I need to know what size the hard drive is. 2.5" or 1.9"?
I need to know soon
  • 3 Answers
There is no 1.9" that I'm aware of. Likely 2.5" is the answer. What is the capacity? What's the model of notebook?
Posted on Dec 08, 2012
How do I choose a hard drive?
It depends upon where the hard disk is to be installed, ie. in a desktop computer, in a laptop or in an USB hard drive case.
A 3 1/2 inch hard drives can be a IDE/PATA or a SATA type. Older computers use IDE/PATA hard drives and the maximum size you can install in a desktop depends upon the computer's BIOS.
SATA hard drives are generally used in later model computers and the size of the hard drive is not limited by the BIOS.
A 2 1/2 inch hard drives are used in laptops and are available in IDE/PATA and SATA types. The size and limitations of IDE/PATA hard drives also apply to laptops. The same applies to SATA hard drives.
The choice and size of hard drive depends upon your requirements and how much you want pay.
Don't forget to check BIOS for the maximum IDE/PATA hard drive size you can install in your computer.
Aug 22, 2011 | HP Computers & Internet
I have a Seagate external hard drive model # 9w6044-500. I need to know what kind of drive it has, how many gigs it is and what size disc it uses.
Welcome to Fixya. Here's the specs of the hard drive
MPN: 9w6044-500
Capacity: 160 GB
Interface: USB
Enclosure: External
Spindle Speed: 7200 RPM
Special Features: Vertical or Horizontal Placement
Internal Data Transfer Rate : 464 Mbit/s
External Data Transfer Rate: 60 MBps
Seek Time: 8.5 ms
Buffer Size: 8 MB
Average Latency: 4.17 ms
Interface (Detailed): USB 2.0
Hot Swap: Yes
Platform: PC, Mac
Height: 2.25 in.
Width: 6.5 in.
Depth: 7.13 in.
Weight: 2 lb.
If you have questions please let me know. Thanks for using Fixya.
Mar 13, 2011 | Seagate (9W6044-500) 160 GB Hard Drive
I need a diagnostic tool for RAID falure code 0. Initial boot indicates degraded condition. DISK scan does not seem to remedy the issue. Did the drive actuually fail? Is there a fix? Primary disk still...
It looks like you have two arrays here. The first one being a mirrored RAID array and has only one disk. This means that the other disk has failed in some sort. This does not mean that the drive is bad, just the RAID failed for some reason. You will need to rebuild the RAID if you want to maintain the same level of redundancy.
You can just attempt a rebuild the RAID to the same drives but if this fails you will want to replace the bad drive. In order to do this you will need to make sure you can tell which drive is which. You do not want to mirror the bad drive to the good one.
If attempting a rebuild to the existing drive does not work or is not an option (because the failed drive could really be bad), you will need to determine which physical drive needs to be replaced. You may be able to hot-swap the drive but if you can power things down, that is always safest. Once the new drive is installed, you can rebuild to it and all should be well after that.
Jan 04, 2011 | Dell Dimension 9100 PC Desktop
Personal computer, need to know the size of the hard drive
it is 3.5inch hard drive fits in the bay just like the floppy drive size
Dec 04, 2010 | Computers & Internet
Can not copy outlook messages
It looks like your external hard disk in FAT32 system and outlook messages file .PST is more then 4GB.
To know the file system of the Hard Disk right click on the drive select properties.
Check your file system first. FAT32 will not support more than file size of 4GB.
There are 2 options to copy.
1. Split the .PST in to 2 or more outlook data file
or
2. Convert the FAT32 System to NTFS.
To convert from FAT32 to NTFS. go to following link
http://support.microsoft.com/kb/307881
Mar 07, 2010 | Western Digital (WD3200JS) 320 GB Hard...
Shows hard drive into 4 sections soon uses gb upon main hard drive but others show plenty of gbs left how to put into one drive
Use Partition Magic. It is software that will Re-Size, Merge and Create a hard drive partition. Here is the download link for you pal:
http://www.softpedia.com/get/System/Hard-Disk-Utils/Partition-Magic.shtml
I am sure this could help you a lot. Thanks..
Dec 18, 2009 | Excelstor Technology J880 Hard Drive
Know what kind of hard drive to put in a toshiba satillite 4090
It will If its a laptop sized hard drive , A desktop sized Hard drive will not fit.
Nov 30, 2008 | Toshiba Satellite 4090XDVD Notebook
Problem in hard drive
The hard disk may have some bad sectors. Try zero filling the hard disk. Try to download the programs from http://www.samsung.com/global/business/hdd/support/utilities/Support_HUTIL.html You will come to know if your hard disk is the culprit.
Oct 06, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
