Question about Toys
How do you fix a imaginext mammoth's front leg?
The front right leg wont stay on
2 Suggested Answers
mckernie
SOURCE: Imaginext Batcave lift sticks and doesn't go up and down. Does anyone know how to fix this?
the thread is too long, so you have to remove the top, screws (x2) on either side, then unscrew the lift reel (black disc) from the red twister (on top where figures feet fits into).
Take lift to top of run until it comes off runners, pull two halves apart and trim thread behind knot to shorten to required length), retie knot and re assemble.
Posted on Apr 04, 2012
Imaginext Batcave drawbridge won't go all the way up.
Turn the batcave over and remove the long black piece in the center section (5 screws). Re-align the two white gears so that the drawbridge stays shut. Then put everything back together. Easy 2 min. fix.
Jan 06, 2013 | Fisher Price Imaginext DC Super Friends...
Adjusting doors to stay closed
It is not a matter of adjusting the doors. It is a matter of adjusting the legs so that the front legs are taller than the back. This causes the entire refrigerator to tilt toward the back, which is what makes the doors close by themselves. Your installer should have done this for you, as it differs between locations. It takes at least 2 people to do this: one person tilts the refrigerator back by pushing on the front of the freezer door, and the other person carefully rotates the front legs of the refrigerator until they lengthen about 1/2 inch - each! You might have to slide the whole refrigerator forward to give you some space behind it to allow tilting. Don't adjust the rear legs - not needed unless someone has unthreaded them in error, or for some unknown reason.
Oct 21, 2012 | Frigidaire FRT21P5A Top Freezer...
Starts but not stay running
When you say it starts but doesn't stay running does that mean it goes right back off or does it go off random. If it goes right back off it could be several different things such as bad soldier or voltage regulator. If it does it at random I'd say first thing look for bad soldier around regulator its on the side of the radio 3 legs attached to side. One of these legs will get unattached because of using your side screws and tighting them to tight.
Jul 14, 2012 | Ranger Communications RCI-6900F-25 CB...
Dec 26, 2011 | Toys
When I open bottom or top fridge doors they swing all the way open by themselves instead of staying put partially open
The fridge needs to be leveled better...
When the doors swing open then gravity takes over and pulls the doors open the rest of the way...
to fix this adjust the legs of the fridge so that it leans just a bit away from the hinge side and back just a bit...then the doors will swing closed by themselves...
The back legs may have to be shimmed and the front leg adjustments are usually right behind the front cover at the floor...sometimes there are screws there to adjust the back legs from the front also...
heatman101
Jan 16, 2011 | Kenmore 64802 Top Freezer Refrigerator
When you push big foot's chest his mouth opens but nothing comesout and then there's this buzz sound
From Fisher-Price Site
If Bigfoot stops working, check the following
  • Motor Stall - Was there any audible beeps from Bigfoot before he shut down: If audible beeps came from Bigfoot, a motor has stalled.
    • 1-Beep = arm motors stall
    • 2-Beeps = leg motor stall
    • 3-Beeps = head motor stall
To Fix the Motor stall:
    • Remove any obstruction from Bigfoot's path.
    • Turn the product off and then back on to restart the product.
    • If this stall condition continues to happen when no obstruction is present, there is a malfunction with Bigfoot. Please contact Consumer Relations.
In my case I had 2 buzzes and I forced the legs into the stand position. That did the trick.
Jan 14, 2011 | Mattel Fisher-Price Imaginext Big Foot
BACK LEG LEVELING ARM
The back legs are usually not adjustable. Adjust the front legs & lock them with the lock nuts, at the lowest level, that is the machine tilts towards the front. Adjust further if there is any shake when you try with your hands.
You could also check to see if any springs or shocks have become loose. Refer manual.
Mar 30, 2008 | Washing Machines
LG bottom freezer
Sounds like the refrigerator is sitting lopsided.  Make sure that the front legs are both retracted in the up position.  If it doesn't work, then lower the front leg on the hinge side of the refrigerator.  That will cause the frame to lift the door and it should be able to close properly.
Oct 25, 2007 | LG LRDN20720 Bottom Freezer Refrigerator
Toys Logo
48 people viewed this question
Top Toys Experts
Tom Chichester
Are you a Toy Expert? Answer questions, earn points and help others
