Question about Garmin zumo 550 GPS Receiver
My garmin zumo 550 gives the following error "failed to initialize bluetooth" please help
When trying to activate the bluetooth I get out the following error "bluetooth failed to initialize" and I can not connect my devices.
  • Arturo Baptista Dec 11, 2012
    Your Question Status Hello Arturo Baptista Thank you for posting the question: "My garmin zumo 550 gives the following error "failed to initialize bluetooth" please help" 24 hours ago. Your questions has been viewed by 15 of our experts but it is still unanswered. Perhaps the question needs further clarification. To help you get an answer to your question please add more details here. Your question will be closed if no additional information is added to it. Thanks for your participation. Thank you! The FixYa Team
    Reinstall system updates and bluetooth but the error persists.
marcelbakker
  • 174 Answers
SOURCE: Import *.gdb route file in Garmin Zumo 550
Import to pc or to garmin device? There is some info in the manual, however you will need an SD card to work with triplogs.
Posted on Jul 23, 2008
SOURCE: connection problem between a nokia n95 8gb and zumo 550
I have recently purchased a Zumo 550 and successfully copied across selected phone book entries from a Nokia N95 without the need to use any additional apps:-
1) Assuming the N95 and Zumo are paired via BlueTooth
2) In N95 Contacts - use 'Mark' / 'Mark All' as necessary to select the contact entries you wish to transfer to the Zumo 550
3) In N95 Contacts - select 'Options' then 'Send Business Card' then 'Via Bluetooth'
4) Select the Zumo 550 device from the list of paired Bluetooth devices
5) Contact data is transferred from N95 phonebook to Zumo 550 phonebook
Interestingly, Garmin don't seem to list the Nokia N95 as being a supported device on their website, but the above process worked for me!!
Posted on Sep 01, 2008
marcelbakker
  • 174 Answers
SOURCE: Garmin Windows Vista Issue
I now this issue, and it's quite easy to work around, right mouse click on the executable and select run as administrator.
Posted on Oct 27, 2008
  • 3 Answers
SOURCE: Garmin Zumo 550 Freezes
If the unit freezes with something on the screen, then the book that came with the unit tells you to push the power button and the + sign button at the same time and this should fix the problem. Good Luck.
Posted on Jul 13, 2009
mindreader
  • 578 Answers
SOURCE: how do i reset my garmin zumo 550
Press and hold Power and + at the same time.
Go to http://www.manualnguide.com/dl/4354/ for more information.
Posted on Nov 22, 2009
When I turn my Garmin 550 on it says loading maps, then goes to the select a local: It's frozen their on United States i push OK and nothing happens can not change the Locale it's frozen I tried...
Hi tkfranks331,
Press the power key and hold it if the screen of your Zumo is frozen. Keep holding the power key while pressing the key that has a plus symbol ("+") on it. This will reset your device and unfreeze the screen. You can also try calibrating the screen by pressing the power key for one full minute.
If this does not work, please follow these steps.
1. Update the internal disk software. Download and install WebUpdater on the computer. Please visit this link to download the WebUpdater.
2. Open WebUpdater on the computer.
3. Connect the Zumo 550 to the computer with its USB cable.
4. WebUpdater will automatically search for updates.
5. Follow the prompts to download any pertinent updates for the Zumo 550.
Hope it helps.
Thank you for using FixYa.
Aug 17, 2011 | Garmin zumo 550 GPS Receiver
I have problems with the touchscreen zumo 550 An example: When you press the A activate the B in all the tabs do the same Is there any way to calibrate the screen;
To (re-) calibrate the touchscreen you must hold the power button for approximately 1 minute when turning it on. Then follow the onscreen instructions.
http://garminzumo.wikispaces.com/Tricks
Jan 23, 2010 | Garmin zumo 550 GPS Receiver
I cannot get audio at all for my garmin zumo 550. all it says onscrean is to connect zumo to holder which i have done or to connect to bluetooth headset.i think i may have a problem with my power lead but...
The 550 relies on the car base for audio as it has no speaker. If the base is not powered up it will not amplify the sound out of the GPS unit, Check the in-line fuse on the power cord, it is usually located in the tip of the cigarette lighter adapter. twist off the tip and this should expose a fuse.
HAve you tried connecting to it with a bluetooth headset, this should work regardless of whether or not it is on the base.
Hope this is of some help.
Ed
Apr 20, 2009 | Garmin zumo 550 GPS Receiver
Can't end Bluetooth phone call with Zumo 550
I have a motorola phone, and it's fine.
I have paired the phone to the zumo, and the phone is set to connect to the zumo automatically.
Check the phone is set up this way, and all should be well.
Hope this helps.
Dec 24, 2008 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 cannot find satellites
I'd remove the battery first, leave it out some time, put it back, fully charge it and use webupdater to see if all is up to date. There is a test menu on the Zumo to see if all works. I will tell you how to get there, only after you have tried the above first!
Jun 16, 2008 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 bluetooth pairnig problem
Have you connected the device to the computer and run webupdater? Mine showed up with a bluetooth firmware upgrade. Bluetooth works fine, however, lost the functionality of the phonebook after the update. Sometimes you win sometimes you loose
Mar 28, 2008 | Garmin zumo 550 GPS Receiver
Touch screen not working properly
I'm not familiar with the Zumo family of GPS from Garmin, but if they are similar enough to the StreetPilot, you should be able to recalibrate the screen. In the StreetPilot series, to recalibrate you turn the unit off. Press and hold the bottom right of the screen and turn the unit on. Keep pressing the screen until the calibration information begins. Try this, see if it works on the Zumos, too.
Mar 11, 2008 | Garmin zumo 550 GPS Receiver
Zumo 550 - Failure of call functionality on Bluetooth
Try the garmin webupdater with the unit connected to the computer to see if your bluetooth firmware is the latest. Beware however, I lost phonebook functionality!
Mar 04, 2008 | Garmin zumo 550 GPS Receiver
Connection problem between a nokia n95 8gb and zumo 550
Feb 15, 2008 | Garmin zumo 550 GPS Receiver
Aug 28, 2007 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 GPS Receiver Logo
186 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
