Question about Maytag MER5750 Electric Kitchen Range
My maytag electric oven mer5750 wont turn on OFF is showing up on the screen
My oven wont turn on and OFF is showing up on the screen
    Top Expert:
  • Maytag Master
  • 9,472 Answers
If the unit was off, and the on light, not the hot surface light, was on, then when you turned the unit off, the light went off, you may have a bad switch on the unit. You will need to turn the switches on and off one at a time until you locate the switch with a bad terminal. Post back your results.
Posted on Dec 09, 2012
2 Suggested Answers
huuum
  • 750 Answers
SOURCE: maytag electric gemini,model mer6755aaw
Hello bigboy1666,
Welcome to Fixya,
You said, Oven does not show any displace and does not work. When you try to turn on the top oven, the displace shows h3 132 and the clock shows 12:00 .
You try to turn the upper and lower oven, none of them work. The light in the oven comes on okay.
Lets try to reset the system.
trun off the range.
Now trhow the breaker in the electric box off for 5 minutes.
after waiting 5 minutes turn the power on and try the range!
Let me know how she works.
Huuum at your service.
Please remember to leave a rating!
Posted on Oct 06, 2008
Oven light wont turn off
make sure the door is shut tight and making the switch
Jan 04, 2014 | Maytag 30" Built-In Single Electric Wall...
F-4 code on maytag cwe900
F4 = temperature sensor probe error.Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 08, 2012 | Maytag MER5750 Electric Kitchen Range
Oven will not shut off pull cancel did not work do you think it is control pad
I think you are correct. The oven relays are located on the Electronic Oven Control (EOC) board and will sometimes short (when bad) and not shut off. You will need to turn the circuit breaker off to the appliance to shut it off for now. Replacing the EOC (also known as an Electronic Range Control - ERC) board should correct the problem. The following link explains step-by-step how to access and replace the control board on MOST electric ranges:
http://www.fixya.com/support/r3727366-replacing_control_kitchen_range
A replacement control board can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three websites on the list also have helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. The replacement part number will be determined by the remaining digits in your serial number. There are three LETTERS following the number sequence. If you have any difficulties in locating parts, or need further assistance, please post back and let me know. I hope this helps you.
Apr 18, 2011 | Maytag MER5750 Electric Kitchen Range
Where can I go and get directions on how to replace the front left element on my glass top Maytag stove model #mer5750BAW. The stove top has to be lifted and the element underneth needs to be replaced or...
Good afternoon. We are Maytag factory authorized service and parts suppliers and have all the solutions for your Maytag appliance issues.
We have the proper element for this model and can get it out to you asap.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 7 PM CST and we will get your parts out right away.
We look forward to hearing from you. Thanks, Ella
Jan 15, 2010 | Maytag MER5750 Electric Kitchen Range
Maytag electric gemini,model mer6755aaw
Hello bigboy1666,
Welcome to Fixya,
trun off the range.
Oct 06, 2008 | Maytag MER6772 Gemini Electric Kitchen...
MER57550AWAW electric - won't heat to selected preset temp
can you see lower (bake) element or is it hidden(under the oven floor). a visual inspection of elemnet is usually all that is required to determine if its good or not, It will have a "burn out" in it perhaps a plume of white soot around damaged area.in which case you will need to replace the element. simple enough 2screws and 2 wires part number 74010750.. if it is a "hidden" bake elemnt the floor oh oven lifts rightup to reveal it."POWER MUST BE TURNED OFF!!!!!!!! IT IS A CONSTSANTLY LIVE ELEMENT!!!!!!!!!!!!
Mar 16, 2008 | Maytag MER5750 Electric Kitchen Range
Burners not working on a Maytag Electric Range
The top of the range will open if you remove the three screws under the front edge of the top. You will need to open the oven door to see them. But first, unplug the range or turn of the circuit breaker. There's still live voltages (240VAC) even with the range turned off. Also use care not to lean on the oven door or you could damage the springs. If the top does not have any brackets to hold it up you may need to find something to prop it up, or use a second set of hands. The elements are easily removed by removing a couple of screws and the some wires. Write down the wire colors and where they go to assist in making sure you reconnect them correctly. Also, pay particular attention to the numbered holes on the back of the element. Make sure you reconnect the retaining brackets in the same numbered holes as you removed them. Last of all, do not handle the ceramic material or element coil with your bare hands. They are fragile and the oils from your hands could create hot spots and potentially ruin the element. I do not know the arrangement of your elements, but I suspect you have one of each size burned out. The part numbers are as follows: 6" element: 1032743 9" element: 1035285 The prices are about the same ($40 ea.) with the larger element costing slightly more. I hope this helps you.
Sep 02, 2007 | Maytag MER5750 Electric Kitchen Range
The "hot Surface" light is remaining on continuously. (the surface light is off)
all surface knobs [switches] feed into a common relay for the surface light. check for a stuck relay.
Aug 20, 2007 | Maytag MER5750 Electric Kitchen Range
Maytag MER5750 Electric Kitchen Range Logo
78 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
