Question about Polaroid T1455 14 MP Digital Camera Violet
When i switch on my camera, the lens can not capture anything. The LCD display is black as if something has covered the lens
  • Polaroid Master
  • 4,738 Answers
This might be a stuck shutter. Has the camera been sitting unused for a long time. If so, see this link for some troubleshooting steps that may help.
Posted on Dec 09, 2012
If the pictures come out black, you might have a problem with the sensor, it might be broken, or simply disconected. Take your camera to a service center to have it diagnosed.
Aug 23, 2011 | Polaroid t1455 Digital Camera
I can't take photos with my phone. Once I click the camera button, the area where you see what you're taking a picture of is black. How do I solve this problem?
Some camera types need us to open lens cover manually before taking a picture, N70 foe example,
so check your phone's lens cover before capture something.
Or that's because there are less light when you take the picture, so turn on your flash light.
Hope this help and RATE please !
Jan 18, 2011 | Cameras
Not capturing pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Feb 12, 2010 | Canon PowerShot A530 Digital Camera
I cannot see anything when in camera, film, or view mode. When I snap a photo, it sounds like a picture was taken and the flash still goes off, but nothing is displayed on the screen. Only when I attempted...
Does it show pictures on the computer or is it black images, if they are black, your cameras lens cover could be stuck, it opens up when the lens is fully open, dirt-sand and dust or old grease causes the problem. otherwise your LCD on the camera could be off by mistake, (Do a camera reset) or a bad LCD
Oct 27, 2009 | Canon PowerShot SD600 Digital Camera
Camera does not react
I quote: "A couple of days ago after using it when trying to see the pictures on the camera the LCD did not show anything. The lens reacted and even take pictures but nothing was visible on the LCD screen."
That means that there was a problem either with a LCD display or with ribbon cable.
Now:"I tried charging the battery and removing it from the camera, now the camera only does a bit sound when switching on but nothing else, the lens does not even come out."
That means that the ribbon cable had probably shorted, now the camera may be furtherly damaged.
The camera must be disassembled to access the LCD and fix the problem.
The repair must be done by an experienced technician, as to access the LCD you need to remove both covers.
Jan 07, 2009 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Canon SD1000 display is black while the camera in shot mode
After some inspecting of the camera it seen the issue lies with the lens, not the camera itself so don't go banging the camera up or you might damage some other part and the camera will be broken for real. Inside the lens is a closer which block the internal system from capturing image. The closer look just like the one you see before turning on your camera but it's smaller and it's inside the lens way in the far back. Look carefully and you'll see it - you will see the closer if your screen is black while in capture mode otherwise you will see a nice round glass (the internal lens for capturing image/video).
Think of if like this, imagine an eyeball with its eyelid close. That's what happened when the screen is black while in capturing mode.
HOW TO FIX IT: In order to fix the black screen while in capture mode and cost as little damage to your camera as possible, simply turn on the camera in either picture or video mode and look inside your lens, there should be a closer in the far back end. Gently hit the lens a few times until you don't see the closer no more and only a round glass and your camera should begins capturing image and video again.
Good luck to you all. And remember don't use anger to force your camera to works or you will regret it.
If you need further help, contact me via email y a j y e e (at) h o t m a i l (dot) com
Yee Yang
Canon PowerShot SD1000
May 13, 2008 | Canon PowerShot SD1000 Digital Camera
Pictures are black
My 4300 works fine until this week. No picture display on the LCD screen. Settings like date, exposure, etc.. are fine on the LCD screen. Able to get into setup mode and the colour menu selection box is fine. This shows that the LCD screen is working fine. Prior to this happening, I notice that when I took pictures in zoom mode, the picture turn out to be orange. I suspect this is caused by electronic failure. Light entering the lens cannot be transmitted to the LCD screen. Some photoelectronic stuff had reached its MTBF (mean time between failure)? Is there a way to save this camera?
Mar 17, 2008 | Nikon Coolpix 4300 Digital Camera
Pictures are black
If you can display pictures in playback mode but screen is black in capture mode then the CCD sensor has stopped working and needs replacing.
Sep 12, 2007 | Kodak EasyShare LS443 Digital Camera
No display on LCD
May be the lens block or CCD can be defective. Call the nearest service center and we can only assist in spares and service manuals.
Aug 03, 2006 | Sony Cyber-Shot DSC-F717 Digital Camera
Polaroid T1455 14 MP Digital Camera Violet Logo
78 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
