Question about Refrigerators
I was defrosting my small Kenmore refrigerator today. I was utilizing a hammer and screwdriver to chip out the large ice chunk that formed around the inside and outside of the small metal box of the interior freezer. I punctured a coil in the bottom of the metal freezer box and visibly saw gas hiss out until empty in about 30 seconds. The refridgerator was unplugged and is an an open garage so the odorless gas dissapated without incident. I dont even utilize the freezer portion of the small refrigerator and the fridge is an outside fridge for beer / soda. Is it safe to plug the fridge back in and will the refridgerator portion operate?
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
No, you will need to buy a new unit. That one is scrap metal. Sorry.
Posted on Dec 09, 2012
tborn6
  • 700 Answers
SOURCE: HELP - I punctured the Evaporator coil - is it junk now?
you might as well not turn it back on because you let out the refrigerant and without it the only thing that will happen is the compressor wil get hot then shutdown. I would start looking for another refrigerator too and recycle that one that you have.
Posted on Jan 11, 2009
  • 400 Answers
SOURCE: The refridgerator has large amnts of water leaking from freezer
Looks like your defrost element is bad and needs replacement. Or if you can do a manual defrost and check if you are getting heat on the element. If there is heat, you can find a piece of copper wire and wind it around the element, leaving a trailing length of around two centimeters into the outlet drainpipe. By conduction this should keep the drainpipe clear.
Posted on Jul 02, 2009
  • 358 Answers
SOURCE: Ice forming in the bottom of the freezer
Unclogh the drain hole inside the freezer in the bottom of the bakc wall pouring hot water until the ice melted and keep pouring until goes through.Repet this every 3 or 4 months to keep it clear.
Posted on Jul 22, 2009
  • 21 Answers
SOURCE: i was defrosting my fridge and punctured the tube
might be possible, depending where exactly the puncture is, but if it was repaired it would need
regassing to the correct level, you would need a professional refrigeration engineer,
Posted on Dec 13, 2009
  • 1796 Answers
SOURCE: My Sanyo refrigerator (model SR-4431S)
Hi!
Before you can refill the system, you need to have the leak fixed. They have to evacuate the system, weld shut the leak, vacuum the system for 30 min. and refill refrigerant to proper level. This is a job that by Federal Law has to be performed by an HVAC Certified Technician. Take the unit to an appliance repair shop for repair, this way you'll save on the service call.
A HELPFUL - 4 THUMBS - Rating and a TESTIMONIAL would be greatly appreciated if you are satisfied with this FREE solution. Thank you for using FixYa.
Posted on Oct 22, 2010
Testimonial: "Thanks for the info and your time! I will follow your advice and take the unit to a repair shop. Much appreciated!"
How to fix ice build up in freezer
Did you examine the drain behind the rear panel (location #11) and below the evaporator coil in photo HERE and location #20 HERE You will need to tell me how much frost there is on the evaporator coil (location 22) I want you to test the=> 12729129 Defrost Heater Assembly. Check the door seals around both doors. Are the door seals good? I am here should you need me, Thanks John Tripp Appliance 911
Contact Me Here
Mar 11, 2014 | Maytag Refrigerators
The freezer is forming ice on back wall and all around the ice bins where the ice storage is, plus forming on food boxes, what could be the problem?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 25, 2010 | Kenmore TRIO 77314 Side by Side Bottom...
It's too cold in the top freezer, yet not cold at all elsewhere
if your freezer is cold but your fridg isn't then you have a defrosting problem. behind the back wall of your freezer you will probably find a very large mass of ice. unplug your ref and using hot water melt the ice. you will need several large towels for this since it will make a mess. once the ice is cleared if you have an ohm meter you can check the defrost element you are looking for continuity( closed circiut) if that tests ok find the defrost termintor(also called a bi-metal defrost) it is about the size of a quarter and is usually located in the top left side of the freezer. It will be clipped to one of the tubes. if it looks like it has popped then it is bad. If the bi-metal looks ok you will need to hook the element back up and go to the control panel in the fridge. looking up at it you will see a small hole and a gear inside that you can turn with a slotted screwdriver. turn it until you hear it click and the fans stop running. if the defrost heater comes on then change the defrost timer(the part you just turned)
Apr 24, 2010 | Kenmore 64802 Top Freezer Refrigerator
Kenmore refrigerator defrost dranage tube plugged
Empty the fridge, carefully put the fridge on it's side and access the drain from the bottom. There will be a shallow collection tray designed to collect and evaporate the defrosted water, and you may have to remove this with small sheet metal screws.
Once you find the tray you'll see the drain tube. Use a thin but rigid wire to poke into the tube.
An old bicycle brake cable works well.
Also, the plug may be a frozen chunk of ice. Try letting the fridge defrost for a day.
Jul 30, 2009 | Kenmore Refrigerators
Ice cube maker
We need to check the defrost timer first. It's located inside the fresh food compartment and inside the control panel. There should be a small opening through the panel that you can place a flathead screwdriver. Turn slowly clockwise until the refrigerator compressor stops. Leave it alone for about 30 minutes. If it does not restart then the timer is bad and will need replaced. If not then we need to unplug the refrigerator and remove the rear panel inside the freezer and inspect the defrost heater and defrost thermostat. Let me know when you need more assistance, Thanks Sea Breeze
Timer part number may depend on if the model is correct listed above your post. Part # 68233-3
SITE-> http://servicepartstec.blogspot.com/
Jun 18, 2009 | Maytag PTB1954GR Top Freezer Refrigerator
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ice forming on freezer back wall of 6 year old top
u have a defrost problem unplug for 4 or 5 hrs with door open will work like new till u can get a tech out to replace parts
Mar 17, 2009 | Kenmore 18.9 cu. ft. Top Mount...
Ice cubes made by ice maker become large fused chunks over time.
Ice cubes will deteriorate over time if not used. They shrink due to defrosting of the freezer and will become stale.
Once the ice bin is full, turn the ice maker off until you use the cubes and or dump the cubes every 3 or 4 days and start over.
Mar 03, 2009 | GE Refrigerators
Water leaking out from the inside bottom Jenn Air JRSD245L
It sounds from what you described is a clogged drain line pull the bottom drawer out and look at the bottom of the back wall. see if the drain is backed up with ice if so use the back end of a rubber handle screwdriver and lightly tap the ice until it breaks up clean up the best you can around the drain and pour some hot soapy water down until to you hear it going into the drain pan.. a cup will do....>>the water comes each time the unit goes into defrost as the heaters melt the frost build up on the evaprator it melts and is suppose to go down the drain but if it is blocked then it forms at the bottom of the freezer floor..let me know if you still need the wiring diagram I can email it to you. Hope this fixes YA !
Feb 22, 2008 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Ice building up on top of drawer
Try to defrost the unit until all the ice disappear in the evaporator coil.
Feb 05, 2008 | Jenn-Air JFC2089H Bottom Freezer French...
Refrigerators Logo
140 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
