the summer without the freezing humid air from the house goes over the cold a/c coil and the moisture condensates on the coil running down to drain pan. raising the temp. in the house and lowering the humidity should help. I would also recommend running the electric heat in low outside teperatures.
Dec 17, 2009 | Aprilaire 600 Humidifier
Zoneline Airconditioning - Winterizing and drain line
Yes this will recycle the room and can be cover outside if it is not a heat pump and will use elec heat strips to heat. As long as it is tilled toward the back the water will run out the back without a drain kit there should also be a drain hole in the bottom.
Oct 06, 2008 | GE Heating & Cooling
Dayton gas heater mod 3E404
This is an easily fixed problem. There are two thermistor switches on Dayton furnaces. One controls the fan motor run function and the heater valve on/off function. The other called a blocked vent switch (located in the top front of the heater) stops the gas valve from opening in the event the
vent is plugged. However, if the furnace was totally shut down for the summer and is now being fired up for winter, the block vent switch has to be reset. The switch has a reset button on it, push it and it should solve your problem. Also, check to make sure the fan run thermistor is clean and does not have debris around it as that acts a insulator for heat to keep the fan run function on.
Dec 30, 2007 | Heating & Cooling
Dryers Logo
156 people viewed this question
Top Dryers Experts
