SOURCE: TV won't stay on. Green & Red light timer-lamp (Green) stand by/temp (red) flash.
Most likely needs a new lamp. Easily done yourself.
SOURCE: when i turn on my samsung 62
Hi.The ballast may be defective if you hear constant clicking sounds after you've pressed the power button.
If there are no clicking sounds after you press the power button(3-5 clicks every 2-3 seconds), this will confirm optimal ballast performance and, it will also confirm a major issue that concerns the Power distribution board. There are several weak or damaged components on the board that have failed.
The replacement of the power board is recommended in this case.
SOURCE: tv turns on & all panel lights are off,
The projection lamp is dead,replaced the lamp.No,labors u could do it ur self.The lamp about $100-150.
SOURCE: HLR6167WAX/XAA samsung tv wont turn on i
Tv also have a colors wheel.Now u turn the tv on,u hear squiling,motor or whinning noises?Yes,the colors wheel is dead,replaced the colors wheel.The tv will,work agian.
SOURCE: I replaced the lamp on my Samsung HLS5086WX/XAA
To bring up the service menu, turn your TV off. On your Samsung TV remote, press Mute 1 8 2 Power. This WILL invoke 'service mode' and invoking this WILL reset all your custom picture and source name settings. I don't know the specific menu to find the lamp reset option, but I believe it is in the first menu context.
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE
REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
