Question about Samsung DMT400RHS Builtin Dishwasher
Dishwasher fills then drains sets code for over- level water error, what to look at first
2 Suggested Answers
SOURCE: My Samsung DMR57 Dishwasher gives me error code
Our unit started displaying code 9E after filling, draining and filling again. At the beginning it was enough just to restart it. Finally this trick didn't work anymore. Before calling service for out of warranty I decided to take the unit out of the cabinet and start it. Of course this didn't fixed the problem. Then i noticed where the water comes in and I took off the panel on the left side bottom. 366571e.jpg
Under the panel there is a white box that has a floater inside. The floater is pushing a lever that actuates a micro switch. I noticed that the lever wasn't moving as the machine started to fill in with water. The lever was stuck. An easy touch on the lever fixed the problem and the machine started working. 677e4ea.jpg
I will put back the washer for now but if it happens again in the next future i'll have to find a more permanent fix.
Posted on Sep 21, 2010
Why is my countertop dishwasher stuck in drain mode(s), and won't initiate or complete any wash cycle?
normally if a dishwasher fills then pauses it is trying to read the water level if it fills again it is trying get a reading from the pressure switch when it cant determine the water level it will drain to prevent it leaking, however you should get a error code for this kind of fault which makes me think it is the control board which is at fault by not being able to read the sensor rather than the sensor itself not working
Oct 08, 2014 | Dishwashers
LDS5811BB LG dishwasher IE code. What does this mean?
WATER INLET ERROR Water has not reached to the pre-set level within 8 min. since inlet valve operated, or water has not reached to the normal level within 25 min. stop cock turned off, faulty inlet valve.
Sep 19, 2014 | LG Dishwashers
What are the common fixes for OE Error Code?
OE error code is an Outlet Error.
That has to do with the drain itself. It can come up when the unit is draining slowly, it has nothing to do with water-level really. I would suggest makign sure that your drain hose is not crimped / crushed / or obstructed first before going onto other problems.
May 02, 2014 | Samsung DMR77LHS Tall Tub Dishwasher
E3 water drainng error
Some drain problems come from the washer drain hose not being high enough to allow for the water to fill in the dishwasher. Make sure the hose is held as high as the washer top as possible before it drains into the sink drain pipe. A good example is your cloths wash machine the drain hose comes from the bottom of the machine then it goes up to the drain that is higher than the basket. This keeps the water level high enough to wash clothes. The dishwasher works the same way. The drain hose must be slightly higher or as high as the needed level in the machine to work. In most cases as high as the dishwasher top or close to it. Simple raise the drain hose.
Jan 20, 2014 | Samsung DMB28AFS Dishwasher
Miele dishwasher model G858 water will not circulate and the intake / drain code flashing? Does anyone know what needs to be replaced?
when you start a cycle, your machine should drain for 30 sec, fill with water, and then the circulation pump should come on. your water level should be up to the handle on the filter in the bottom. if you drain, and fill to the handle and then the intake drain error comes on, your circulation pump is stuck. if it does not fill to the handle, you may have a problem with the inlet valve.
Jun 02, 2012 | Miele 24 in. G858SCVi Plus Built-In...
P/No 3850DD 3006E MODEL LDF 681OST 23 7/8 X 33 7/8 609KW2HOO957 69LD 12 10 These are all the numbers on my dishwasher, approx 3-4 yrs old. suddenly started making a noise and stopped washing after...
1. Make certain the water supply valve is turned on. Check the inlet hose for any kinks or bends in the line that could prevent unit from filling properly. Check drain hose for proper installation. If water drains immediately, unit will display an IE Error Code.
2. Check the water supply valve and make certain that it is turned on and open fully or this code will display.
3. Check the inlet valve filter for buildup of mineral deposits. If the inlet valve filter is clogged it will restrict water flow is restricted into the dishwasher, resulting the IE Error. Clean filter with small brush to remove any accumulated mineral deposits that may have accumulated.
4. If inlet hose is kinked, water flow into the dishwasher, is restricted resulting the IE Error. Straighten any bends or kinks in the inlet hose. If the drain hose is not installed properly and the water drains out of unit, this could cause premature draining, which results in IE Error Code. In this case it will be necessary to reinstall the drain hose according the instructions in the installation guide.
5. If the water pressure is not 20 - 120 psi, water will not fill properly. This will result in IError Code. If water pressure is too low, it may be necessary to call for service.
6. During winter, parts of the dishwasher that are installed outside may freeze. Melt the frozen part by soaking a towel in warm water and wrapping it around the part. This should allow the dishwasher to operate.
7. If the unit is not leveled properly, the IE Error may occur. Use a level to check the sides and top of the unit. If the unit is not level, adjust the leveling feet in the front and back. Use the leveling kit packaged with the dishwasher. Check mounting brackets. If one is tightened more than the other, it will offset the cabinet.
* Note: To adjust leveling legs on the front, use a 1/4" square drive wrench. Turn clockwise as needed to adjust level. To adjust rear legs, use a standard Phillips head screw driver. On the left side rear, turn the screw counterclockwise to lower the leg and raise the rear. To adjust right side rear, turn the adjusting screw clockwise to lower the leg and raise the rear of dishwasher. Using a level while adjusting the legs will help aid in proper leveling.
Feb 14, 2011 | LG Dishwashers
E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Apr 28, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Hobart lx30 E3 error
Error Code E3 relates to a problem with the fill. Specifically that the water level has not been recognized at the middle water sensor. This can be caused by a problem with the drain system as you describe, or by low water pressure to the machine (should be 15-25psi flow), or bad wire connection to this middle sensor.
Check for proper water pressure first (should be a gauge on the machine) during the fill. Then check / repair drain as needed. These will probably eliminate the problem
Jun 19, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Samsung DMT400RHS Builtin Dishwasher Logo
261 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
