Question about Canon PIXMA MP830 All-In-One InkJet Printer
File name contains invalid characters - Canon PIXMA MP830 All-In-One InkJet Printer
I have a file folder in my external hard drive. it is now renamed usbc with some other characters. cannot open the folder anymore.
Try running scandisk to check the drive for errors. If a directory or file has a name containing invalid characters then you cannot access it. This can happen if the file allocation table gets corrupted. Unfortunately there is no easy fix if you need to access any files in the folder. You may need to find some data recovery software if the data is important.
May 20, 2011 | Video Game Consoles & Games
Could you please tell me, what does DCIM in my sony ipod mean? how can i use that or when do i use that? please
Yes, that is the access to you picture files.
From WIKI:
Design rule for Camera File system (DCF) is a JEITA specification (number CP-3461) which defines a file format and file system for digital cameras, including the directory structure, file naming method, character set, file format, and metadata format. It is currently the de facto industry standard for digital still cameras. The file format of DCF is based on the Exif 2.2 specification.
The latest version of the standard is v 2.3.
The filesystem in a digital camera contains a DCIM (Digital Camera images) directory which contains possibly multiple subdirectories with names such as "123ABCDE", which consist of a unique directory number (in the range 100...999) and five alphanumeric characters, which may be freely chosen and often refer to a camera maker. These directories contain files with names such as "ABCD1234.JPG", which consist of four alphanumeric characters (often "DSC_" or "IMG_"), followed by a number. The file extension is "JPG" for Exif files and "THM" for Exif files that represent thumbnails. Other file formats use different extensions. Multiple files sharing a number (even if the file extension or the four alphanumeric characters are different) are considered related and form a DCF object.
For example, the files on a Nikon D40 are arranged according to the above specification. Thus, a card formatted by the camera will have a partition named "NIKOND40", with a subdirectory named "DCIM". This directory contains a subdirectory named by default "100NCD40", in which images are stored. images are named "DSC_xxxx", where xxxx represents the file's sequential number.
As this is an industry standard, similar directory structures and naming procedures can be found in most digital cameras.
[edit] AccessCamera file systems can usually be accessed by directly mounting them via the USB mass storage device class protocol, which exposes the file layout, whether DCF compliant or otherwise. Alternatively, and independent of DCF, files may be accessed via the Picture Transfer Protocol, which provides an object-oriented view and need not expose the file layout.
The file system layout is often opaque to users, as images are copied onto a computer or printer and the application deals with layout
Apr 11, 2011 | Vacuums
Cannot open excel file
if you saved the file with any of these characters (!@#$%^&*()+=) in the file name, Excel will not recognize the name
you will have to rename the file
right click on the icon for the file and rename it with .xl as the extension, you will then be able to open it
May 02, 2009 | Microsoft Office Excel 2003 for PC
I get error 1324 , path contain invalid character
It may be that one of your "special" folders has an invalid character in the path, such as \. You can reset your folders to there defaults. Go here http://windowsxp.mvps.org/usershellfolders.htm
Use caution when modifiing the registry.
Apr 01, 2009 | Computers & Internet
Huge files are not being retrieved
I would make sure that all filenames do not exceed 116 characters in length, and they contain only standard characters (A-Z and 0-9, not symbols like !@#$%^*))/|).
Sep 18, 2008 | Electronics - Others
Pop up 'invalid file name'
Invalid file name usually means that you are trying to use an invalid character in the file name, like a / or a symbol. When that happens the file is not saved. To change a name on a pre-existing file. Select the file, press the F2 key and type in the new file name. Press enter to save the file name, but don't change the file extension: ie. .jpg, .gif, .psd
Nov 13, 2007 | Adobe Photoshop CS for PC
225 mr will not play burn MP3's
I have the manual and copied it verbatim for you. Please let me know if you need me to scan the manual for you. Acceptable medium formats: The following formats are available for the media used in this unit. The maximum number of characters used for file name including the delimiter (".") and three-character extension are indicated in parentheses. ? ISO 9660 Level 1 (12 characters) ? ISO 9660 Level 2 (31 characters) ? Joliet (64 character; Up to 32 characters are displayed) ? Romeo (128 character; Up to 64 characters are displayed) ? Long file name (200 characters; Up to 64 characters are displayed) ? Maximum number of characters for folder name: 64 (Joliet; Up to 32 characters are displayed) For a list of available characters, see the instruction manual of the writing software and the section Entering file and folder names below. The media reproducible on this unit has the following limitations: ? Maximum number of directory levels: 8 ? Maximum number of files per folder: 255 ? Maximum number of folders: 50 MP3/WMA written in the formats other than the above may not be successfully played and their file names or folder names are not properly displayed. Settings for your MP3/WMA encoder and CD writer Do the following setting when compressing audio data in MP3/WMA data with the MP3/WMA encoder. ? Transfer bit rate MP3: 8 ?320 kbps WMA: 48 ?192 kbps ? Sampling frequency MP3: 8, 11.025, 12, 16, 22.05, 24, 32, 44.1, 48 kHz WMA: 32, 44.1, 48 kHz When you use your CD writer to record MP3/WMA up to the maximum disc capacity, disable additional writing. For recording on an empty disc up to the maximum capacity at once, check Disc at Once. Play mode may not be possible when portions of the functions of Windows Media Player 9 or higher are used. Entering ID3 tag: The Displayable ID3 tag is ID3 version 1.x. For the character code, refer to the List of Codes. Entering file and folder names: The code list characters are the only file names and folder names that can be entered and displayed. If you use any other character for entry, the file and folder names are not displayed correctly. They may neither be displayed correctly depending on the CD writer used. The unit recognizes and plays only those MP3/WMA which have the MP3/WMA extension (.MP3/.WMA). A file with a name entered with characters not on the code list may not play correctly. Writing files into a medium: When a medium containing MP3/WMA data is loaded, the unit checks all the data on the medium. If the medium contains a lot of folders or non-MP3/WMA files, therefore, it takes a long time until the unit starts playing MP3/WMA. In addition, it may take time for the unit to move to the next MP3/WMA file or a File Search or Folder Search may not be performed smoothly. Loading such a medium may produce loud noise to damage the speakers. ? Do no attempt to play a medium containing a non-MP3/WMA file with the MP3/WMA extension. The unit mistakes non-MP3/WMA files for MP3/WMA data as long as they have the MP3/WMA extension. ? Do not attempt to play a medium containing non MP3/WMA.
Jul 31, 2007 | Kenwood KDC-225MR 200W Car/Marine SIRIUS...
Microsoft Broadband Networking Setup Wizard does not start
CAUSE This issue may occur when the Network ID setting on your computer is configured with a workgroup name that contains a special character--for example, a period. A workgroup name can contain up to 15 characters, including letters, numbers, and the following characters:! @ # $ % ^ & ( ) _ - ; : ' " ,. It cannot contain any spaces, and must start with a letter or a number. The NetBiosName class considers the majority of those special characters as invalid so the problem may occur if the workgroup name contains other characters besides the period. RESOLUTION To resolve this issue, change the workgroup name to something that does not contain special characters. To do this, follow these steps. Note Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps. Note Follow these steps on all computers that are in your workgroup. 1. Click Start, right-click My Computer, and then click Properties. 2. In the System Properties tab, click the Computer Name tab, and then click Change. 3. Under Member of, click Workgroup, and then type a name for your workgroup that does not contain any special characters. 4. Click OK, and then restart your computer.
Feb 16, 2006 | Microsoft Broadband Networking MN-500...
Feb 16, 2006 | Microsoft Broadband Networking MN-100...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
44 people viewed this question
old marine
old marine
