Question about Kitchen Ranges
Hi I have a new Frigidaire model# CFEF3007LWF, it the burners does not heat up quickly and when it does it is not hot enough. It takes a long time to do anything and does not get very hot. not hot en
Burners do not not get very hot .
  • Marie Gurcharn Dec 09, 2012
    I understand that there a safety thing on these models that stops it from getting too hot or as hot as other stoves. I would like to know it this is true and if and how it can be removed or turned off.
    Just heating up a pan or boiling water takes forever.
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
First, be sure that the breakers are both on. You may have one tripped.
Posted on Dec 09, 2012
3 Suggested Answers
rockitman187
  • 2559 Answers
SOURCE: Surface of stove heats very hot when oven is on.
This is normal and designed to do so.
Posted on May 15, 2009
shinn8
  • 85 Answers
SOURCE: Oven burner will not light. Ignitor is orange hot.
When ignitor gets worn it will come on but not get hot enough to open the gas valve. Very rarely the valve fails.
Part number 5303935066
Posted on May 20, 2009
Where to replace burners for my zanussi gas stove ZCG831W
without new parts I would suggest buying a new stove. SORRY
Jan 08, 2015 | Zanussi Kitchen Ranges
We have a 40amp hot wired stove but now we just bought a frigidaire fef366dce with a 50amp. Will the new stove work well if hot wired to the 40amp
The new stove may work but you may also blow the breaker/ fuse which ever you have... make sure to leave the 40 amp fuses or breaker in the box as the wiring will not be heavy enough to support a larger amp. fuse or breaker... that will start a fire!
You may find that you just cannot run all of the burners and the oven or broiler at the same time.
heatman101
Apr 19, 2011 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire Gallery Range (New). When plugged in, get a PF20 (power failure). Clock works fine. Both ovens work fine. Stovetop does not work. No heat in burners. No display over burner.
When it doesn't heat up,
We have a Frigidaire Range model PLEF398CCC and, as many others here have mentioned, we saw the puff of smoke and the oven nor the front left burner works. The repairman has to replace a EOC on the back of the control panel and another one in the back on the bottom. The total cost for parts alone is $438 then add in the service call cost. THIS IS THE SECOND TIME we've had an EOC go bad for big bucks. The unit is about 5 years old. We're thinking of filling the landfill with it.
Use this for troublshooting:
(home-electrical.suite101.com/article.cfm/troubleshooting_an_electric_range)
another testimony to help,
Had the same problem. This solved it for me:
(lazerangle.com/sanna/index.php?option=com_content&view=section&layout=blog&id=6&Itemid=63.).
Take care.
Jul 12, 2010 | Frigidaire Gallery GLEFM397DS Electric...
My burner gets excessively hot very quickly is this normal?
That right front burner is an extremely hot burner by design. It is sold as a quick power burner. The rating on it is 12,000 btu's meaning it could easily boil a pot of soup in that time.
Here is a quote from the owners manual for your range
"There is a 12,000 BTU*
burner located in the right front position. These burners offer
higher speed cooking that can be used to quickly bring water
to a boil and for large-quantity cooking."
Use the back for slower smaller cooking and front for larger and quick heating.
I hope that helps.
May 09, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
My oven wont heat up at all. gets no gas. the top
your glow coil is wron out , need to replace it, you may see it glowing in there but it isnt getting hot enough, usually you can switch out the broil one for a quick fix to get you outta truoble. easy do it yourself problem
Feb 05, 2010 | Frigidaire FEB27S5A Electric Single Oven
Not heating water hot enough or as much water.
You probably have a bad heating element. Probably the upper element.
Feb 03, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
May 20, 2009 | Frigidaire FGF334BG Kitchen Range
Frigidare Gas Dryer - get some heat, but NOT hot enough!!
You say its a gas dryer...there is no element. Have you cleaned the lint trap. Is the vent clear of obstructions? I suspect one of these issues will be the problem
Mar 16, 2009 | Frigidaire FGQ1442ES Gas Dryer
Oven takes a long time to heat up
your ignitor could be going out. the ignitor has to get hot enough in order for the gas to turn on and heat your oven. if your ignitor is going out, sometimes it doesn't glow hot enough for the gas to turn on, or it could be that is takes longer than normal to get hot enough to turn the gas on. I would replace the ignitor and that should solve the problem. Joe
Nov 15, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Burner didn't ignite on my AO Smith model FXGT/PGXT
Unless your AO is a high recover it will take a while for it to fill up with the water that you have used then reheat the water in the tank.
Nov 12, 2008 | Water Heaters
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
