Question about Compaq Presario CQ62-215DX Laptop
Compaq Presario CQ62-215DX has a white screen
When I turn on the laptop it has a complete white screen. I can manuever the lcd screen sometimes and the video comes back and at times flickers. any ideas on what is the problem?
    New Friend:
  • 3 Answers
Need to check the connection of the LCD to the motherboard.
http://h10032.www1.hp.com/ctg/Manual/c02641795.pdf
Start on page 70 and follow exact instructions
Posted on Dec 08, 2012
  • 1 more comment
  • Paul Davis Dec 09, 2012
    I checked the connection and it seems to be ok. if I have the laptop screen opened all the way it works to a degree. if you start to close it the screen goes crazy and goes white completely. If I press on the left side of the keyboard it can fix the issue temp or if i push on the back of the lcd it fixes it temporaily
  • jaspersabe
    jaspersabe Dec 09, 2012
    It really smells like either a connection issue. If it was an issue with an IC, then it wouldn't respond to the physical tests. Have you taken the notebook apart as described in that manual I gave you link to?
    yea i agree and I did, actually got it to work just fine HOWEVER the blasted ZIF connector for the keyboard part came lose which I cant get back on or find anything to put enough pressure to hold the cable. any suggestions on that as I have looked everyone on line and have yet to find an answer on getting that ribbon cable to stay
SOURCE: Compaq Presario F500 Monitor Problem
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01480071&dlc=en
This might fix your problem. There is a problem sith the bios on select F500 models. Yours might fall in that category.
Posted on Sep 10, 2008
  • 12 Answers
SOURCE: Compaq presario 700 series cm2130 LCD Screen
I have the same model of laptop; and not had a problem swapping with other X-series screens taken from Compaq/HP and IBM laptops. (My laptop is a bit 'incident' prone, and is +70% by weight replacement parts.)
As for assembly/disassembly and a (very) partial replacement part list, HP publishes the Service Manual(pdf) online.
Also, if you have a model with an aluminum heat sink take this opportunity to remove the sliver solder attaching the aluminum/magnesium heatspreader, and silver paste-- (someone in QC failed highschool chemistry, remember the galvanic series ?). A hard eraser will remove the worst of the rust, use an odd bit of pottery if you need a mirror finish. I then reccomend using a good latex-ceramic paste, your laptop will then avoid the spontaneous shutdown issue.
Posted on Jan 12, 2009
leecom72
  • 4806 Answers
SOURCE: compaq presario laptop screen flickering
Hi there.
It sounds like you may have a loose inverter cable or the ribbon cable behind the screen is loose.
Is the machine in warranty? I
Posted on May 29, 2009
  • 11 Answers
SOURCE: I have a compaq presario cq50 215-nr. the lcd
I am sorry to tell you that the screen has been damaged and will need to be replaced. There is no work around/solution for a bad screen. Replacement is the only way to go. Sorry.
Posted on Sep 07, 2009
  • 1087 Answers
SOURCE: Compaq presario c700 laptop- unable to turn on laptop
U may have a dead board. They average $285 plus labor. A shop should be able to test it on a volt meter see if the power grid is burnt for around $35. then u will know what ur in for. If its a bad board just replace the laptop I wouldnt repair that problem on an older laptop.
Posted on Jun 24, 2010
White Screen Compaq Presario CQ60
Regarding ; White screen , I flipped my notebook over and removed the power source(s) , power cord and battery. I then removed the three screws in the battery cavity and the two outside corner screws to gain access to the connection for the LCD and found a loose connection. It seems that the wire that connects to the screen was being moved every time I opened and closed my computer. So very glad to find that bulb and inverter board was not bad. Prior to this , I did try external monitor and found that all was okay as far as operation of start-up.
Aug 20, 2012 | Compaq Presario CQ60-220US PC Laptop
Laptop screen blank all white
Either your LCD Video Cable is not plugged in snuggly or the monitor is slowly going bad. The fact that you can see the images on an external monitors says your Video Graphics Card is working fine. You'll need to disassemble the laptop to get to the cables. Get a quote from your local computer shops, then try the guys at: http://www.generalsystemsconsulting.com Most times they will fix it and ship it back by Fedex or UPS cheaper than any quote you obtained including the shipping.
Mar 15, 2012 | Compaq Presario CQ56-115DX Laptop
Compaq presario 2200 white vertical screen line
its ur lcd screen problem mainly comes when ur screen get some external shock to screen mainly its not repairable need to replace the screen other way is a risky one by resolding the screen main board which is behind the lcd screen (dont try urself ) nd its not a big problem as ur screen work properly
Jun 29, 2010 | Compaq Presario 1200 Notebook
Screen gets blurred and comes back after applying pressure on LCD
from your description, it appeas to be an issue with the LCD since applying pressure has effect on it. I would advise to check with compaq for warranty repairs if you still have one active. The LCD may have to be replaced for this situation. You can try to use an external monitor to check if the video controller actually works properly
Oct 25, 2009 | Compaq Presario Notebook
Laptop screen turns white
You can put your laptop on top of a icepack, cause your Graphics card is probably getting to hot. Thats why your screen turns white(probably only when gaming).
It is likely one of your fans is broken
Feb 24, 2009 | Compaq Presario X6000 Notebook
Compaq presario 1700 LCD issues
i have the exact same problem. try connecting the laptop to an external VGA screen. if it works, then the problem is most likely a loose cable (connector). It turns out that the connector (which connects the motherboard or gfx card to the LCD screen) on my laptop is torn and cut. see if u have the same problem. this link might help u check out ur problem:
http://www.laptopparts101.com/lcd-screen-video-cable/
Nov 21, 2008 | Compaq Presario 1700 Notebook
Compaq laptop screen not working
compaq presario c304nrharddisk is not detecting
Jul 04, 2008 | HP Compaq Presario C304NR Notebook
Compaq Presario CQ62-215DX Laptop Logo
544 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
