Question about GE Ovens
Ge JKP55 WM2WW control panel blemish
Contro panel plastic part on face plate has bubble up.
3 Suggested Answers
freetek
  • 5568 Answers
SOURCE: Bubbles on control panel overlay
If the overlay isn't a protective foil that easily peals off, the hair dryer would only serve to distort it, I don't believe it will cause it to shrink to fit. If it was applied with a 'self-stick' backing, you may be able to puncture the bubbles and press it back down with a hot rag.
Posted on Sep 15, 2009
SOURCE: I have a GE JTP70, The Plastic over control panel bubbled up.
Mine did the same thing...and believe me it even looks worse over time....look online it happened to a lot of people....GE won't do anything about it....it is a defect but they won't own up to it......They just want you to keep replacing the part, which cost a fortune. Mine oven cost over $1000 and I am stuck with a nasty looking piece of garbage in my brand new kitchen......can't afford to buy a new one.........I Will NEVER BUY ANOTHER GE PRODUCT AGAIN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Jun 13, 2010
Where can I find parts for the control panel and button sensor. The tech said GE no longer makes them????
if the repairman said they no longer make why do you ask we will not find them either
Mar 17, 2015 | GE JKP55 Electric Double Oven
The plastic cover on our GE Oven Model JKP70W started separating and then came off, leaving it very unsightly. Can this be replaced or does the entire control panel need to be replaced? Any similar
Call GE - 866-622-6184
There is a campaign to replace that part as they are defective.
They will send you the part for free, but charge you $200 to install it. The install is not too hard. Make sure you power off the oven when you do it. Instructions are included.
May 07, 2012 | GE JKP70 Electric Single Oven
I moved the latch for my jtp15 ge oven and now it won't open. What do i do to move the latch back over?
The latches on this model oven have a very high failure rate. Once the latch fails it is permanent. To open the door you have to access the control panel to reach the door look. To do this first turn the power to the oven off at the service panel by turning the breaker off.
  • Step 1 Remove the three screws from the control panel. The control panel is on the outside of the oven, above the door handle. Pull the bottom of the control panel toward you, then lift it up. This action will release the control panel cover's tabs.
  • Step 2 The mechanism that operates the door latch during the self-cleaning cycle will be behind a smooth, square plate held in place with two screws. White, black and red wires, as well as a grounding wire, will be protruding from the face of the plate. These wires will be twisted together with other control panel wiring and covered with electrical wire caps.
  • Step 3 Remove the failed part by removing the caps and untwisting the wires. Using an appropriate wrench, extract any screws holding the plate in place. The cylindrical-shaped mechanism will be attached to and behind this plate.
  • Step 4 Visit a store or contact GE at (800) 626-2224 to acquire a replacement part. To reassemble, slide the new mechanism into where the old one was and reattach the plate with the screws. Reconnect the wires by twisting them together and replacing the electrical wire caps.
  • Step 5 Replace the control panel by slipping the top of the panel into its groove and angling the panel downward, dropping the tabs back into the slots. Replace the three screws.
  • Aug 14, 2010 | GE JTP15 Electric Single Oven
    Feb 19, 2010 | GE JTP70 Electric Single Oven
    My GE double oven JKP26GP broiler burned out (burned a hole right thru). The keypad immediately went blank and the keypad controlled top unit isn't working now (top unit only - bottom is fine). Will...
    I'm afraid I don't know how to help you get a new control panel (part #WB36K5065 is no longer available). But we have the same oven and a similar problem. Our control panel works just fine, but the face is melted from a recent mishap (small fire in the upper oven while broiling), so the plastic face of the control panel looks awful and needs replacing. If you decide to replace your oven and would like to sell the front face to your control panel we'd love to purchase from you.
    Nov 21, 2009 | GE Ovens
    Do I need to remove my wall oven GE model JTP14 to replace the heat sensor part # WB23T10002
    Usually you have to either remove the top of the oven or you can remove the back panel to access the sensor. or you can unscrew it from the inside and pull it out enough to unclip the harness and install the new one. if it is connected to the thermostat ( temp switch ) you have to remove the switch and install the new one and route the sensor the way the old one is routed which might involve doing one of the above options and removing the face plate the switch is connected to
    Sep 17, 2009 | Ovens
    I have exactly the same problem.
    same problem. bubbled after 8 mths. replaced by GE. then bubbled again after 7 mths. GE refused to replace again, said warranty was only one year and did not include parts replaced under warranty. obviously a defective part. i'm not buying GE anymore. Good luck.
    Sep 15, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
    Sep 15, 2009 | GE JKP27 Electric Double Oven
    Overlay Panel bubbles up!
    I had the same oven panel overlay bubbling problem on my GE oven purchased in 2008. It started peeling and bubbling within the 1 yr warranty, and GE sent me a replacement panel. This new part began bubbling again within 4 months. Again, I called but now they say it's out of warranty and they will not replace it. Obviously there's a manufacturing defect in this part. The panel looks terrible. It appears that GE no longer cares about the quality of their products.
    Jan 02, 2009 | Ovens
    Top oven will not heat up
    Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
    Nov 14, 2007 | GE JKP45 Electric Double Oven
    Ovens Logo
    47 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    Are you a GE Oven Expert? Answer questions, earn points and help others
