Question about Dryers
Mercator fan light with remote faults
Ceiling fan faults
Buffalo12980
  • 625 Answers
SOURCE: Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Posted on Aug 22, 2007
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
  • 34 Answers
SOURCE: HUNTER ceiling fan remote works with fan but not light
Unfortunately, you either have a faulty reciever or remote. A replacement will cost $30-$40 at homedepot2.gif. And it doesn't matter which is faulty because you can't purchase them seperately anyhow.
Posted on Sep 10, 2009
extreme7528
  • 108 Answers
SOURCE: Hunter fan wiring
sounds like one of your connections is loose. Im not sure if i completely understand your description of how you re-hoked up your fan. Please tell me how many wires your fan has and colors and how many wires you have on the sensor remote. (lots of times if you draw a wiring diagram on paper you can figure it out) Basically you should have power coming from ceiling to remote sensor. Then the remote sensor should throw the power to either the fan or the light, so there should be two seperate leads coming out of the remote sensor to control either the fan or the light independantly.
Posted on Oct 07, 2009
extreme7528
  • 108 Answers
SOURCE: ceiling fan and light with remote turns on and off by itself
Both the remote and reciever in the fan base have the ability to have the codes changed. What is happening is you are getting radio interference that is causing the problem. Change the codes by either switching the switches in different positions or adding more dip clips that came with the fan. In any case change the codes in both the reciever and remote to the same code and you should no longer have a problem. Usually the place to change the code in the remote is in the battery area and are small switches (usually 5 or 6 of them) and unfortunately you will have to take the fan down to do the one there.
Posted on Oct 12, 2009
My light on my ceilinf fan will only stay on dim.. What can I do to fix it.. It only operates bt remote
if fault is not on remote , you may need to bring down the ceiling fan and check on stuck electrical contacts and sensors to fix the problem.
Dec 28, 2013 | Hampton Bay Indoor Ceiling Fans and Light:...
My Hampton Bay Brookedale ceiling fan worked fine for a while. Went to turn it on the other day and won't work. Ceiling fan remote seems to work (light goes on when buttons pressed) but fan or l
The light on the remote is a battery light. First mistake was buying a store brand fan which are mostly low-end parts. Try adding a different remote w/receiver.
Mar 02, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
REMOTE DOES NOT WORK FAN OR LIGHT
Surely the fault in the remote control. open the remote is out off warranty and look for fault in the crystal or the IC. Solder and check, also the power connection and battery. If none work the IC can be faulty.
Sep 01, 2010 | Hampton Bay B52852WPB Redington III White...
Wiring instructions are terrible. Ceiling wires = Red, Black, White, Copper. Fan wires = Black, White, Copper. Remote wires = Neutral in(Black), Live In(Black), Light out(White), Fan out(White),...
That is dificult to follow .. here is the usual wiring plan for ceiling fans .. green to green or bare and mounting bracket ... ceiling black and red are live from the switches, fan and light.with a remote you really only need one of these , so cap off the red and use the black as your input to the remote .. the neutral to the remote should be the white .. there are only 3 wires from the fan so I am assuming that there is no light , or the light will be activated from the remote .. the black for the fan and the black for the lights connect to marked wires on the remote. .. lights out, fan out
or looking at your description .. ((Remote wires = Neutral in(Black) white ceiling wire, Live In(Black) blaxck ceiling wire, Light out(White) blue Fan/Light wire, Fan out(White) black fan/light wire, Common(White) white ceiling and white fan/light wires.
May 21, 2010 | Hunter 27148 Remote Control
Remote controlled ceiling fan
unplug the fan then remove the batteries from the remote then plug the fan back in and, reinstall the batteries; this resets the fan control
Apr 22, 2009 | Hampton Bay 24002 Ceiling Fan
How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
Remote control ceiling fan
Possibly a bad circuit board in the ceiling fans remote function. I would suspect that the circuit board has a thermal issue where once warm it works fine. The most common fault that I have seen is a bad solder connection on the board. Pull the board from the fan and check all solder connections for cracks or dull solder. If you see any of these then reflow the solder connections. If this does not work you probably will need to order a new board from the manu.
Jan 26, 2008 | Dryers
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Open Questions:
Dryers Logo
148 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
