Question about Toshiba Televison & Video
Toshiba tv won't stop turning on and off
Turns on and off
    New Friend:
  • 3 Answers
I am not an expert but you could try unplugging it, wait a minute and plug it in again.
Posted on Dec 08, 2012
Toshiba tv won't turn on
Check and replace damaged component/s in its main power supply regulator circuit.
Feb 24, 2013 | Toshiba 36A40 36" TV
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Toshiba 32AV502R won't turn on even though green light goes on
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 30, 2012 | Toshiba 32AV502R LCD TV
My toshiba tv model 32yt56b2 turns itself on and off continuously after i push the on button on the tv until i press the off button again
Check the microswitches inside the front panel control. You have to take the front panel control printed circuit board out from the TV. Repalce all the microswitches there at one time. It won't cost mor, and can be bought from most of the electronic spare part selling shops at your town.
May 17, 2012 | Televison & Video
My toshiba RC-3910 tv turns on but 10 mins later it turns off and it wont turn back on why
hello!
it seems, like the problem of your TV is the power supply module, particularly 12v power supply I.C. chip.STRW6735 or similar. I've replaced few lately with similar problem TV. It might have a few bad electrolytic capacitors on the board, as well. Solution: if you are possess electronics technician skills and have all the necessary equipment and parts , you may do the job yourself. Otherwise, look for replacement power supply board, preferably at used boards distributors(shopjimmy.com or similar). I won't recommend to buy used on e-bay, unless it has been rebuilt. Or, remove the board and take it to local TV repair shop for rebuilding. This way you may save a few bucks.
Good luck,
Alex.
Mar 06, 2012 | Televison & Video
Won''t turn on the tv also cannot change the settings manually on the tv
Thanks for stopping by.
What is the model number and manufacturer of the TV you are trying to control with the CT-90157 remote?
Not all IR codes are programmed into all remotes.
Sep 26, 2011 | Toshiba CT-90157 Remote Control
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
