Question about Keurig B60 Coffee Maker
It says not ready then when it is, it shuts off
  • 1,511 Answers
Reset the lever and make positive contact.
Posted on Feb 06, 2014
Tip
Speed up vista !!1
  1. 1. Shut Down Remote Differential Compression
  2. Remote Differential Compression checks the changes of your files over a network to move them with as little bandwidth as possible instead of transferring an entire file that has previously been moved. With in constantly checking for file changes, this service will greatly slow system performance.
    To shut down this service:
  3. Control Panel
  • Change to Classic View
  • Choose Program Features
  • Select Turn Windows Features On And Off
  • Uncheck Remote Differential Compression
    1. 2. Shut Down Windows Search Indexing
    2. Windows Vista search indexing is constantly checking the files on your system to make their information available for quick searching. This is helpful, but can severely slow system performance.
      To shut down constant indexing:
    3. Select Start then Computer
    • Right Click your C: Drive
    • General Tab, Uncheck Index this drive for faster searching
    • On the next dialog box, Choose Include subfolders and files
    1. 3. Add at least a 2GB USB Flash drive to take advantage of Windows Ready Boost
    2. Ready Boost uses a USB flash drive to provide quick access memory for the operating system. The Ready Boost system can greatly improve system speed.
      To set it up:
    3. Plug in a Ready Boost Compatible USB Flash Drive
    • Select Start then Computer
    • Right Click Your USB Drive in My Computer
    • Choose the Ready Boost Tab
    • Click Use this device
    • Choose as much space as you can free up for RAM usage vs. Storage
  • on Jan 29, 2010 | Computers & Internet
    My Lexus safety and emission test said Not-Ready. I was told to drive it. but it shuts off? what do I do?
    You need to find out why it shuts off. Immediately as it fails test for spark at plugs. OK? next use fuel pressure gauge to see if pressure drops just before it dies. No spark means bad coil/ignition module, crank/cam sensor. Bad fuel pressure = bad pump, filter, relay, regulator.
    Jun 22, 2015 | 2001 Lexus ES 300
    At smog shop guy says 4 problems saying not ready go drive car for 50 miles.did that and still saying not ready
    The car has to go through a certain number of driving cycles (start, drive, shut down) after the computer has been reset or the battery disconnected for an extended period of time before it will be ready, sometimes 50 or more depending on the vehicle. You could drive 1,000 miles and it wouldn't make a difference. Take your car on multiple short trips, around 15-20 minutes each, letting it sit for a while in between. Just starting and shutting down the car won't count either.
    Mar 08, 2011 | 2002 Ford Crown Victoria
    Machine shuts off and says NOT READY. It will not work again until it is unplugged for a minute. Plug it back in, water heats and READY. It is not set to shut off. It shuts off soon after using for no...
    Sorry to read about your problem, I hope this helps you out.
    you can contact Keurig at 1-866-901-2739 or Keurig.com
    You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
    I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
    dad
    asd
    Dec 17, 2010 | Keurig Platinum B70 Coffee Maker
    My Akai PTH5498 54 in. Rear Projection hdtv-ready Television power shuts off intermittently. Sometime after only a few minutes sometimes after an hour or so.
    There could be number of problems but most likely its the horizontal chip that is heating up and failing. If you are a tech feel the chip after the set shuts of it's normal for it to get hot but not extremly hot. If it is extremly hot it is your problem.
    Jun 21, 2010 | Akai PTH5498 54" Rear Projection...
    How does the ready light work on the toasymaster waffle baker
    Depending on what you have it should turn green when ready to cook, ten the light shuts off when you put the waffle mix in then when waffles are down it turns green again
    Feb 07, 2009 | Toastmaster Kitchen Appliances - Others
    SANYO PLV-70 - powers up for approx 5 secounds and then turns of
    we had this problem and it ended up being that one of the fans under the lens assembly was not working, causing the system to shut down when it tested it at startup
    Dec 11, 2008 | Sanyo PLV 70 Multimedia Projector
    Keurig B60 Coffee Maker Logo
    70 people viewed this question
    Top Keurig Coffee Makers & Espresso Machines Experts
    Lisa
    Lisa
    Jason
    Oloyede Monsuru
    Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
