Question about Acer Power FH PC Desktop
It won't power up. I have tried all of the "normal" fixes.
The computer will not turn on. Is there a power reset button? I actually have two of these, and both are in the same condition.
  • 2 more comments
  • steve_peasle
    steve_peasle Dec 10, 2012
    They didn't both go out at the same exact time, but rather about 4-6 months apart. My feeling is that there's some sort of built-in lifespan on these, since they're the same model. I bought them probably 5-6 yrs ago. In both cases, there was a reason to shut the power off, and then it wouldn't turn back on. Everything else - monitor, speakers, etc - all work fine. Only the computers fail to even acknowledge that I'm trying to turn them on.
  • max carson
    max carson Dec 10, 2012
    I had a old HP sr1120nx (2005) similar issue, I replaced the PSU and solved the problem. I had add extras to the desktop, graphica card, sound card, Speakers, etc., which required more power. It may have over taxed the PSU. My point is if you want to keep them, I would try a PSU, easy fix, not that expensive.
  • max carson
    Also check the MotherBoard for a in-line fuse. Some Mobo's have a fuse, if blown the Motherboard will not get power. Let us know how it goes.
  • max carson
    Sorry I forgot replace the CMOS battery as well, again, easy fix , not expensive.
  • Acer Master
  • 7,627 Answers
Does it start , lights come on and shutdown in a few seconds? Can you describe what happens when you push the on/off button. BOTH? Do you have them on a battery backup/surge protector? Need more info.
Posted on Dec 09, 2012
  • steve_peasle
    steve_peasle Dec 09, 2012
    Nothing happens at all. No lights, sound, nothing. I had them both on different UPS/surge protectors, but have unplugged and then plugged them straight into the outlets, which work for everything else, as did the UPS. Thanks for your help, Max.
  • max carson
    max carson Dec 09, 2012
    Bad PSU come to mind, but in both at the same time? Some Motherboards have in-line fuses on the boards. Both went out at the same time??? Power surge? Any thing out of the ordinary with the power? Are they the same age? Have you opened the case? Any electronic burn smell? BOTH very odd.
Dell logo won't go away.
If you are lucky a hard power reset will fix this. Disconnect all the cables, hold the power button on for 10 seconds, release the power button, reconnect the cables and turn it back on. Otherwise you may have a hardware problem.
Jul 09, 2017 | Dell E2210 22" Widescreen Flat Panel...
Danby portable air conditioner won't turn on - brand new!
Obviously it is problematic machine from the factory so it will suggest a replacement.
Apr 12, 2012 | Danby DPAC12010H Portable Air Conditioner
The 'boost' button on my aqualisa digital shower won't switch off. It comes on when I press the shower on (without actually pressing the boost button) and when I press the boost button to try...
Good Morning drlesleyanne. The issue you describe will down to the PCB inside the push button controller. If this does not send the correct signal to the processor box it can cause the unit to 'fail safe' and this is why the unit needs a power reboot. The remedy to this is to replace the push button control itself and once installed should allow the shower to work correctly again. All our digital products have five year guarantees, so you can always call our Customer Service line on 01959 560010 and they will replace this for free.
Kind Regards,
The Aqualisa Team
Jul 29, 2011 | Home
When I press "Music" on the menu, the unit
Welcome to Fixya. If your player freezes and you already press the reset button it seems that the issue is the you can try to update the software and see if it will fix the issue. Can you provide the operating system of your computer.
Thanks
Jul 19, 2011 | Philips GoGear SA5285/37 Digital Media...
My HP compact nc6000 laptop went to Hiberating mode and i don't know how to fix the problem. If i could please get help that would be great. i just got this laptop yesterday. it was working but all of...
Hi Jessica,
Hibernation mode usually turns the computer off but saves any work. Then you would start it back up by hitting the power button, it will boot up and you log in like normal and the computer should be as it was before it went into hibernation.
If you can't get it out of hibernation by pressing the power button, try holding the power button for 5-10 seconds. The laptop may actually still be on, and holding the power button will cut if off. Once the computer is back on you can change the battery options(hibernation/turn off settings) in Windows by going to the bottom right task bar and right clicking on the battery icon. Normally you will have an option like "power saving settings", "battery settings". In this setting window you can turn off hibernation due to inactivity.
Let me know if you have any questions.
Regards,
G33k
Jul 09, 2011 | HP Compaq nc6000 Notebook
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
My Belkin F5D8236-4 v3 Router won't turn on. We had a storm last night and the power went out but the router won't turn on. I have tried to plug it into different outlets to see if that would work...
Try resetting the router. There should be a little hole somewhere on it with a button inside that you can press with a paperclip. Try holding that button down while you unplug then plug the router in while holding it (if possible). If that doesn't work, I'd suspect the storm might've damaged the router somehow. Was it plugged into a surge protector, and/or have you noticed any other issues with anything else that was turned on at the time?
Jun 16, 2011 | Belkin F5D8236-4 Router
My coby kyros won't turn on, won't charge, no lights are coming on
Mine does that to but all I ever do it just hit the reset button on the back and it turns back on.
May 18, 2011 | Coby Kyros 716829701508 Tablet PC
Screen frozen, can't turn off
Hold the power button down on the actual tower of your computer. After about 10-15 seconds the computer will turn off and you can restart it. If that fails, as a last resort pull the power cable out of the tower. It isn't as damaging to the computer as most people think but should only be used if the computer won't turn off any other way.
Apr 07, 2011 | Computers & Internet
Acer Power FH  PC Desktop Logo
169 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
