Question about Gigabyte Computers & Internet
PCV-RS60G Sony, runn a bit faster?
Well first off this computer runs like the CPU will be at maby 10% Usage but the hardisk will be at 100% usage, on the pageing file.
I have tryed to add a 2nd Harddrive to the system and set it to be the only disk doing the Pageing-file. with no luck no change in its speed. i did notive the ram is running at 250Mhz of its 333Mhz is there a way we can make the ram run at 400Mhz, and have it not use the disk so much?
  • f_password
    f_password Dec 09, 2012
    Gary sir, you didnt look up the pc specs did you? the pc is IDE only no sata of any type. i did do a fresh install just yesterday i forgot to say.. but i got it to run faster and much better with the current setup, i removed all of the XP updates it had, and only did the ones for the grafs card, and network. there was something with the XP updates makeing it run like lol but since its only hardwere updates now its runnig so much better
  • Gary Rice
    Gary Rice Dec 09, 2012
    Hi again - just wanted to mention the SSD HDD's have simple adaptors to work with IDE only pc's. That said - I hihgly recommend you upgrade to a dual core pc. for the cost you will incure - the head aches you will avoid and the satisfaction you will get I would strongly suggest you get a new [er] pc if not a new one. I didn't 'look up the pc ' but I did search it and never even came up with the exact pc. I don't mean to be rude but I would not even bother to answer had I known the pc is that old because - there are so many things on the mother board alone that will cause the same problems - HEAT. You never said how much ram you have in the pc? Thing is for the price of a ram and other upgrades like a hdd and maybe a video card you can buy a new pc or a great used on from Craigslist. Bestr of it on getting up to speed. Gary
    President:
  • 1,851 Answers
As it looks like you know - RAM is the solution.
Even before that you sound like someone who will benefit with a fresh install no matter what your operating system is. After a fresh install :
Not knowing what you have I can only suggest you go to
www.crucial.com and follow instructions. You will need to upgrade the ram and you will really benefit with a new HDD - make it an SSD HDD even though smaller they are very fast. Set the one hdd as your MASTER and your second as SLAVE this will allow you to run way faster than the set up you have now.
Best of it
Gary @ Fix Ya.
Posted on Dec 09, 2012
2 Suggested Answers
  • 11800 Answers
SOURCE: the hp m 7170 n
No, find out which program is using all those resources (use Task Manager for that) and uninstall it.
Posted on May 11, 2011
I have a computer [AMD athlon(tm)]xp 1800+ 1.50 GHz]. My problem is when I switch on the system,the OS will open and i don't open any application then if i see in 'Task Manager - performance' there the...
Type "msconfig" on search bar there will be bar "startup apps" click that and click on disable all and restart your system...hope it works... Regards: imran
Sep 19, 2014 | Computers & Internet
CPU usage 100%
This is due to memory and program usage.
Depending on your computers specs. try these steps
1. Disk clean and defrag
2. Virus, spyware, malware, Trojan, rocket scan and removal
3. Registry cleaner and optimizer
4. Check disc space on the C: drive
5. Turn off unnessasery programs auto starting
If this does not work it maybe that you need to upgrade your computer or add some extra RAM.
Sep 28, 2013 | Dell OptiPlex GX280 PC Desktop
High CPU usage from interrupts and ACPI.sys
go to bios see if the cpu cap is off or on also go to system in computer and adjust all index options can also try cpu usage controls in control panel
Feb 28, 2013 | Computers & Internet
My Toshiba satellite pro M10 very slow.
check your system performance thru task manager. check for CPU usage. usually COU usage is 1% to 10%. if your CPU usage would peak from 10% to 100% there is a huge possibility that there is program running on your computer that eats up your memory. Or it could be spyware/malware
Mar 27, 2010 | Toshiba Satellite Pro M10-S405 Notebook
I'm having the dreaded 100% cpu usage.Would a new hard drive help?
if the cpu usage rides at over 90% constantly u need a newer faster cpu
Feb 25, 2010 | Sony VAIO VGN-TX670P/B Notebook
My cpu usage is more ,transfer rate i.e coppying spee is low
hi,i think this is most likely just your os .files on harddrive corrupt.reinstall windows!
Mar 06, 2009 | Computers & Internet
CPU Usage Meter 100%...... Indexing..... HELP!
What processes are you running?
Check taskmgr.
You will find there what is going on, and which program and processes are running on your computer taking the 100% CPU usage.
Dec 30, 2008 | Dell Latitude D430 Notebook
Computer CPU usage 100% anytime a program is opened and slowsdown
hi, i have written a document to fix this. if u like i can share it with u. check out myblog see if that helps you out. if not message me and i'll help you sort out this. and yes download combofix and run the tool. it will scan for malware,adware and spyware.
Nov 30, 2008 | Sony VAIO PCG-K47 Notebook
Open Questions:
Computers & Internet Logo
41 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
