Question about Frigidaire Electric Dryer
Frigidare dryer gleq215ee won't heat then shuts off after about 10 minutes. 4 lights on right flash. no error code comes on. I am pretty handy and can take apart and fix. would need to know what t
  • Official Brand Answer
  • 4,342 Answers
Hello John Sterns - First, try resetting the unit dryer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Restart unit and if it proves to be ineffective then typically this is something that a professional would need to diagnose. Since it is such a complex unit, there are multiple possible causes; faulty power cord, house wiring, defective control board, thermal limiter or door switch.
Posted on Dec 14, 2012
  • Janet Wright
    Janet Wright Jul 02, 2014
    I have barely used this appliance.
Healeyman
  • 1198 Answers
SOURCE: Dryer will work for about 15-20 minutes. Then
Always list your machine model, mfg, type, voltatge, etc. The more info we have the more we can help you. If you just got the machine, check your warranty. Blinking lights probably mean an electronic control problem, you're going to need a qualified tech to fix that.
Posted on Apr 25, 2009
localwonder
  • 6784 Answers
SOURCE: Dryer front load model # GLG22152ESO, Flashes Error Code E9E
Ok, i would also pull the blower assembly and, check it for clog's as well. clean out the entire exhaust hose as well. if this doesn't stop the shut down, you will need to replace the hi limit thermostat and (dryness)sensor(if equipped) as well.
Posted on Jun 09, 2009
dragonsthatk
  • 547 Answers
SOURCE: LEQ2152ES 2005 dryer shuts off when start us pushed
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Posted on Jun 19, 2009
  • 5 Answers
SOURCE: Error Code E68 stuck button?
control boards for this model are as low as $146.00 on ebay, although the code 68 "button stuck " issues 's I've found have been the start button switch ,found one at the local electronic store[close to what's on the board , but not exact !] for $3.99 fixed one for a customer of mine [just to see if that was indeed the problem]. Been running for the last year so far
Posted on May 24, 2010
  • 472 Answers
SOURCE: fridigaire dryer GLEQ642AS2 running but not
sounds like you started checking the right areas first... make sure you actually have correct voltage coming to rear of dryer should be between 220-245 volts at power supply across the 2 outside power wires... check both at same time to make sure electrical circuit is correct.. some people only check 1 leg at a time to ground and thats great but you actually need to check both hot leads and see if your getting the above voltage i stated... if so then is anything working the light on inside or does it tumble at all just no heat... if nothing at all works i would test the thermal cutoff switch located near the heating element but normally closer to the blower assembly... it will usually be a white round /flat disk with 2 wires coming out of it. remove 2 wires and test contuinity should beep at you or give closed circuit. if not replace and then check for obstructions in the heating vent or blower assembly also make sure the termination exhaust point is clear no birds nest etc... if that is not the problem and the unit works just no heat check the heating thermostat located close to the heating element remove the wires and test the same ways as i mentioned above it should beep or give closed circuit indication... if that good move to heating element and check it same way... hopefully one of these are your culprit...if all that looks good possible the timer is bad.... repost with anymore questions and a little more info.... wish you luck
Posted on Feb 10, 2011
F10 code flashing on my frigidare oven
A faulty RTD sensor probe is one of the causes for an F10 code or overheating oven. The sensor probe is supposed to detect the exact temperature in the Frigidaire electricrange cavity and relay it to the oven's main control so it knows when to shut off the heating elements.
Hope this helps
Bob
Sep 15, 2017 | Frigidare Ovens
How do I make my Frigidaire Affinity dryer stop beeping and run?
Have you checked the lint has been cleaned off filter and water reservoir emptied.?
Dec 09, 2014 | Frigidaire Dryers
I have an error code 64 on my dryer. I am out of work doing chemo right now. can anyone tell me what the problem is
If your Frigidaire Affinity dryer is beeping at you and giving you the "E64 CALL SERVICE" business, chances are you have a bad heating element. The good news is, with a screwdriver, a pair of pliers (a multimeter if you have one) and a new heater element you can fix this yourself and save a couple hundred bucks.
Below I outline a step by step process to do this on the Frigidaire Affinity, but this guide may help with other dryers, as they basically all function the same way.
A WORD OF CAUTION: You will be handling a lot of thin sheet metal components. Be careful as it is easy to cut yourself on them.
First you'll want to unplug the dryer. Then disconnect the vent hose and the water feed (if applicable). Be sure and shut off the water valve first, or you'll have a mess!
http://therandomfix.blogspot.com/2013/07/frigidaire-affinity-e64-error.html
Apr 03, 2014 | Frigidaire Brand New Frigidare Dryer Motor...
Dryer is tumbling but no heat - when I reset it shuts off after about 10 min and the Drying, Cool Down, and Extended Tumble lights are all flashing.
Janet McDonald,
I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
-Best Regards-
Jan 14, 2014 | Frigidaire AEQ6700FE Affinity Electric...
Tumble dryer
If you have not already. Disconnect the unit from the wall for 5 minutes. A power glitch may have caused this error. The Central Control Unit (CCU) is not operating properly. It sounds like that may be your trouble. If someone is handy in the home. Have them unplug the unit and remove the rear top screws to the upper panel to check for any loose connections. There is a thermistor located behind the front bottom removable panel next to the thermal fuse. Unfortunately this may take a repairman to come out and diagnose. If anything else comes to mind on your washer repair I will let you know.
May 05, 2013 | Dryers
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidare AEQ600es2 does not heat. Reports error code E68, but all buttons seem to work.
You will nee The error code E68 is a stuck button error code. I recommend checking each button to make sure it loose in the plastic console. The button should rock side to side a little bit. If all the buttons are loose you can try to reset the unit control by unplugging the dryer for two minutes. If the error code comes back you will need to replace the unit control.
Apr 17, 2012 | Frigidaire AEQ6000ES Electric Dryer
Set won't turn on, 10 red flashing lights
This is an error code and depending on brand/model number can have a number of meanings---
You can GOOGLE the model number with "error codes" etc to get an idea of what likely your error code means.
Mar 19, 2012 | Televison & Video
My dryer will run, but won't heat. After about 15-20 minutes, the dryer stops and all the indicator lights (drying, cool down, etc.) flash but no error code shows. I took off the front panel and...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 11, 2011 | Frigidaire GLGQ2152ES Gas Dryer
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    Frigidaire  Electric Dryer Logo
    179 people viewed this question
    Top Frigidaire Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
