Question about Plumbing
Kinetico changing filters
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 42 Answers
I believe they screw in and out.
Posted on Dec 18, 2012
We just changed out filters in out K5 unit and turned on the water and the faucet and the water is running very slowly. What can we do to get it running strong again
Your manual is here:
https://www.kinetico.com/media/2329/13034j_manual_owners_k5_1216.pdf
Did you follow the filter change procedures completely and correctly including depressurization? Did you change the pre-filter - probably clogged? Did you open up the faucet fully?
OK. Now be patient! Wait for the tank to fill. With a maximum filtration rate of 3 gal per hour, it will take 5 min to produce the first quart.
Aug 23, 2017 | Plumbing
What could be the problem causing the rotten egg smell in the water? We have changed the anode rod.shocked the well.no sulfur. We have kinetico softener. Use iron out salt. Water heater 2 yrs old.
Some water softeners you can increase the back wash time on the unit to clear out a smell or bad taste , rotten egg smell can be sulfur. You may need a well flush but seek a well company on that for there advice as its not cheap .
May 16, 2017 | Water Water Heaters
In inches what should the float be set on kinetico model 60 with adjuster tube set on h
Water level should be about 1/2" below top of overflow pipe.
Aug 13, 2014 | Home
Kinetico reverse osmosis water flowing very slow
I am guessing you have checked to make sure the water flow into the osmosis system to make sure it is at proper pressure? If so is this a whole house system or just for the kitchen? If it is a whole house do you have the same problems in other parts of the house?
Jan 21, 2013 | Refrigerators
MY KINETICO QUAD 50 QUIT MAKING SOFT WATER. LOOKING ON HOW TO CHANGE OUT AND OBTAIN TO REPLACE
Hi Dale,
I worked at a Kinetico dealership for 6 years. I am very familiar with the quad 50. Unfortunately, Kinetico can only be serviced by a kinetico dealership, or someone who has the parts and the know how. They can be difficult to diagnose and fix if you are not familiar with them. You say you want to change it out and replace it ? You might be better taking it in to a kinetico dealership and having it serviced. They are worth it. If not, you can go on the internet and shop for a water softener. www.ohiopurewater.com or www.discountwatersofteners.com
May 04, 2011 | Plumbing
Kinetico water filter leak
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} What you are describing sounds like a quick connect fitting. I have included a link below to a video that explains how this type of fitting works. If you are using plastic tubing with these fittings you may be able to remove the tubing from the fitting and cut back about ½” from the end of the tubing and reinsert it into the fitting. Do not cut the tubing with scissors, use a tubing cutter or razor blade knife (see video). If that doesn’t solve the leak and you find that you need to replace any fittings we have a complete selection located here: http://www.freshwatersystems.com/c-276-fittings-valves-tubing.aspx
Geoff D., CWS-I - WQA Certified Water Specialist
Fresh Water Systems, Inc - http://www.freshwatersystems.com 1.877.335.3339
Mar 16, 2010 | General Electric Profile Smartwater Ultra...
Kinetico Water Softening Unit has brine tank drainage problem
This sounds like the resin cylinder is perforated or connections at the top are leaking. The brine tank should only have a little water in the bottom - if it is full of water (maybe even up to the overflow?) then you will need to replace the resin cylinder or fix a leaky connection to it.
Is the water in the brine tank 'rusty'?
Feb 11, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Water softner dirty water
you might also want to check into the piping in your house is it gavinized, cpvc or copper, this could also make a diffrence, you could also be pulling mud from the bottom of your well, the anoid rod in the water heater will keep you from seeing this in the hot side lines,suggest to have a test done on the water take a jar with a lid and take it to your local plumbing supply house and see if they can't have it tested then you will have all your answers, the test i'm in md. it cost us aprox 40.00 to have the complete water test,
May 27, 2009 | Water Heaters
Water softener doesn't work properly
Check for iron content of the water in your area. Excessive iron will clog the zeolite beads in your softener and reduce its life. You can try increasing the backwash and rinse cycles to see if it helps. You can also get an iron pre-filter for a softener. I am assuming you have either a private well or a municipal well.
Mar 17, 2009 | Kitchen Appliances - Others
Replacing charcoal in my kinetico water softner
On the top of the unti there is a plastic site glass it also will have a phillips screwdriver slot when you insert the screw driver you have to push down and then turn it clockwise until you hear it kick in the let off let it run the entire cycle then run a faucet to make sure everything is clear and clean
Nov 11, 2008 | Plumbing
Plumbing Logo
136 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
