Question about Black & Decker Jump Start System 450 Amp Instant Starting Power/ Compressor
I am not sure if after plugging the charger in to electric outlet, do I have to turn the charger on or leave it off to charge it?
  • piercefildr
    piercefildr Dec 10, 2012
    Thr reason I;m trying to charge the Jump Start System is I haven't used for quite a while, and it didn't start the car, so I thought maybe it needed charging, the lights to indicate if it fully charged shows 2 red lights and and one green light. read instructions and they are clear as to what to do with the off and on button while trying to charge unit!!HELP, HELP!!!!!!!!!!!!!
  • piercefildr
    i MEAN the instructions are not clear as to what to do????
    Sergeant:
  • 288 Answers
Leave it off
Posted on Sep 11, 2013
Display would not turn on. I have replaced the battery and still no display. Do I need the charging cord to get it going?
The battery charger is only used to recharge a low battery.
If the console does not light up after pedaling. connect the battery charger to the machine and then plug it into an electrical outlet.
If the console powers up, your battery is low and needs to be charged.
Leave the battery charger connected to the machine for 24 to 48 hours to charge the battery.
It is okay though to use the machine with the battery charger connected.
If that still does not work, check over all main cables for loose connections or fraying. Especially those to the battery and to the console.
Verify that the speed sensor is 2mm (about a credit cards thickeness) from the speed disc on the alternator.
Please be sure to disconnect battery cables before adjusting speed sensor or touching any other electrical components.
If anything else comes up we would be happy to assist you, contact our Tech Support Team at 888-713-2880 or visit us online at
www.sportsmith.net
Jun 20, 2015 | Stairmaster 3400CE Upright Exercise Bike
On ultra jet 3 there is a 3 prong outlet below the seat on the right & has cord that goes to normal outlet is that how to charge it
Jet 3 Ultra www.pridemobility.com 33
VI. BATTERIES AND CHARGING
To charge the batteries using the off-board charger:
1. Position the front of your power chair next to a standard
electrical outlet.
2. Be certain the controller power is turned off and the
freewheel levers are in the engaged position. See III.
"Your Power Chair."
3. Plug the off-board charger into the off-board charger/
programming socket on the controller.
See figure 25.
4. Plug the off-board charger into the electrical outlet
You should use the charger supplied with the power chair. It is
the safest, most efficient tool to charge the batter-ies. We do not recommend using other types of
chargers (e.g., an automotive battery charger).
Sep 07, 2014 | Health & Beauty
My tablet M9200 will not turn on
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
Feb 10, 2014 | Kocaso M1050
Will not turn on
Feb 10, 2014 | Kocaso Tablets & eReaders
Battery wont charge on my Mid m9100 android tablet pc
Are you sure the charger is working correctly? When you plug the charger into the tablet and into the wall, then leave it alone for half an hour, does the charger feel at all warm? Is there power to that outlet, or is it a switched outlet (like one used for a lamp)?
If the charger feels warm after half an hour, does the back of the tablet also feel warm? It may actually be charging.
If the charger is dead cold (same temperature as a table) and you're sure that it's plugged into a good outlet and correctly plugged into the tablet, then it's a good bet that the charger is dead & you need to find another.
Can you also charge that tablet with a USB cable connected to a PC? That'd be a good test. Try doing that - if that ALSO will not charge the tablet, then there may be a problem with the tablet itself.
Mar 02, 2013 | mid M9100 9" Dual Camera Android 4.0 ICSOS...
Does not work, we tired a new battery, but no help.
Instructions
    Technical Difficulties
  1. If the phone doesn't turn on, make sure battery is charged and fully plugged into phone. Remove battery from phone and use rag to brush away dirt that may interfere with connection. Reconnect and try again. If using cigarette-lighter adapter, make sure it's properly plugged in. Make sure charger is properly plugged into outlet and into battery.
  2. When the battery doesn't charge, plug lamp or other electrical device into outlet to verify that outlet works. Borrow friend's charger to see if charger or battery is problem. Replace charger or battery if necessary.
  3. In case the phone gets wet, remove the battery from the phone and allow both to dry thoroughly. If rust or corrosion develops, wipe it off with a stiff brush. If phone still does not work, replace it.
  4. Should the display not be working, try getting it to room temperature, extremely cold or warm conditions may affect display functions.
  5. If the keys don't work, look for a display of a symbol that looks like a lock. The keypad may be locked. The display often tells you how to unlock it. If not, check owner's manual.
Jan 24, 2011 | Lands Phones
When the charger is left plugged into the electrical outlet, will it automatically turn off when fully charged?
when the battery is fuly charged if im not mistaken the green light will still stay on but will not be charging the battery anymore. All the light is doing is indicating that the battery is fully charged. It is not recommended that you leave the battery sitting on the charger for long periods of time since batteries an get a memory from a charger and then you might start having some battery issues. Hope this helps.
Dec 10, 2010 | kawasaki 19.2V 4 Piece Cordless Tool Kit
How do I charge my scooter I have lost my instructions
Look in your manual if you lost it then, go to razor.com and request one. But the simple answer is to:
1. Turn off the scooter
2. Plug charger into wall outlet.
3. Find the hole on the side that matches the charger plug(not the wall outlet plug) .
4. Plug the charger into the scooter.
5. Wait until the charger turn off ( if the charger is a smart charger), typical charging time is 4-6hours.
*If not a smart charger you can calculate the charge time by using an online battery charging time calculator.
Jul 02, 2010 | Razor E100 Electric Scooter
Motorola razr v3 wont charge, the bettery is not that old the phone beeped to signal charge requred, plugged it in as usual but cant turn it back on.
If the charger is plugged in, the phone is hooked to it, and it still will not come on, I would think it's a charger or electrical outlet problem.  I think most phones will bypass the battery power if they are plugged into an outlet, so try another wall plug, and if that wasn't it, try a different charger.  If a different outlet and charger don't solve it, it may be time to take it to the store to be checked.
May 29, 2009 | Motorola Mobility RAZR V3
Does leaving a cell phone charger plugged in to an outlet at home,without having the phone charging in it,drain energy from your home?
Yes. You are right. Here energy is not the criteria. It is always safe to unplug the charger (when not in use) to prevent the damage of a cell phone due to accidental over load of electricity or short circuits. Moreover Chargers do draw power when plugged in, whether or not a device is actually being charged.
If the charger is plugged in someplace easy to access, like right by where you keep your phone, you should unplug it. But if it would be difficult to have to plug it in every time you need to use it, you'll be fine just leaving it plugged in..and.It still uses energy even when not charging. Any electronic device plugged in a socket uses energy whether it is in use or not.
Oct 07, 2008 | Samsung SGH-D900 Cellular Phone
Black & Decker Jump Start System 450 Amp Instant Starting Power/ Compressor Logo
191 people viewed this question
Top Black & Decker Hammering Experts
Gary Nitowski
Piyal Perera
Piyal Perera
Are you a Black & Decker Hammering Expert? Answer questions, earn points and help others
