Question about Yamaha RX-V373 5.1 AV Home Theater Receiver Black
Trying to hook up my wii but have sound and no picture I have HDMI cable from tv to yamaha v373 amp and trying to connect the red white and yellow cables to back of amp
  • 25 Answers
Need to put yellow cable into monitor in and choose a input with video vcr, tv, or dvd. still no luck then yellow directly to tv.
Posted on Dec 10, 2012
  • 127 Answers
SOURCE: my wii won't play video through my Yamaha RX-V465.
This receiver doesn't support processing of video signal, only switching. This means that it can output only the same format of video. Only some more expensive models do upscaling from component/composite to HDMI out.
From HDMI out, you can output only signal that came via HDMI in 1-3. For component out, you can output only component in. The same for composite.
So in order to use wii through receiver to TV, you must connect receiver and TV also via the component cables.
Or other option is to connect component from wii directly to TV and connect only audio to receiver.
Posted on Aug 13, 2010
SOURCE: no picture from wii
The RX-V800 switches the various video signal types separately.
Since you are feeding S-Video to the TV the composite (yellow) input from your Wii is not going anywhere.
If you cant get S-Video output from the Wii then I'd suggest a simple Composite to S-video adaptor plug ($5 say). It worked for me with a Game Cube.
Cheers
BJ
Posted on Apr 27, 2009
easyq
  • 144 Answers
SOURCE: Intermittant disruption of Picture and Sound on View TV/HDMI only
If i am not mistaken you can select the HDMI signal going out on the 663, this means you should select to have only pictures to go out as sound will have to be reproduced by the 663.
So HDMI output setup on the 663 should indicate image only, no sound.
Posted on Apr 17, 2009
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
quang123
  • 107 Answers
SOURCE: problem hooking up my Yamaha RX-V461 to my PS3
When you connect the optical cable to the ps3 you must change the output to optical on the ps3. To do this, startup your ps3 then go to settings then audio output settings and change it to Digital Out (Optical).
Posted on Dec 01, 2008
Please tell me how to hook up my Wii and my cd player and my dvd player to Pioneer VSX-D309 receiver
Greetings and good health to you.
Ok, so on the back of the unit there should be labeled connections, AUX, DVD, etc. These will be your inputs.
If your Wii has RCA connectors (the plug like ends that are usually Red, White & Yellow) then you would connect the Red plug to the AUX right speaker input. The White plug to the AUX left speaker input. If you want to run the video through the unit to the TV, then you would plug the Yellow plug to the AUX video input. If not, the yellow plug with go straight to the TV. If you are using HDMI from you Wii, then you would plug that into one of your HDMI inputs.
You will do the same for CD player but using the inputs labeled CD or whatever you have available. You can use any of these inputs for any of your devices it just helps to know what is connected where.
The DVD player may be a different story. Depending on what type of connection you are using from the DVD player will depend on where you plug it in. If they are red, white and yellow...then follow as above. If they are red & white on half the cable and blue, green and red on the other, you will plug the red & white ones that are close together into the red and white audio inputs under the DVD labeled connections. Then the other 3 will go into their matching colored inputs. If the connection from the DVD player is HDMI, that will go into a HDMI slot.
Finally, connect the unit to the TV. Keep in mind that if you are using any HDMI inputs, you will need to connect the unit to the TV via a HDMI cable.
Hope that helps.
Nov 05, 2015 | Pioneer VSX-D307 Receiver
No audio from my rx v373
hdmi cable does both vid and sound so you should be ok if you have used this way to connect. if you have used rca connection try using another red white yellow cable cause they are cheap and break easy.
Mar 29, 2014 | Yamaha RX-V373 5.1 Channel AV Receiver
I just bought a toshiba 50M2U 50' series TV. I also bought a audio/video switch to connect my bose 3,21, surround sound sytem which still uses the red, blue, green cables and I have a wii system w
i think your problem is with cabling your surround sound is audio only and you wii is video and audio. i would hook up wii first and get it working first. dont plug the surround into the yellow jack on your audio video switch
good luck
Sep 09, 2012 | Toshiba 50L2200U 50" 1080p LED-LCD TV -...
Trying to hook up a dvd and wii with direct tv and can"t get sound out of wii! HELP Can you show me where to plug cords in?
Your TV has two sets of AV inputs. One on the side and one at the back. The Wii has a 3RCA cable ( Yellow / Red & White ) . Connect these jacks to the corresponding color sockets on the side input of your TV. Select that input on the TV and your Wii sound and picture should come on.
For the DVD player you have to get a 5 RCA component cable. This cable will have 5 colored jacks, connect the White & Red to the Audio in of the TV and then connect the Red/Blue/Green jacks to the component video input of the TV.Do the same at the DVD's end also. Setect that source on the TV and you should hear the DVD sound and picture.bobhifi_31.jpg
Apr 03, 2011 | RCA L32HD41 LCD TV
How do I connect my Wii to my Yamaha RX-A700 receiver? I am running everything through my receiver....Is it just a matter of connecting color to color wires at rear of unit...ie AV5 input?
are you just trying to get the sound? Use a pair of audio in jacks like av5. (usually red and white inserts in jack and the color of the plug ends) if you have video switching and have hooked up a video out to your TV then you could also use a composite video connection (usually yellow insert in jack and yellow plug on wire) to send the picture to the TV. A higher signal source would be component (red,green & blue) or HDMI if your reciever has that level of signal swithing.(HDMI is audio and video in 1 cable)
Jan 20, 2011 | Yamaha RXV665BL Receiver
I,ve connected my wii to the led tv using a wiii component cable(5 leads) but have used only 3 of them red green & blue 1,s leaving a red & white 1 left i have good picture but no sound help please
your cable is split into two different connections for your tv... the red green and blue cables are for HD only. They are their own little set. the yellow cable is your video cable for normal tv's. the red and white cables are sound cables, also for normal tv's. I would unplug the red, green, and blue cables, and use the yellow, red (right sound), and white (left sound).
Dec 31, 2010 | Nintendo Wii Console
When I connect my Wii to my Yamaha HTR-6130 through the front V-Aux jacks, i hear sound but no image. It says " Listening to Dock" on the front display. Can you help?
On this receiver the tv must be connected to the Monitor RCA Composite (yellow) output in the rear when you use another Composite input. You can't connect the Wii with the Composite and expect to use the tv with the HDMI - this unit doesn't have an onboard converter.
Once you have connected it correctly just select as a source the front connectors.
Nov 28, 2010 | Audio Players & Recorders
I have a vizio HDMI DTV telvision, and a sony surround sound system, I am trying to hook my wii to this to watch movies, the problem is I have hooked the yellow cable from the wii to the surround sound, I...
If you're using the HDMI cable with 5 wires, the red, blue and green wires are for video and the red and white wires are for audio. If your TV has a component IN RCA jacks, they connect there. If you're using the 3 wire cable, yellow is for video, and the red and white is for audio. You will NOT get HDMI pictures with this setup so you will have to go into the input selections and choose composite video input on the TV menu. Get a connection diagram from Visio's website or look in your owners manual if you have one.
.Connect them to the corresponding inputs
Jul 28, 2017 | Philips HTS-3565 Theater System
I can't get the video to work on the wii using the red, white & yellow cables. Will component cables fix my problem?
Your post indicates the use of a receiver. If you are in fact using a receiver, make sure you have a "video out" connection from the receiver to your television. Then make sure you have the correct input selection on the receiver, and on the TV.
Dec 28, 2009 | Yamaha RX-V463 Receiver
How to hook up wii to surround sound
You need to connect your amplifier to your TV, (Video Out of Amp to video In of TV), then select the input where you connected your WII in amp.
Or you could just connect the yellow plug to the TV directly, and the white and red plug to your amplifier.
A note thou, Red and White will not give "True" surround sound as it has only 2 channels, you need to connect a digital input to the amp to get true surround.
Let me know what happens
Alex
www.CAS411.com
Mar 15, 2009 | 2006 Chevrolet Uplander
Yamaha RX-V373 5.1 AV Home Theater Receiver Black Logo
1,129 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
