Question about Nikon D3000 Digital Camera
Cant set shutter speed past 200
Trying to adjust the aperture and shutter speed and noticed it wouldnt allow me to go past 200 even when i turn the wheel on back of camera how do i fix this?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Is the flash turned on? The camera won't let you set a shutter speed faster than 1/200 when the flash is on.
Posted on Dec 08, 2012
Takes good pics. in daylight but no pics.atnight
At night there is no light. Cameras need light
Jul 17, 2017 | Cameras
Photos to dark
The aperture and shutter speed setting depends on the amount of light and on the effect you want to achieve. For any given lighting situation there are many possible aperture/shutter speed settings that are all equally valid. However, the aperture also determines the depth of field, and the shutter speed can either freeze action or allow it to blur. Only you as the photographer can decide which of those valid exposure settings best conveys your vision.
As to how to determine the proper exposure, there are several possibilities. One is to use a light meter. If you don't have a separate light meter, you can use another lens and meter through it. It may not give you exactly the same field of view, but it should get you into the ballpark. Then there's the "sunny-16 rule." This says that under a bright sun, the proper exposure is f/16 with a shutter speed equivalent to 1 over the ISO. Of course this is just a starting point, and you can adjust the aperture/shutter speed to achieve the desired result.
I suggest you visit your local library. They should have introductory books on photography which will explain all this in depth.
Mar 06, 2012 | Tokina f/NIKON- 80-200/4.5-5.6 SZX Zoom...
I'm having problems with the settings on my Canon EOS 400D. When I take pictures in AV mode I can get quality pictures but in TV or M modes the pictures always come out so dark even when taking them...
You need to understand the relationship and teractivity of aperture, shutter speed and iso. In Av mod, you choose the aperture and the camera makes thw shutter speed agjustment, In Tv mode, you set the shutter speed and the camera makes the aperture adjustment, In manual, you have to set both shutter speed and aperture manually. If the ISO mode is set to AUTO, the camera chooses the sensors sensitivity to light automatically. Change to specific ISO
(200-400 for daylight and 799-1600 for night). Take a picture in AV mode and note what shutter speed the camera chose. Then switch to TC mode choose the same shutter speed and see if camera chose the same aperture(f-stop) you chose in first shot. Change to Manual and choose same f-stop and shutter speed the camera chose for you in the other modes. Compare all three photos. They should be almost if not exactly the same exposure wise.
In Tv mode choose a dlowers shutter speed, In Manual choose a combo of slower shuuter and wider f-stop(smaller number). Read your manual.
Jan 02, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
I'm using a Canon EOS Rebel X S 35mm SLR What setting should i set my camera for a manual shutter speed?
If your camera is a Rebel XS you should have a dial on the top right with a series of letters and icons. To set your camera so you manually control the shutter speed turn this dial too "TV" (Time Value). This setting will allow you to select the shutter speed and the aperture will open or close to achieve the correct exposure. The "M" is (Manual) where you would select both the shutter speed and aperture "AV" is (Aperture Value) where the user selects the aperture they want and the shutter speed increases or decreases to obtain a proper exposure. The "P" (Program) mode allows the camera to automatically select the shutter speed and aperture
Dec 06, 2010 | Canon EOS Rebel XS 35mm SLR Camera
X-370S 35mm SLR Camera: what is the best aperture, shutter speed and iso f...
Your camera light meter should tell you, but in case it doesn't work then all you need to remember is the "Sunny 16 Rule". Basically, on a bright day and with the lens aperture set to f16 you set the reciprocal of the film speed.
So with ISO 100 film the reciprocal is 1/100, or 1/100th of a second. Your camera shutter speed dial doesn't have that, but it does have 1/125th which is close enough.
Once you have the exposure set for f16 then if you adjust the aperture you simply adjust the shutter speed to match. So if you decide to set f11 that allows twice as much light onto the film so to compensate you reset the shutter speed to 1/250th of a second to halve the light coming in. As twice the light coming in through the aperture is compensated for by halving the light coming in via the shutter, the exposure remains the same.
Although this works for a sunny day, you just guess based on experience other lighting conditions. So if it's bright but overcast then you can leave things as they are, but if it's dull and overcast allow one extra stop of exposure by opening the aperture by one setting or by doubling the time that the shutter remains open. So from the starting point of f16 at 1/125 (as above), on a dull cloudy day you'd either set f11 OR 1/60. If you set f11 AND 1/60 then you'll be allowing not just twice as much light in but three times as much.
Hope this helps, if so please take a moment to rate my answer. If it's too complicated then please add a comment and I'll re-explain in even simpler terms.
May 18, 2010 | Minolta X-370S 35mm SLR Camera
How to KNOW the light is right 4 an Olympus OM20 Manual camera?
OM-20 was basically a upgraded OM-10 with the manual adapter built in and a number of other refinements.
The viewfinder has LED's to show the shutter speed recommended by the camera's lightmeter for the ISO and aperture selected. It also has an exposure compensation indicator (the +/- symbol) and an indicator for flash ready which doubles up as a post-exposure flash confirmation. There is also the indicator lamp to show manual mode has been selected. OM-10 lacks the manual mode lamp and the +/- indicator.
Like the OM-10, the OM-20 is primarily an aperture priority automatic camera. In this mode you set the ISO film speed, choose which aperture you wish to use (with the ability to use the lens depth of field preview button) and then the camera selects the correct shutter speed. The +/- exposure compensation control allows the user to tell the camera to modify the recommended shutter speed by up to two stops either way.
In manual mode, there is no manual metering. The light meter behaves exactly as it does in aperture priority mode and the viewfinder shows the recommended shutter speed and not the manually selected one. Correct metering is therefore a case of adjusting the aperture first, and then choosing the correct shutter speed indicated in the viewfinder. If the user then decides to select a different shutter speed, then the aperture ring must be adjusted to maintain the correct exposure. For example the aperture is set to f8 and the camera recommends 1/60th of a second. The user decides that a faster shutter speed is required and chooses 1/250th, but the viewfinder remains showing 1/60th. In order to keep the same exposure value the user must open the aperture by two full stops to f4. The camera's light meter will detect the new aperture setting and providing the light on the object is unchanged the viewfinder shutter speed display should now show 1/250th as well to confirm the correct adjustment. Alternatively, the user can choose the shutter speed first by looking at what has been set on the control ring (or by turning the ring to the end of its travel and then counting the clicks from there as all experienced OM users do) and then turning the aperture ring until the shutter speed shown in the viewfinder matches what's been manually set.
It all sounds clumsy and complex but is done far more quickly than I've taken to type this and becomes second nature.
Aperture priority metering is selected on the camera by choosing AUTO on the mode selecter. In this mode the shutter speed ring has no effect and the viewfinder always displays the automatically selected shutter speed.
May 09, 2009 | Olympus OM-2000 35mm SLR Camera
Shutter speed won't go above 200
I have two possible solutions:
First, are you shooting with the flash up or an external flash connected to it? If so, the camera likely needs to synchronize at 1/200 or slower otherwise it won't be able to take a full photo. As a safety feature to prevent that, many new cameras just restrict the ability to pick a faster shutter speed.
Second, if its not related to the flash, it might be related to the mode you are using. Turn the camera off the automatic modes and put it on an all manual setting. Change the ISO to 400 or so, got outside and aim up at the day's sky, put it on manual mode and then adjust the shutter speed. Open up the aperture on your lens all the way (turn it to the smallest number). Now adjust the shutter speeds. It should be able to go past 200 now.
Nov 25, 2008 | Canon EOS Rebel G 35mm SLR Camera
F-stop issues
See pages 36&37 of the manual.
If you haven't got one, you can download it here.
In M mode...
Turn the selector dial to adjust shutter speed.
Hold down the AV+/- button (top-right of rear screen) and turn selector dial to adjust aperture setting.
As for Av mode, this is perfectly normal that you cannot set the shutter speed. Av mode means that you decide on the aperture setting and the camera (not you!) decides on the correct shutter speed.
Hope this helps,
Matt.
Mar 21, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Shutter speed and aperture
You can change the settings when you are not using the smiley face setting. Turn camera on press menu go to sensitivity to change film speed, EV compensation to allow more or less light.
Nov 29, 2007 | Pentax Optio S50 Digital Camera
Aperture Priority Mode - an undocumented feature
In addition to the "quirks" of the Landscape and Aperture Priority Modes (neither mode works as documented!)..... The camera also behaves differently in full Manual Mode (it changes the settings, whether you want it to or not to compensate for available light)... At lower Zoom Levels, the camera will adjust the Shutter Speed Only, to try and compensate for available light... For example: with the Camera preset to F5.6 Aperture, and 1/48 sec. shutter speed, the camera will adjust the shutter speed between a range of 1/30 to 1/291 sec, to try and "auto expose" the shot for lower or higher light levels, even though you're in manual mode. At an Aperture Setting of 2.8 and 1/48 of a second, the number of internal steps in shutter speed the camera is willing to take, increases dramatially - for example: shutter speeds up to 1/600 of a second, even though you have the shutter set to 1/48 in manual mode. The camera WILL NOT attempt to adjust the Aperture to compensate for proper exposure in available light (OR WILL IT??).... It depends on your Zoom settings! It won't if your're near to full wide angle, but IT WILL if you are using the Zoom. Once you cross some unknown zoom threshold (it doesn't have to be at full zoom), then the camera begins to change both the Aperture and Shutter speed to compensate for available light, even though you are in "Full Manual", versus Auto Exposure Mode. In Manual Mode, (as in Aperture Priority Mode), the amount of change the camera is willing to make to your settings, appears to be related to a preset number of internal steps, with the number of steps dependent on both Aperture and Zoom Settings, before it gives an EV Warning for Over or Under Exposure conditions.... The type (shutter speed only for wide angle, shutter and aperture for zoom) and amount (number of internal "steps" it takes to increase/decrease shutter speed and increase or decrease aperture), is dependent on the amount of zoom you are using for the current shot.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Nikon D3000 Digital Camera Logo
47 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
