Question about Denon AVR-1804 Receiver
How to connect Denon avr 1804 connecting to roku hd
How to connect to roku hd
  • Dave Dec 11, 2012
    I do not see the Roku setup screen after connecting the composite cables to a second VCR. Looking for guidance on getting the Roku HD unit to work with my Denon 1804
I connected by Roku to a Denon 1804 Receiver this way:- I plugged the cable that came with the Roku into VCR2 input jack of the Denon. (I used VCR2 because it was available).- Using the remote from the Denon, I made sure the slide switch was on "Audio." (See page 20 of Denon Manual).- I pressed pressed the System Setup button- *System Setup appears in display of Denon- Using the cursor buttons I scrolled to menu Digital in Assignment- I set Menu item 16 Coaxial to VCR2 since that was the input jack I used for the Roku. - After making the selection press the CH Select Enter button to save- To exit the System Setup press the System Setup button again- When using the Roku, select the input source as VCR2 (or whatever jack you used). You should now have sound through the Denon.The most important step is to read the Denon manual starting on page 20
Posted on Jan 06, 2013
4 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Denon AVR 1804
You need to get the manual and do some reading first. I couldn't find the AVR-1804 but the AVR-1803 is avaiable. It should be close enough to get you through connection and setup.
Register with retrevo.com and download it for free.
Posted on Feb 23, 2010
  • 5 Answers
SOURCE: Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Posted on Mar 09, 2010
  • 5 Answers
SOURCE: Flickering video with Denon AVR 1910
I had the same issue with my Denon AVR-1908.....It turned out to be the cable box, not the receiver. I would suggest you unplug your cable box, remove and reseat the cable card,HDMI cables, and finally the cable line itself. Make sure the wires are not frayed or otherwise pinched.
Good luck....
A new Roku HD does not find any wireless sites but another Roku in the same place finds all sites. Putting the older Roku in the same place works fine and connects to my wireless network without...
No way to fix that sadly, contact Roku and have them replace it for you. If you could fix it, you'd have to open it up which would void most warranties.
Apr 02, 2015 | Computers & Internet
Unable to connect to roku screen is a graphic picture of a winter scene
Do you have an Internet connection? Needs to be close to router to receive WiFi signal. Would have had to login in to service account on Roku device to get NetFlixs
Dec 16, 2014 | Roku HD Player (N1100)
How do I start the roku. Indeed to put in the code
The roku is running when you connect the power cord. There is no on or off switch. If you cannot see a picture on your TV, make sure you have selected the port the roku is connected to.
Oct 29, 2014 | Roku LT 2450D Streaming Media Reciever -...
How to hook up
You do not need a smart tv in order to use the roku. Basically the roku device makes your TV Smart. The basic connection is just an hdmi cable, and some type of internet connection. Depending on the Roku you have, you can either go with the built in wireless, or you can hard wire the internet. The same type of cable that you would use to hook up a computer to your router.
Aug 02, 2014 | Roku Televison & Video
My roku device will not connect with facebook
my roku device will not connect with facebook
Jan 14, 2013 | Roku HD Player (N1100)
New router now roku box does not work
Are other devices able to connect? If not, then you're probably entering an incorrect password or you're trying to connect to the wrong network.
Hope this helps
Randy
Oct 10, 2012 | Roku HD Player (N1100)
Can't find roku.com/link to enter code
I CAN NOT GET INTO MY ACCOUNT IT WANT ACCEPT MY PASSWORD
Aug 23, 2012 | Roku 2 HD
ROKU can't connect to local area network.
Have you got past the point where the Roku updates itself? If not, connect the Roku to the router via ethernet to get to that point. Make sure you can watch something on the Roku. Then try connecting wirelessly.
2. If you are still having trouble, connect the Roku directly to the modem. (this is temporary). If you can get the Roku to work, the problem is with your router and not the Roku.
3. Restore all the connections - it would be a good idea to reboot everything: Let the modem come back up, then the router, then the Roku.
4. Check for firmware updates for your router.
5. If you are still having trouble, post the make and model number of your router.
Feb 05, 2011 | Roku HD Player (N1100)
How do you connect a netgrear wireless-N 150 router WNR1000v3 to a Roku.
Hi
Which model of Roku you are having?
  • Roku SD (model N1050)
  • Roku HD (models N1000, N1100)
  • Roku HD-XR (model N1101)
  • Sep 22, 2010 | Computers & Internet
    Olevia 237t No Audio or Video on HD Channels
    Try to connect the ROKU player to the television directly
    Make sure that the internet connection to the player is from your router
    Use your television remote to select the proper input to your television
    Try this and check if it works.
    It should work
    Oct 23, 2009 | Olevia 237T 37 in. LCD TV
    Denon AVR-1804 Receiver Logo
    383 people viewed this question
    Top Denon Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Electro Med Services...
    Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
