Question about Interface Chevrolet Impala 2000 00 Onstar Radio Replace Interface
2000 impala drains battery when sits has new battery and alt. is charging.
Battery drains
Battery wont start the car ,ill charge the battery its ok for a few hours then its dead ,alt charging good ,battery is new,every fuse in both pannels are hot with key off please help
The battery dies after sitting for a few hours ? Parasitic drain on the battery ! With the key off all fuse's shouldn't be hot ! Bad ignition switch . Find a wiring diagram at www.bbbind.com an check power at ignition switch . Look on you tube , a lot of videos on basic electrical trouble shooting .
Nov 13, 2015 | Cars & Trucks
Craftsman lawn tractor
charging system need to be check... alt. some of these tractors have the charging reg. inside alt some have one mounted outside follow wire the red one should be one big (thick) one and a thinner (smaller one) this small one is the charging circuit. if it goes from battery to alt. then regular is inside alt.
Oct 04, 2017 | Craftsman Garden
Battery draining while driving. New alt and battery stays charged in other vehicle
Possible cause due to a bad earth lead most common one to fail is on the gearbox, easy way to check this is by using a multimeter have the engine running and see what the charge is at battery should read upwards of 13.6volts for good charge. Then check and compare charge from battery live terminal and a good earth on the engine block . This is where it gets more involved if no difference in the charge rate. If its safe and accessible to get to the live feed to the alternator keep connection on live feed and other on block and take reading from there this should be good charge rate then check from alt to battery if still good rate of charge you have a problem with the live side
Aug 14, 2013 | 2000 Ford Taurus
2000 impala 3800engine when sits battery drains
If the battery goes dead in a few days, something is "on" and draining it.
Someone will need to check the circuits to find the drain. You can pull all of the fuses or check each circuit one at a time with a test light.
Dec 08, 2012 | Chevrolet Impala Cars & Trucks
2005 toyota tundra new battery and altinator both been tested and battery still dies after trk runs for 10 min. any ideas?
sounds like the alt. is not the problem.does the battery drain while the truck is sitting or running?
Jun 12, 2012 | Toyota Tundra Cars & Trucks
The battery isn't charging some thing keeps killing the battery. The alt seems to be working but the battery want hold a charge for very long.
Have the battery load tested to determine it's ability to take & hold a charge. It could have a bad cell that will drain the good cells. Your local auto parts will test the battery free of charge.
I hope this helps.
Aug 26, 2011 | 2000 Nissan Frontier
Battery drains quickly
the starter could be draining it
Feb 27, 2009 | 1999 Dodge Intrepid
Battery being drained on 2000 Expedition
you should remove your alternator and take it into an auto parts store and they can test it for you.
this alt had an internal regulator which can be replaced easy.
your auto parts store will be able to full feld your alt to bypass the regulator. this is how you test it to see if the regulator is bad.
you didnt say how many miles are on this truck .
most of these ford alt will last 120,000 or more
on the back side of the alt you will see the replaceable regulator.
Nov 17, 2008 | 2000 Ford Expedition
Interface Chevrolet Impala 2000 00 Onstar Radio Replace Interface Logo
19 people viewed this question
Top Interface Car Audio & Video Experts
xxxxxx xxx
Ted Maxwell
Are you an Interface Car Audio and Video Expert? Answer questions, earn points and help others
