Question about Toshiba Televison & Video
When I turn on my rear projection tv,the color will float & the picture will shake side ways. My tv is a toshiba 50h81 model ,also it is a HDTV as well .
When the tv warms up after 15 minutes or so , the picture is good.
  • 26 Answers
It's capacitors on the three line board. difficult to replace. I would recommend taking it to A professional. It will get worse over time.
Posted on Dec 10, 2012
  • Chris tuck Dec 11, 2012
    Is there parts still out there to fix the problem or what? Where are the boards located at on the tv?
  • 51 Answers
SOURCE: blue color is off and bowed at bottom
Needs the 2 convergence amplifiers replaced and then convergence alignment carried out(Could be pricy)
Posted on Dec 04, 2009
ctf1800
  • 4402 Answers
SOURCE: Toshiba 50h81 turn it self off then back on
Did you check the supply fuses to the convergence ICs? Did you check the output resistors
then i would start by replace the convergence ic first.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 08, 2008
  • 1694 Answers
SOURCE: 57h82 toshiba projection tv
Hyper board bad = No longer available part # 23148024 PTS
rebuild only...send core in........57H82..............................T.
Part # is specific to model !....
Posted on Apr 25, 2008
Mr Alexx Sir
  • 12 Answers
SOURCE: TOSHIBA 52 INCH PROJECTION TV - 2003 MODEL
Hi olchap
your tv is projection, maby the heat is causing the bulbs to brighten and dim, you should try to keep the room its in fairly cold or try and have the bulbs replaced to ones that are not as strong,
hope that helps a little ^-^
Posted on Jul 29, 2008
  • 145 Answers
SOURCE: No image on sony rear projection tv (model KP-53V35) for 20 minut
sony has a circuit than balances the 3 crt's. it needs a screen adjustment which is located in the front of tv behind speaker grill. easy repair
Posted on Nov 10, 2009
When I turn on my rear projection tv & the tv is cold the color will float,the picture will shake side ways for about 15 minutes.what can I do to fix the proble?
You did not provide a model so I am not sure of the type of set u have. Wheather it be CRT, LCD, DLP or LED. My 1st guess regarding "color float" is possably the convergence board/section of your set. And the warming up issue could be the result of cold solder connections and/or faulty caps on 1 or more circuit boards. Search your model number through the internet for clues.
Dec 08, 2012 | Toshiba Televison & Video
Focus error 50h81 toshiba red line problem
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows or have 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to fix it.To solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 01, 2011 | Toshiba 50H81 50" Rear Projection...
My rca toshiba 50 inch projection tv is showing a 3d color curve
Need the model number to help as I am not sure of you have a RCA or a Toshiba
Dec 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Blue color is off and bowed at bottom
Dec 04, 2009 | Toshiba 50H81 50" Rear Projection...
Toshiba 50h81 has power but no picture or audio
is your high voltage still comming up?
ok turning up screen controls with tv on. what do you see?
Apr 11, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81 manual convergence
are you sure it's yoke? these are know for bad convergence amp ic's
other wise it's a screw and glue holding the yoke in place loose the screw and try to break the glue with out breaking the plastic on the yoke, the other thing you can do is adjust the magnets which have tabs on the yoke. i would mark the position's of everything on the tube with a sharpie so you can get it back to start.
Convergence amp ic bad
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81
convergence amp ic are bad
Jan 16, 2008 | Toshiba 50H81 50" Rear Projection...
Wavy, jumpy picture, ghosts, occasional color loss/change---you name it!
Dec 12, 2007 | Toshiba 50H81 50" Rear Projection...
Televison & Video Logo
109 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
