Question about Frigidaire Refrigerators
Electrolux ice maker will not rotate - Frigidaire Refrigerators
  • Official Brand Answer
  • 4,342 Answers
Hello - In order for me to better pinpoint you the correct information, may you please provide me the exact model number?
Posted on Dec 14, 2012
aborcass
  • 2651 Answers
SOURCE: ice maker has ice in lower back part of ice maker, rotation stopd
you say ice in back of ice maker??? only the rear 2-3 cubes are filled??? adn the front 5 or so are empty??? then yes its possible low water pressure from a faulty filter can be an issue, shoudl be replaced at least every year. so you cant go wrong by changing it , at least rule it out!
Posted on Nov 25, 2008
Maytag317
  • 1136 Answers
SOURCE: ice maker not working; straining to rotate
Hi, I looked up your model and I see no filter listed. Does your owners manual suggest there is a filter?
Let me know please.
Vic
Posted on May 10, 2009
Sea Breeze
  • 4654 Answers
SOURCE: I have the samsung rs2577sl. the ice maker cube
Your model has the twist tray style icemaker. The part number for you front section that contains the motor assembly is DA97-00258E Ice Maker Assembly. You can try by taking it out and seeing if the tray will return to the home position but stopping there make me question if the thermal fuse in wiring harness may have blown. We may need to test that wire also to see if the thermal fuse is still good, I will leave you some of the links and ready to help when you need me, Thanks, Sea Breeze
Posted on Apr 21, 2010
  • 122 Answers
SOURCE: How to get ice make
call electrolux at 1-877-435-3287
Posted on Aug 22, 2010
  • 1891 Answers
SOURCE: French Door with bottom freezer Electrolux ice
sounds like the drive in icemker head is bad and not turning the timing wheel . the timing wheel controls the harvest and the water comming in ect . best to replace the icemker with ther kit . come with instructions . mm hope this helps . if more info needed i need the model # and ser of your unit .. feed back pls ..
Posted on Dec 11, 2010
Whirlpool bottom freezer ice maker will only make ice if I pull and then replace the ice container, why?
The ice maker works off a timer that controls the discharge of ice, water fill, etc. Right before the tray discharges ice it is heated slightly so the ice is just slippery enough to discharge the ice. Unfortunately, now and then (for us) a chunk of ice remains in the tray. This chunk prevents the blades from rotating and eventually you have a mass of new ice with the blades in the wrong position. The blades have to be in a certain position for the heater to kick in. You are stuck with cracking up the ice stuck in the tray to get the blades to rotate again. We have an Electrolux ice maker but this problem occurs periodically. The root of the problem is it's failure to heat up the ice tray adequately to discharge ALL the ice. One thing to remember is that next time this happens you have to manually break up the ice in the tray and push the timer advance button until the 2 set of blades are fully closed (hidden) and at 90 degrees. From that point on at least the ice maker can start making more ice.
Aug 23, 2014 | Refrigerators
Ice maker leaking
Hello Friend, thank you for your inquiry! I understand that water is
leaking from the ice maker of your Electrolux refrigerator; however please help me understand if you are referring to the ice/water dispenser (filter) or actual icemaker? With this material I can better address the issue at hand. Thank you! - Z
Jul 14, 2014 | Electrolux Refrigerators
Electrolux ice maker won't stop making ice
The bin full detector is not working--replace it.
May 21, 2014 | Electrolux 15 Under-Counter Ice Maker...
Electrolux ice maker bucket stuck
Probably the ice maker leaking caused by ice maker itself or faulty water valve. I would think you would have to let Ice thaw that's most likely holding bucket from coming out and then replace Ice Maker or water valve or both.
Aug 23, 2017 | Electrolux Refrigerators
Fridge makes knocking sound. it sounds like it is coming from the ice maker. Is this a common problem and how do I fix it?
Ice maker could be stuck with frozen ice on the rotator look over and if you see some turn ice maker off and use hairdryer to free up
Nov 19, 2010 | Electrolux EI23BC56IS (226 cu ft) Bottom...
Electrolux EW28BS71IS ice maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
sfgs
Jun 24, 2010 | Electrolux EW28BS71IS (278 cu ft) Bottom...
Electrolux will not make ice. the water will dispense
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 17, 2009 | Electrolux EW23CS65SS Stainless Steel Side...
I do not know how to remove the bowl. Just opened it from the box and can't get the bowl out. What is the trick?
This ice cream maker comes with 2 bowls. One bowl is fixed in the unit and cannot be removed. The second removable bowl should have a handle on it. To move the motor assembly rotate it clockwise and slide the assembly backwards. This should allow access to the bowl.
Detailed drawings can be seen here:
http://www.healthgoods.com/Shopping/Appliances/Nemox_Chef_2200_Gelato_Ice_Cream_Maker.asp
Dec 29, 2008 | Electrolux Gelato Chef 2500 5 Quart Ice...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
