Question about Toyota Vehicle Parts & Accessories
How to hook up my car horn to my alarm
Have a honda accord 98 i purchase a alarm ASTRA 777i asked the tech if
he could wire it to the horn. but he toll me he needed one one more relay.
and that was going to cost me another 55 dollars if i wanted hook to the horn can some one help how to wire from alarm to relay to horn he toll me
if i dont use a relay i could burn the alarm.....can some one helpppppp....
  • 45 Answers
It will not burn it up take the two wires from the siren and tape 2 wires of that and run them to your 2 horn wires and tape into the horn. Thats what i did and i havent had a problem since.
Posted on Jan 13, 2009
2 Suggested Answers
SOURCE: how to hook up my car horn to my alarm
Your tech is mistaken. The brown/white wire will hook directly to the lt.green/blue wire at the steering column in your car. Might require some programming at the alarm module.
How can i stop the alram every time i plug in the battery off a honda accord 2000 if the alarm is not manufactured by honda
Follow the alarm speaker (Horn sounding off) wiring. It will most likely go underneath the dash. Remove the box for the aftermarket alarm and all its wiring. (Not car manufacture harness) make sure to take it all out as certain models can leave vehicle unable to start if only partial removed.
May 22, 2015 | 2000 Honda Accord
98 ford escort horn goes off at night when its really cold
can be 4 things, as is true with all puters, as that is what it is.
1: bad inputs to the alarm (wires are corroded, shrink cold and fail)
2: bad sensors.
3: bad alarm processor.
4: bad outputs, ( the horn is a shared resource , so can be the horn stuck?)
to find this take real hard work. and tools for monitoring all inputs
to the alarm and see what fails. THE FSM covers all that
read the FSM and ask questions if any.
Jan 06, 2014 | 2003 Honda Civic
Which is the horn fuse honda accord 2ooo
My alarm on my 2002 honda accord keeps going off. Should I just remove the horn fuse, or go see a repair shop. I'm worried that they will try to give me the 'works' and end up costing me a fortune.
Jun 02, 2012 | 2002 Honda Accord
1998 Accord security system goes off for no reason and goes until battery drained. Horn has been disconnected for benefit of neighborhood. Cleaned and had battery checked by Batterys Plus and battery is...
The 98-02 accord do have hood latch problem that cause the alarm to go off like what you're having. One thing you can try is disconnecting the hood latch harness only(picture letter D). If everything turn back normal then you got a bad hood latch. You could replace latch or leave it unplug, it's up to you. Your alarm will work fine with it unplug. hope this helps you.k42282_2.jpg
Dec 13, 2010 | 1998 Honda Accord
I cannot locate the valet switch to disengage the alarm.
    Preparing for the Installation
  1. Step 1 Gather materials. You will need scissors or a knife, crimps, solder material, solder gun, test light, drill, screw bit, screws, tie wrap, double-sided mounting tape and a voltmeter.
  2. Step 2 Read the installation manual that comes with the alarm. Make sure you understand what the instruction manual says. If you purchased the alarm from an automotive store, you can always ask them some basic questions to help you get started.
  3. Step 3 Call the tech support number for manufacturer of the alarm and tell the tech advisor what kind of car you have. Ask what kind of locking system your car uses and what color wire to connect to in order to interface the lock/unlock feature of your alarm,
  4. Step 4 Ask the advisor how to hook up the relay for the door lock feature, what color wire to connect to for the starter disable feature, and how to hook up the relay.
  5. Step 5 Ask how to set up the voltmeter to test the door lock wires.
  6. Step 6 Ask how to access the factory door triggers.
  7. Step 7 Determine where you intend to place the components by referring to the installation manual.
  8. The Installation
  9. Step 1 Mount the siren to a solid metal surface under the hood. Point the horn of the siren down toward the ground so that moisture cannot collect inside it. Drill a hole through a rubber grommet in the firewall of the car and feed the siren's wire through that hole into the passenger compartment of the car.
  10. Step 2 Connect the alarm's power wire directly to the car's battery. Feed the wire through the rubber grommet on the firewall and into the passenger compartment of the car.
  11. Step 3 Put a fuse on the power wire next to the battery. Check the installation manual for the fuse size.
  12. Step 4 Mount the shock sensor as described in the manual.
  13. Step 5 Drill a hole in the dash where you intend to place the LED status indicator. Feed the LED's wire through that hole and place the double-sided mounting tape to the back of the LED and place it over the hole in the dash.
  14. Step 6 Locate the wires that work the car's power door locks.
  15. Step 7 Connect the door-lock relay to the lock/unlock wires and connect the alarm wire to the relay in the manner described by the tech advisor.
  16. Step 8 Using the advice of the tech advisor, locate the wire that works the courtesy light if the alarm has current sensing.
  17. Step 9 Connect the current sensing line from the alarm to the courtesy light wire.
  18. Step 10 Locate the factory door triggers if the alarm does not have current or voltage sensing.
  19. Step 11 Connect the factory door trigger to the alarm.
  20. Step 12 Find the starter wire on the steering column some inches below the starter switch. Cut the line and connect the starter disable relay. Connect the starter disable wire from the alarm to the relay.
  21. Step 13 Mount the valet switch somewhere under the dash.
  22. Step 14 Connect all the wires to the proper inputs and outputs of the alarm module.
  23. Step 15 Mount the module to a sturdy surface under the dash using the drill, screw bit and screws.
  24. Step 16 Use the tie wraps to secure the wires of the harness and stuff it back under the dash.
  25. Step 17 Arm the alarm and test its performance.
Jun 01, 2010 | 1998 Ford Taurus
I would like to find a 98 honda accord wiring diagram.(mt)
http://honda-tech.asterpix.com/cy/2423701/?q=98+Honda+Accord+Wiring+Diagram
browse this site. There's also a couple of forums where the guys will walk u thru the whole process
Feb 06, 2010 | 1991 Peugeot 405
Can I stop my horn from sounding when I lock my 2009 Accord
You might can have the dealer program it not to honk, but its just the way the keyless entry works. I've owned 2 accords--an 06 and 08--and both of them honk the horn when the lock button is pressed twice. Pressing the button once will secure the car and arm the alarm. So once click is all you really need. And no your alarm is not malfunctioning.
Jul 18, 2009 | 2006 Honda Accord
Jan 12, 2009 | ' II' DIY Car Alarm Vehicle Anti-theft...
Vehicle Parts & Accessories Logo
403 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
ashburton
Colin Stickland
Colin Stickland
jamie suver
Level 1 Expert
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
