Faulty Ram Controller?
Using Memtest86+ V2.01 ram in slot 1 (top slot) is reported as DDR1 CAS 3-2-2-0, in slot 2 (bottom slot) is reported as DDR11 CAS 4-4-4-12, both are FSB 133. The ram is GEIL 1Gb PC2-5300 DDR11-667 CL 5-5-5-15, I am using 2Gb in total. Is there a problem maybe with the memory controller or something else related? Memtest completes tests on both slots without a problem. I am using Windows Vista Home Basic and have intermittant system lockup and have to power off to restart the system, ctrl-alt-del will not work. When lockup happens I will get a problem with the screen picture of multiple lines in three columns down the screen with short black bars 2-3mm thick about 25mm long and 25mm apart from top to bottom and flickering. When this happens the system will not respond to mouse or keyboard and power off by power button will only work.
  • 6 more comments
  • Stephen Jan 13, 2009
    It is a Acer Aspire 4710Z laptop and has a basic bios, not many changes available. The Memtest86+ that I used is a full test and takes approx 15min to run on this system. I have noted the s/n of the ram slices and if they are not put 7000101 in bottom and 7000102 in top the system will power up but no bios check or system load will happen.
    The system is about one & a half years old approx and I am having random system lockup problems with a degraded display being the first symptom when it happens.
    If the ram or a controller connected to it is having problems, couldn't it cause display problems or lockup the system. I am also thinking of backing up the system and doing a full new install of windows, drivers etc...
  • Stephen Jan 15, 2009
    Do you rustyk123 know of a good tester for the onboard video, I had a look at a friends acer laptop and ran the memtest on his and got the precise info on his memory slices at the stated cas and ddr type. Unfortunately it was not the exact same model but it proved the memtest I am using is ok. I am definately going to back up the system data and do a full install of windows for good measure but not hopeful as I feel it is hardware not software.
  • Stephen Feb 03, 2009
    Bingo I have the problem nailed down to bad ram slice. Used latest memtest86+ V2.11 on each slice individually over and over 4 times and bingo one finally waved its hand and gave up. Thanks to all for your help and advice.
  • Dan rogers
    Dan rogers May 11, 2010
    sounds like a display issue to me when is the last time you updated your hardware drivers?
  • Dan rogers
    It also kinda sounds like your cpu or the graphics card may be having issues. How old is the system?
  • Stephen Scheneman
    Stephen Scheneman May 11, 2010
    Can you change your CAS/RAS latency in the advanced BIOS options? And did you do the quick tests or the full tests with memtest? (Just curious...This is an interesting issue.)
  • 50 Answers
This does sound to be video problems. This could be caused by one of two things. 1) Faulty Video card 2) Faulty Memory/controller. I would sugest running a program to test the video card if it passes, try removing the top stick of memory (the one being falsely read) and try running it for some time under its normal use to test this.
Posted on Jan 15, 2009
What is the max size of ddr400 memory you can fit into ddr1 & ddr2 dimm slots on a p4vm8 mother board
1) Total maximum amount for motherboard is 2GB.
2) There are 2 Ram Memory slots.
3) Maximum amount for EACH ram memory slot is 1GB.
Either DDR Sdram at 266MegaHertz, or 333MHz, or 400MHz.
PC2100, PC2700, and PC3200, respectively.
There is no DDR1 and DDR2 slots, in a manner of speaking.
May be marked on your motherboard that way, but stating it that way on a computer product support website = No.
You're going to make someone think, you don't know what you are talking about.
They may think you are referring to DDR Sdram, and DDR2 Sdram, and they know the motherboard only uses DDR Sdram ram memory.
Suggest state Slot 1 and Slot 2; or DIMM 1 and DIMM 2.
For additional questions please post in a Comment.
Mar 18, 2013 | VIA ASRock P4VM8 P4(S478)/...
Hi... Can you help me in the software of my pc the Video Controller (VGA Compatible) It was gone when I was reformat the PC. Motherboard Manufacturer: Company Name Micro-Star International Motherboard...
Field Value North Bridge Properties North Bridge SiS 661FX Revision 11 Memory Timings CAS Latency (CL) 2.5T RAS To CAS Delay (tRCD) 3T RAS Precharge (tRP) 3T RAS Active Time (tRAS) 5T Memory Slots DRAM Slot #1 256 MB (DDR SDRAM) DRAM Slot #2 512 MB (DDR SDRAM) Integrated Graphics Controller Graphics Controller Type SiS 330 Mirage Graphics Controller Status Enabled Graphics Frame Buffer Size 32 MB AGP Controller AGP Version 3.05 AGP Status Enabled AGP Device SiS 330 Mirage Integrated AGP Aperture Size 64 MB Supported AGP Speeds 1x, 2x, 4x, 8x Current AGP Speed 8x Fast-Write Not Supported Side Band Addressing Supported, Enabled Chipset Manufacturer Company Name Silicon Integrated Systems Corporation
Jul 16, 2010 | Microsoft Windows XP Professional SP2
Is it possible to add 1GB DDR1 RAM 333 MHZ to INTEl D101 GGC
u can use the 1gb ddr1 ram,if the sound is coming then may there is two problem
1.may be the ram is damage
2.your motherboard is not supporting 333mhz bus support
try to find 400mhz ram instead of 333mhz
Feb 27, 2010 | Intel D101GGC Motherboard
My mother boaard has written ddr1 and ddr2 near the ram slot. Is it pssible to put ddr2 ram? before it had ddr1 ram
It's not because DDR1 ram slot Motherboard are created only for DDR1.
DDR2 are the newest design of memory module by a new MOBO.
There is no Motherboard that are design with two kinds of Memory Slot DDR1 & DDR2.
I never that before.
Aug 19, 2009 | Computers & Internet
Can i use ddr2 ram in my pc inplace od ddr1 i cn purchase pc 07?
Hey there, Check for the slots given on your motherboard, whether all the slots are same; However a motherboard can support only one type of module either DDR1 or DDR2. your motherboard has only DDR1 slots. You cannot upgrade DDR1 to DDR2 cause the Memory Module or notches are different than eachother. Gimme Acknowladgement by rating me. Thanx - Romy Decostza
Jun 09, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Few questions about RAM memory?
i)  LOW DENSITY modules have 100% compatiility with ALL systems and ALL chipsets.
    HIGH DENSITY modules only have 10% compatibility
    here compatablity means LOW DENSITY RAM are accepted by all system(100%)  or any make           system.. HIGH DENSITY RAM are accepted by 10% by only some system or computers...
ii) in order to check system performance or amount of Computer RAM usage press the ctrl+alt+del
   simultaneously a new window(window task manager) will appear showing:
    CPU usage: showing the amount of CPU or processor utilized at that particular time.
    PF usage: showing the amount of RAM memory utilized at that particular time.
    Physical Memory: showing Total RAM Memory, Available Ram memory....
iii) baiscally they are two types of RAM they are:
    DDR1:which is older one supported by older system  or older mother boards which is costlier
    DDR2: which is latest one supported by all new system or new mother boards which is less                         costlier
    DDR: double data rated ram......which will send data at a double rate compared to SD RAM
iii) here color doesnt matter, these slots either support DDR1 or DDR2 but not both at a time
    DDR1 has 184 pins or gold plated pinssss... on the edge of the RAM
    DDR2 has 240 pins
    so difference doesnot allow DDR2 to placed in DDR1 motherboards or vice versa...
iv) it does have anything to do with no of chips on the RAM but they only differ whether it is DDR1 OR DDR 2(DDR2 are much faster than DDR1)
NOTE: whatever may the the RAM, each RAM has FSB(called Frequency...) which determines the frequency of rate at which data is tranferred from RAM to processor(CPU)  usually in MHZ such as FSB 300, 400, 200 , 333...................
more the FSB the faster data is transferred to the processor(CPU)
dont worry even RAM with less FSB's work well with the processor....having 1 GB RAM or 2 GB RAM is engouh, it only matters with the speed of CPU ... but not RAM......
Sep 24, 2008 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Hi I would like to upgrade my mem in my desktop pc i have a ASROCK PS461 with a 256MB ddr1 pc2700 333card and a pc2700 512MB ddr1 333 in the next slot (3 slots) i would like to up the ram to 2 Gig ,...
just ask computer shopkeeper for 2gb RAM DDR1 for *********** board.
Please let me know your feed-back.
Technical Associate
Apr 30, 2008 | Computers & Internet
Computers & Internet Logo
274 people viewed this question
David Payne
David Payne
