Question about ASUS G1S-A1 Notebook
Toshiba laptop reboots when on AC Power
Hi, I have a 6month old Toshib Equium L40-156 laptop running Vista Home Premium. Whenever I shut the laptop down without the AC cable connected (just running on the battery) everything shuts down fine however, when I try shutting vista down while on AC power, the laptop shuts down correctly and the power light goes off but after apprx 3 seconds the power light comes back on and the laptop starts up again.
I tried installing SP1 to see if that would fix the problems but it has not. I have also check the power button commands and all are set to shut down the laptop. In addition, I have also unchecked the automatic restart option in the 'Startup & Recovery' section but nothing has workied.
Thanks in advance.
Dave I have the exact same issue, runnning Vista 32bit. I tried messing with the BIOS and power management settings, but nothing has worked. I had a power surge before this problem began so that may explain things, but I have no way to verify if it is a hard or software issue.
I have the same problem with my Toshiba too, prima facie, it looks like Toshiba and Vista don't make a good combo. I suspected this to be a pure hardware problem, but was disproven when I booted in safe mode. It does not have any problems with the AC Power on in Safe mode.
Posted on Dec 19, 2010
Gateway MT6707 shutdown problem
Open the Control Panel, select Power Options, select High Performance, select Change Plan Settings, Under Plugged In, set time to Turn Off Display, set Put the Computer to Sleep to Never, select Change Advanced Power Settings, scroll through the settings , click on the + at Power buttons and Lid, set to shut down, Sleep and Hibernate to Never, adjust the rest to your preference. When you are not using the Laptop ALWAYS shut down and unplug to prevent damage due to power surges.
Apr 03, 2013 | Gateway Computers & Internet
Toshiba external drive won't instal on Windows 7 Home Premium
Will the external drive work on another computer? Has the external drive been dropped, bumped, jarred? If it works on another computer, shut down the Win7 laptop, unplug, remove battery, remove the USB external plug, plug into AC, reboot, when it is finished, plug in USB.
Jan 13, 2013 | Computers & Internet
How do i test the power button on a toshiba equium l40 laptop
OpenControl Panel, Power settings, Advanced Power settings, change SLEEP to Never, Hibernate to never. Shut down and unplug, if you use mostly on AC, remove battery, your laptop when not in use. It will last longer, if there is a power surge not be damaged, and a reboot every day resets the computer.
Dec 26, 2012 | Computers & Internet
My toshiba laptop windows vista will not start.when u nturn it on it goes straight to a back screen..
  1. Check ur powercord & adapter.
  2. If its working then check the battery, reseat the battery & check.
  3. If available then check with another battery
  4. If no, then remove the battery & switch on the PC in AC mode.
  5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
  6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
ALL THE BEST
Aug 20, 2010 | Compaq Presario Notebook
About product key
hi this product key will not work with the windows 7 , the product key that is under the laptop is for vista, that will not work you will have to ask your friend for the key they used for the windows 7 CD you have borrowed...
Jul 04, 2010 | Toshiba Computers & Internet
Frecquent shut downs on both computer s with vista home premium
check your ac power voltage input maybe low. chek the cpu fan. scan all your pc virus causing pc to reboot by it self.
Jun 03, 2009 | Dell Inspiron 530 Desktop Computer
Toshiba a100 freezes
check the power adaptor
give a check to your battery also
instead of doing it urself i suggest to show it to a service person
Nov 23, 2008 | Toshiba Satellite A100-S8111TD Notebook
Equium Laptop Headphones Not Working
The jack might be disconnected from the mobo,or it's simply broken or the headphones don't touch the contact metal properly
Oct 29, 2008 | Toshiba Computers & Internet
Dimage dual scan 4
Use VueScan instead of the Minolta software. A free trial is available so you can test it before you commit to buying it. Available for Windows Vista.
http://www.hamrick.com
Mar 29, 2008 | Konica Minolta Dimage Scan Dual IV Film...
ASUS G1S-A1 Notebook Logo
602 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
