Question about Infinity BASSLINK Car Subwoofer
Basslink red light on but no sound
Im a tech guy who know the basic so ia have a basslink that stop working the red light is on servo light off but no sound for a second i tought that the speaker blow but i opened the basslink to hceck the speaker and is fine so is something in the motherboard amp so what could be wrong
  • 5 more comments
  • micki108 Jan 13, 2009
    thanks im gonna check that tomorrow cuz i work all day today ill let you know
  • silverspy0 Feb 21, 2009
    Same damn problem, Infinity repair center out here says it's the main board that needs replacing (I'm looking at mine right now, just took it all apart), and that's as much as a new Basslink. This is a horrible product that sounded decent for the year or so that it worked. This does not help Infinity's reputation.
  • danpecor Mar 21, 2009
    Same problem here. Bought unit used, should have listened to it work first. Power light comes on, but no sound. Believe me, I've checked every possible connection including every combination of speaker input and pre-amp (rca jack) inputs. I would like to know if this is a common problem with this unit.
  • Anonymous Apr 10, 2009
    I loved this thing in my Jeep Wrangler for the year or so it worked. No changes were made to my system and it stopped working. I am a electronic technician and know that ... with verified input ....either line level of speaker level ......there is no output. The amp is shot. Was looking to buy another of the same for replacement but not after what I am seeing about all the problems with this thing.
  • derbassspiel
    derbassspiel May 02, 2012
    I had the same problem. Mine turned out to be two fried resistors, numbers R143 and R144. They are 3.3K Ohm, 0.5W, +/- 5% resistors. I identified them because one end of each f them looked corroded and rusted. I checked them with a multimeter, and they had infinite resistance, i.e. were blown. I just got the new resistors at Radioshack and soldered them in. Now, it works fine! Your problem might not be the same as mine, but once you get the amp off to look at the board, just look for things that look wrong and replace them. It's not the most direct way to go about the repair, but when parts cost a couple bucks each, why not at least try your hand at it?
  • alsheensheeh
    alsheensheeh Sep 17, 2012
    haha same as all of you. i just ripped mine apart and found out there is a black spot ont the back of the motherboard. its actually a burnt sodder that says "R141"
  • Morgan Thompson
    Morgan Thompson Apr 13, 2017
    Had the same issue, R143 + R144 were open.
    New Friend:
  • 111 Answers
Check the all power lines and regulator .is any of them overheating?
then check the power amp ic or transistors.
nuwan.
Posted on Jan 13, 2009
Testimonial: "thanks "
SOURCE:
Need schematic diagram infinity basslink subwoofer
Design: The BassLink brings together a 10" subwoofer (treated paper cone, foam surround), a 10" passive radiator (to increase efficiency and limit distortion), and an extremely efficient, specially designed 200-watt Class D amplifier that work as an integrated system. Special circuitry monitors voice coil position to maintain linearity at high power levels, so you hear loud, clear bass.
Enclosure Type and Materials: The enclosure is made of an acoustically inert polymer which is rigid enough to resist flexing and dampens any resonance.
Servo-Control: The servo-control system continually monitors the performance of the speaker and ensures that the amplifier delivers exactly the right amount of power.
Class D Amplifier: This unit has a built-in 200 watt Class D amplifier which is highly efficient and designed specifically for use with the subwoofer and passive radiator combination.
Auto Turn-On Feature: When the speaker level inputs are used, the system will automatically turn on and off with the radio. Note: The auto turn-on feature does not operate when the preamp level inputs are used, unless the remote turn-on lead is connected.
Low-Pass Crossover: The low-pass crossover frequency can be varied from 50Hz to 120Hz for a seamless transition between the output of this unit and that of the other speakers in the vehicle. The crossover has a slope of 12dB per octave.
Bass Boost: The amplifier includes a continuously adjustable bass boost from -6 to +3dB centered at 40Hz.
Phase Switch: Allows you to select normal or reverse for best bass.
Mounting: You will be able to put BassLink in a variety of in-vehicle locations, thanks to its compact size and mounting feet that enable the rigid polymer box to be mounted vertically or horizontally.
Vertical Mounting Dimensions:
Width: 14.625"
Height: 13.375" (including feet)
Depth: 8.675" (10.076" including feet)
Horizontal Mounting Dimensions:
Width: 14.625"
Height: 9.5" (including feet)
Depth: 12.75" (15.1875" including feet)
BassLink LC Remote Level Control
Overview: The BassLink LC allows you to adjust the volume of BassLink powered subwoofer.
Installation: The BassLink LC may be mounted under the dash or may be dismantled and mounted inside the dash for a factory appearance.
Under-dash Mounting: Select a mounting location that allows easy, safe access to the control while driving. The BassLink LC has mounting "ears" to use as a template for drilling pilot holes. Attach screws through the "ears" to secure the BassLink LC to the mounting surface.
In-dash Mounting: Disassemble the BassLink LC by removing the Phillips-head screws on the front, rear, and top panels. Remove the bottom and side panels and disengage the RJ11 connector from the back panel. Choose a mounting location that allows easy, safe access to the control, and provides 1-3/4" clearance behind the mounting surface. Drill a 9/32" hole in the mounting surface. Feed the BassLink LC's potentiometer (with the knob removed) through the hold and use the nut provided to hold the control in place.
Connecting to BassLink: Route the cable behind the dash or other interior panels and under the carpet. Do not route the cable outside the vehicle. Connect the cable on both ends.
Inputs and Controls
Inputs:
Universal Interface: Front and rear, left and right Universal interface speaker-level inputs (for use with the supplied speaker-level input wiring harnesses)
Line Level RCA Inputs: Front and rear, left and right female preamp level inputs
+BATT (+12V): Gold-plated screw terminal, 0.350" wide
REM (remote turn-on): Gold-plated screw terminal, 0.350" wide
GND (ground): Gold-plated screw terminal, 0.350" wide
Fuse: There is an installed 20 Amp fuse
Remote Gain Control: Phone type jack for included remote gain control
Controls:
Gain Control: Rotary control that sets gain (variable from 250mV to 4V)
Crossover Control: Rotary control that sets the low-pass crossover point (variable from 50 to 120Hz)
Bass Boost Control: Rotary control that sets bass boost level (variable from -6 to +3dB, centered at 40Hz)
Phase Switch: Selects normal or reverse phase (0 or 180 degrees)
Power LED: The power LED glows red when the BassLink is on
Servo LED: The Servo LED glows green when the servo circuit has determined that the woofer has reached maximum excursion and power to the woofer has been modified to provide maximum performance. The LED should light momentarily during high-level bass transients. Note: Avoid adjustments that cause the LED to remain lit for an extended period of time
Thanks
Apr 01, 2012 | Infinity Bass Link Subwoofer Car Audio...
Basslink works for a few seconds after i turn on the stereo, then it fades away. The servo light is always on even when i disconnect the input line and turn the knobs to the min level. What could be wrong?
Hello, check the +15v and -15v on the Switching Power Supply Control board. If one or both are missing, it is probably Q117 for +15v and Q118 for -15v. If one is missing the limit comparator will rail to one side and cause the auto variable volume control to trip the servo protection.
Oct 02, 2010 | Infinity BASSLINK Car Subwoofer
Basslink has no output, but Power LED and Servo LED always on.
One or more of the DC to DC outputs might be bad. Check the
/- 54v on the main PCB and the /-15v on the switching controller PCB.
Losing one side of the 15v will cause the limit comparator to rail and force the servo protection, even with no input signal.
Apr 02, 2010 | Infinity BASSLINK Car Subwoofer
Is the light on the infinity basslink suppose to be red or green
Hello jmw3031,
The Basslink should have both a red power LED and a green servo LED. The red LED should be on when power is applied. The green servo LED should only come on during high-level bass transients. Turn the gain down slightly if it stays on for extended periods.
Hope this helps.
Jul 15, 2009 | Infinity BASSLINK Car Subwoofer
Red light comes on and then slowly goes out. No output
For some reason you are not getting constant power to the system. What gauge power/ground are you running? Describe your system to me and we'll see what I can do to help.
Jul 16, 2008 | Infinity BASSLINK Car Subwoofer
Basslink Stoped working after a month ** sound ** red LED
check all your power fuses and insure you havec power where it is supose to be. maybe you have blown a fuse.
Mar 09, 2008 | Infinity BASSLINK Car Subwoofer
Servo light off but no bass
you must have lost power to your servo check all fuses and insure you have voltage up to the fuse
Feb 24, 2008 | Infinity BASSLINK Car Subwoofer
Power LED lit, Servo LED lit as well, no output
check the power cables on the amp and the inputs.isome time when ground cable disconnect the lioghts will light up any way. depending on the way ur vehicle is ground ed .toyota chssis r usually posite un like the norm which is neg.rating please
Jan 21, 2008 | Infinity BASSLINK Car Subwoofer
Basslink servo light constant on
defect age,short worn its time through had the same thing happen to mine,A SUGGESTION PUT A 25 AMP FUSE,AND PULL IN AND OUT THE GAIN TUG IT,IT SOMETIMES STICKS AND SHORTS YOUR UNIT OUT,GOOD LUCK
Feb 23, 2007 | Infinity BASSLINK Car Subwoofer
Open Questions:
See all Infinity BASSLINK Car Subwoofer Questions
Infinity BASSLINK Car Subwoofer Logo
2,512 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Mark Skinner
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
