Question about GE Energy Star WCVH6260F Front Load Washer
Drum seems off balance during spin cycle making loud thump what could be wrong?
Model # cannot be located. It is a GE Energy Star 8 cycle heavy duty deluxe quiet. Suddenly during spin cycle the drum starting making a pounding noise like when it is off balance with heavy clothes to one side. However, drum still sounds this way with no clothes in washer. Can someone help me?
  • 106 Answers
SOURCE: Loud banging noise durning washing machine spin cycles.
First plug off the wall. Open the machine from behind to examine if any shock-absorbers(known as dampers) or springs have come off or broken. Your dealer could help with spares. But you could do the job yourself.
For spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Posted on Mar 02, 2009
jmgldsmth
  • 2005 Answers
SOURCE: chugging like noise during certain cycles
your clutch need to be replaced as does the tub shaft bearings i;m sorry this is not a do-it-yourself job, try to make a deal to trade in your washer
Posted on Apr 22, 2009
milten1
  • 1304 Answers
SOURCE: loud thumping noise when the drum starts to spin.
see if you shake or tilt or move the inner tub
if you can you may have a groken spinner support
dont know hold old the machine is, but if its out of warrenty, it could be come very expensive repair
Posted on Oct 06, 2009
SOURCE: My GE front loading washer Model WCVH6260 does not
This has happened to us also. Our machine is 27 months old. I just had a non-GE repairman out and he showed me the mutilated belt. I was wrapped around the pulley. He said that the pulley had to be out of wack in order for this to happen because the belt looked in great condition (besides being in 3 pieces). Then the metal wheel (don't know the official name) is now warped and had gouged 3 grooves into the cheap plastic outer tub. So badly that it went thru to where the water is. So NOW, I have a big piece of scrap metal in my basement. I need a new outer tub, pulley, belt and at least 2 hours of labor. So a bill of 4-500$. I think GE can take this hunk of metal! But of course, GE has to send out their service man to inspect it. So I have to pay another service fee. They need to scrap this model and possibly others. What a waste of a whole lot of money. NEVER again.
Posted on Oct 20, 2009
  • 380 Answers
SOURCE: the drum inside my washer is leaning over to the
Take the top off and resit the springs that are on there. Most likely you over loaded it and it went crazy.
Posted on Dec 04, 2009
GE front load washer makes a loud slapping sound during the spin cycle and it sounds like something heavy is in the drum that keeps falling to the bottom of the drum when the spin cycle ends
You did not post the model number and that would be a must. However this sounds like the bearing or the pulley on the drum may have broken.
Dec 18, 2017 | GE Washing Machines
What could be the cause of loud thumping during spin?
Sounds like one of the balancing springs either broke or came off.
Feb 02, 2016 | Speed Washing Machines
My kenmore 417 wahser making too much noise, it looks like the inner tub hitting the outer plastic housing. How can I fix it?
Have you tried moving the clothes around in the drum to balance the drum BEFORE you was them? If that works, you have solved the problem! Most people forget that when cloth gets wet it gets heavy so leaving the clothes unevenly placed in the drum dry will make a real problem when they get wet!
Dec 26, 2012 | Kenmore Washing Machines
Older Model GE Energy Star Front Loader 8 cycle Heavy Duty Deluxe Quiet. Drum makes loud thumping on spin cycle what could it be?
The drum is supported by springs. Maybe one of them broke. You might have to open it up to visually inspect it. You can find videos on YouTube on how to do it. Good luck!
Dec 09, 2012 | GE Washing Machines
My GE GCVH6260FWW front load washer made a load snap while spinning. Repair man couldn't find anything. So we ran a load through and at the end of the wash cycle it started thumping and vibrating on high...
If the drum is also loose, it is dead. The plastic your are finding comes from a part inside. It will cost more (or close) to fix than to replace and you risk breaking other critical parts if you DYI.
Mar 01, 2011 | GE Energy Star WCVH6260F Front Load Washer
Load always bNGING DURING SPIN CYCLE
open the front cover and check for a loose counter-balance weight on the outer drum and also defective shock absorbers or springs on the bottom of the outer drum
Apr 16, 2010 | GE Energy Star WCVH6260F Front Load Washer
GE WSXH208A makes a lound noise during the spin
check to see if the washer is balanced (cloths are evenly placed in drum) if it sounds like banging noise
Jan 20, 2010 | Washing Machines
Thumping and banging
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
Feb 09, 2008 | Kenmore 24032\24036 Top Load Washer
Loud clicking/thumping in rinse and spin cycle
It doesn't look like a motor problem !!! It seems like an unbalanced tub issue. The machin has suspension dampers and suspension rods, and it's look like one of them was damaged or "run away" from its location during machin's movement. Goog luck !!
Jun 14, 2006 | GE Profile Prodigy WPSE4200A
GE Energy Star WCVH6260F Front Load Washer Logo
110 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
