Question about Trendware TRENDnet TEW-432BRP 54Mbps Wireless G Firewall Rou Router (TN-432BRP)
Manual Setup of Trendnet Router
What is the website for setting up a Trendnet Router?
  • Anonymous Apr 02, 2009
    dgbfgfgbfbfgbfgbfgb
  • eecom May 11, 2010
    http://trendnet.com/downloads/
    ..find your model number in the dropdown - select version number on the next page. Is that what you were looking for?
  • 4 Answers
1. Open Internet Explorer 5.0 or above Internet browser.
2. Enter IP address http://192.168.10.1 (the factory-default IP address setting) to
the URL web address location.
3. When the following dialog box appears, enter the user name and password to
login to the main configuration window, the default username and password is “admin”.
Posted on Mar 17, 2009
Why my router trendnet tew-731BR doesn't working?
You have to look on the tag at the base or back and find the IP address and admin / password sign in to set it up. Set of numbers like 192.168.0.1 or www.routerlogin.net then when on the routers server you can enter your ISP details to get the router setup.
Dec 05, 2014 | Trendnet TEW-731BR 300 Mbps Wireless-N...
How do I set up a secure password?
For trendnet
Your Trendnet wireless router lets you broadcast your home network across your entire house, so you can access the Internet in any room. This signal may be powerful enough to extend into neighbors' houses, where they could easily jump on the network if it is unsecured. To protect your network, set up Wireless Encryption Protocol, or WEP, to encrypt data and prevent access unless the user enters the correct password.
Type "http://192.168.0.1" in your Internet browser's address bar and press "Enter." Enter "admin" for the username and leave the password field blank. Click "Log In" to log into your Trendnet wireless router's administrative program. Click "Wireless" from the left pane of the "Basic" tab. Click "WEP" under the "Wireless Security Mode" section at the bottom of the screen. Enter your preferred password for the network. A strong password is made up of a random selection of numbers and letters. Click "Save Settings" at the top of the screen to save your WEP settings.
trendnet wireless router users guide
http://downloads.trendnet.com/tew-611brp/manual/ug_tew-611brp.pdf
Mar 26, 2013 | Trendware TEW-452BRP Wireless Router...
Can my trendnet wireless router be reset with security without the cd rom
Typically, the router will have a reset button somewhere on it. usually you need a pen point or a paper clip end to fit it. Hold the reset button in for about 20-30 seconds and it should reset your router. You will have to set up new settings from there. For more information check TrendNet's website. I'm sure they have more info on there.
Good Luck.
May 11, 2011 | Computers & Internet
Can't connect apple iphone or sony vaio laptop to trendnet tew-652brp wireless router
Have you run the "Wireless Networking Setup Wizard", to configure the router, and to set an SSID, an encryption-level, and to set a password? If not, do it, and then use those settings on your iPhone & on your laptop.
Sep 18, 2010 | Trendware TEW-652BRP Router
Wish to setup hp k550dtn printer with ethernet support to a wireless trendnet router..432BRP. Two laptops will share this printer
You can use a print server to connect your printer to your computers over the ethernet/wifi connection, All printers will be using a network printer..
OR..
You can Attach the printer onto 1 of your computers, set the properties to share the printer, and then set up a new printer on the other computers (network printer)
Make sure all the computers on your home network are on the same WORKGROUP
Jul 17, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
How I can reset the password? I do not remember it
You must remove all power from router, and press the reset button, this will return the unit to factory spec's then you can login, as default, and re-setup the router.
downloads.trendnet.ru/TEW-231BRP/Manual/QIG_TEW-231BRP_EN.pdf
http://www.trendnet.com/downloads/list_subcategory.asp?SUBTYPE_ID=869&SUBMIT=Go
All in these manuals above..
Apr 09, 2010 | Trendware TEW-231BRP Wireless Router...
Trendnet set up on my computer
-> Connect your Modem or Internet to the WAN port
-> Connect your computer to anyone of the LAN port
-> Check if you have internet
If not, You should be knowing what kind of Internet you have DSL/Cable
Check if YOu have a WAN IP. WAN IP should not be 0.0.0.0
http://192.168.0.1->Advanced setup-> System ->Status
xtjdeeblsvxsw4felwm6vryrdkruutd3bv9ylzur8ud+atfl9kwj992js4mrf2e4nktvap1qwkdy2svrtzxjy3g5vedqnwhg8bl3khhwclf9hbkld8fc7fjsw21zebaj4nff+s6a6bxuis4qsmahyc4suq69ujyv+8p8hc8qa+qfhffnqg2apvq72tgrqp4bmu7yiohsankn5fudyat1c8i6b4aj+gebdb8qa+qfeuguibfpjf8qaaud6o4sufb6p4ajdi8f8ddsvnsj0mvlmaaaaasuvork5cyii=
If it is 0.0.0.0
-> For DSL you have to configure it in PPPoE
-> For Cable you have to configure it in Dynamic IP and click MAC clone
Feb 28, 2010 | Trendware TRENDnet TW100 S4W1CA...
How to reset the security key of my trendnet tew-430apb 54mbps wireless access point?
To change your router wireless security
  • Support site here http://www.trendnet.com/products/proddetail.asp?prod=150_TEW-430APB&cat=83
  • User guide here http://www.trendnet.com/asp/download_manager/inc_downloading.asp?iFile=10853
  • Quick setup here http://www.trendnet.com/asp/download_manager/inc_downloading.asp?iFile=10856
Connect your PC to the router with a cable to one of the LAN connections - Now you need to Log into the setup of the router - to do that open a web browser, use Internet explorer (some routers setup pages do not work correctly with other browsers) In the browser address bar - Enter IP address http://192.168.1.100 to the address location. When there is a screen needs to enter the User name and Password, both of the default Username and Password is “admin”
Now you can goto the wireless section or secruity section and set the type of encyption to WEP, WPA, WPA-PSK etc and then make up your own password. See Page 12 of the User Manual
On the PC Double click on the wireless connection in the system tray (bottom right hand side of screen) and then connect manually to your wireless signal - you will be asked for the password you set in the router.
Now you are connected.
You may need to remove any old wireless profiles you have on the PC/Laptops
Wireless Profiles - Vista/Windows 7: http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm http://www.tp-link.com/support/showfaq.asp?id=214 - delete the wireless profiles Start> control Panel> classic view> network and sharing center> manage wireless networks Delete the profiles you will then have to enter the wireless security key for any networks you connect to --
Wireless Profiles - XP http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm http://www.tp-link.com/support/showfaq.asp?id=186 - delete the preferred networks start> control panel> network connections> right click on the wireless connection listed wireless networks tab in the preferred network list click on each one and - remove button
Feb 11, 2010 | Trendware TEW-430APB 802.11g/b (TEW430APB)...
How can I set up a speed stream 4100 modem/router to work with a trendnet tew-432brp. What are the wan settings on the trendnet, What are the settings on the speedstream. Thanks!
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. here are the steps u need to do:
1. press the reset button on the back of the trendnet router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the trendnet router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe. Im sure if the computer is connected to the speed stream 4100 modem router you can have an internet access. just in case u did a pppoe settings on the trendnet router and ur done setting the router, u did the connection, then u dont have an internet, set the speedstream modem router to bridge mode
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
if you have any querry pls feel free to get in touch.. good luck
Aug 30, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Open Questions:
See all Trendware TRENDnet TEW-432BRP 54Mbps Wireless G Questions
Trendware TRENDnet TEW-432BRP 54Mbps Wireless G Firewall Rou Router (TN-432BRP) Logo
5,661 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
Brian Sullivan
Brian Sullivan
alex metro
alex metro
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
