Question about Garden
My question was about well pump not a mower
My well pump is failing in keeping the presure of the water up so there for l have to be bleeding over and over again to keep the water presure up but not working lwant to know if it might be the jet because l didn,t change it when l put in new pipes
    Problem Solver:
  • 7 Answers
Check your pressure switch. Sometimes the contacts (points) can be lightly sanded with emery cloth/board, or even the strike plate on a book of matches. That is a temporary fix to get through for a short time. If that doesn't work, a pressure switch is pretty cheap, under $25, find at hardware or home improvement store, (pump service costs over $100) and can be replaced easily just remember to TURN OFF ELECTRIC to the pump before replacing the switch. Failing that, sometimes pressure tanks fail, that's not so cheap. Hope this helps, can't help with your mower! Though I do know mowers.
Posted on Dec 09, 2012
Water pump for the house keeps re-cycling, without using water
IS THE TANK WATER LOGGED? THERE HAS TO BE SO MUCH AIR IN THE TANK TO KEEP PRESURE.
Nov 28, 2013 | Goulds Pumps J and JS Series Pump nozzle...
Engine keeps over heating 1150D
IY COULD BE YOUR WATER PUMP THAT IS WHAT I WOULD CHECK IF THERE IS PRESURE IN THE RADIATOR AND IS PUSSING OUT WATER IT COULD BE A HEAD
Jan 11, 2013 | Garden
I have a 2004 dodge ram 5.7 liter . O have difficulty starting my truck. Some times it starts fine but other rimes I have to pump the gas and wen it starts a small amount of smoke comes out.truck runs...
I have seen two different problems with symptoms like this. 1. A leaking injector. If one of the injectors is leaking a small amount through the pintle on the end of the injector it will bleed the fuel system presure off and dribble fuel into the cylinder, fouling that cylinder. When you try to start it the fuel that has pooled into the manifold will create smoke when it does start. And since the fuel pressure has bleed off to zero PSI in the fuel supply lines it will need time for the fuel pump to recover the system up to normal operating presure. Presure testing (bench test) of the injectors is needed to verify this. 2. A bad fuel pump, relief valve, or bleed-back check valve will bleed the fuel system presure off while it is sitting. To find out if this may be the problem a fuel presure guage set needs to be installed and then run the engine, verify the operating presure is normal, and then shut the engine down and watch the fuel pressure for exessive drop.
The leaking injector is more apt to create the smoke when it fires up, but both can cause this. I would start with check #2 first. Of course there are many other things that can cause symtoms like this but these 2 are the most likely causes.
Hope this helps, if you have any further questions just ask!
Mar 31, 2011 | 2004 Dodge Ram 1500
Power steering pump pushing fluid back out when you cut off engine bleed it 4 times still does it . flushed lines bleed it again still pushing fluid out can you help me
the pump should have a check valve on the presure side causing the fluid to go through the rack to the return line if this is faulty the high presure in the system will push back when engine is turned off.
Mar 08, 2011 | 1999 Ford Taurus
Cant bleed clutch changed both cylinders still no clutch
does the slave cylinder have a bleeder? it should. auto parts stores sell hand-operated vacuum pumps for bleeding brakes. i have used mine to pull fluid through clutch hydraulics to get enough pressure to commence the regular bleeding process. hope this helps.
Nov 10, 2010 | 1988 Chevrolet K2500
How to get front brake pressure after changing master cylinder, bleeding didnt help or maybe im not doing it right
vacuum bleeding is best for these brakes. To do it without a vacuum pump you must pull the handle very slowly and pause about three seconds between handle pulls to allow fluid to refill the piston chamber.
Mar 12, 2010 | 2001 Suzuki GSX-R 1000
Circulating pump shutdown piolet lite shut off on boiler
It sounds like you have a circulation problem. The bleed off valve should only open when you have a presure problem (nonexistent on the open system of a pool) or when you have a over herating problem witch will shut down your pilot also. Check your heater by-pass valve. (A valve in an "H" on the inlet and outlet of the heater) This should be 80-90% closed to force water through the heater. If not this the standered; check the baskets, clean the filter and make suree there is enough water to keep the pump primed. I hope this helps, if not send more info on what is going on.Good luck.
Nov 05, 2009 | Lochinvar ENERGYRITE 400K BTU PROPANE GAS...
Trouble Bleeding Break Line
you need to hold in the metering valve.when you bleed the front brakes.long as the valve closed off you wont be able to bleed front brakes.better to get extra help.hard to bleed by your self .
Apr 20, 2009 | 1988 Oldsmobile Delta 88
Back disk brakes will not bleed
because ur letting air back in the way ur doing it fill reservoir with brake fluid this might b easier with u and a partner pump brake and hold-while holding open brake bleeder let handle squeeze in dont release keep squeezed in now tighten bleeder and pump the brake continue bleeding till brake is normal about 5 times
Apr 07, 2009 | 2004 Factory bike Desert YR 250
Reservoir
Do not overfill your reservoir tank!
Scheck see if your fan is running regularly and strong. If it's not, then cooling won't happen and it will shoot water every time.
Water pumps can also cause such problems in when they fail.
Feb 19, 2008 | Thermaltake Liquid Cooling System Water...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
