Question about Canon CanoScan 3000F Flatbed Scanner
Need 64-bit driver for canoscan 3000f to work with windows 7
I have a new windows 7 hard drive which is 64-bit, however my old canoscan 3000f only runs on 32-bit, so is there a driver available to run the scanner
MarcusVR
SOURCE: CanoScan N1220U Scanner Windows 7 64-bit Driver
You may use Hamrick VueScan Pro, it installs a driver that makes 1220 to work. Or, if the version of Windows 7 you use support XP Mode, install it.
It's still a good scanner, and mine is working in 7 x64 using XP Mode!
Posted on Jan 16, 2010
SOURCE: canoscan 5000F scanner driver needed 64-bit
You can find solution in vincenzomazzotta.blogspot.com or traslated by google traslate service in english in http://translate.google.it/translate?hl=it&sl=auto&tl=en&u=www.vincenzomazzotta.blogspot.com
Posted on Jan 04, 2011
SOURCE: Canon Canoscan D1259U2F dont have any driver for Windows 7 64-bit
the only successful method I found for using CanoScan D1250U2F in 64 bit Windows 7 (I guess the same would be for 64 bit Vista) is to use Windows XP Mode in Virtual PC (attach the scanner as USB device and that's it - works perfectly)
I had a problem with Windows 7 detecting the device as CanoScan (needed for Windows XP Mode to detect is as USB device and allow attach) - the solution was to unplug the scanner, plug it in and CANCEL Windows 7 hardware detection process before it finishes - this leaves it as "CanoScan" device (auto-detect will leave it as "Unrecognized device" and with that unusable/un-attachable in Windows XP Mode)
latest versions of Windows XP Mode will make your hard drives accessible as network locations (no need for external media)
Posted on Mar 14, 2010
technical114
  • 1851 Answers
SOURCE: I've an old Canon Canoscan
There are no available drivers for windows 7 operating system for your scanner. You can download the official windows xp drivers from this link and before run the downloaded file right click on the file and at the compatibility section check the windows xp sp3 compatibility option and hit apply - ok. After this run the file as usual. This procedure will install the drivers is windows xp sp3 compatibility mode.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on May 02, 2011
  • 58 Answers
SOURCE: I need to install a
You need also to install a 64bit drivers. It will not work if you will just install a 32bit. You can contact the system manufacturer to give details how to get a 64bit download.
Posted on Jun 02, 2011
XPS-410 needs to have MCE 2005 Rollup two SP3 replaced by Windows 7 64 bit. Too many problems to list currently but will work limited programs
Not sure what you are trying to do. If you are trying to convert 32 bit to 64 bit Apps, try going to manufacturers website to look for drivers.
Win 7 will actually find the best drivers for your devices.
May 06, 2014 | Dell XPS 410 PC Desktop
Is my Iomega hard drive compatible with Windows 7
Yes window 7 is the problem there is no updated driver for it to work, go to www.Iomega.com contact customer support and the technical department to see if they can offer a updated driver.
May 04, 2012 | Iomega Computers & Internet
Driver Canoscan N670U for windows 7 64-bit
Free option to use CanoScan N670U wth Windows 7 64 bit
VueScanner cost$ --> I am running Windows 7 64bit and was able to use my CanoScan N670U by Installing Windows XP Mode in Windows 7 at no additional cost
http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
After install the software loaded and the only trick was to click the "USB" dropdown in the virtual machine menu at the top of the screen and select canoscan
Jan 16, 2012 | Canon CanoScan N670U Flatbed Scanner
I need to install a driver for Windows Vista 64 bit for my Canoscan 3000f scanner. Canon does not have support for 64 bit drivers on their website.
Jun 02, 2011 | Canon CanoScan 3000F Flatbed Scanner
Neew canon 3000f driver for windows 7 64 bit
I'm afraid there are no drivers under W7 for this unit .
You could , if you have the W XP install disc , install a virtual version of W XP on your HDD .
You could also partition your HDD and install W XP on the new one .
Otherwise , you 'll need to buy a new scanner that runs under Windows Seven .
Regards .
Dec 27, 2010 | Canon CanoScan 3000F Flatbed Scanner
Where can I find Driver for my Canon ( CanoScan 3000 / 3000F) for Windows 7 ??
Canon has a driver for Vista 32-bit here: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=8741#DownloadDetailAct . This might work in Win7 32-bit (possibly you will need the compatibility mode - right click on the driver and choose properties and the Compatibility tab.).
However, Canon has no 64-bit Vista support and no Win7 drivers and no plans to update the drivers for Win7. You can try a generic scanner driver from the OS - chose a TWAIN driver.
I wish that I could be more help.
Jun 11, 2010 | Canon CanoScan 3000F Flatbed Scanner
No driver for Canoscan FB 630U Vista 64 bit
Unfortunately, it doesn't look like Canon supports this scanner under Vista. Check if the Windows generic TWAIN scanner driver will work. The Canon software won't work. If the generic driver can be installed, then you should be able to acquire scans in Paint (File > Import from Scanner or Camera), Windows Fax and Scan (New Scan) (some versions of Vista) or Windows Photo Gallery (IIRC it works like Paint).
I hope this helps.
(Canon wants you to upgrade. I have a different scanner that isn't officially supported past XP and the generic driver works fine. Unfortunately, you can't just use the XP driver in the compatibility mode due to the lack of signed drivers that are required in the 64-bit OS)
Jun 03, 2010 | Canon CanoScan FB630U Flatbed Scanner
Jan 01, 2010 | Canon CanoScan D1250U2F Flatbed Scanner
Sep 17, 2009 | Canon CanoScan N1220U Flatbed Scanner
Canon CanoScan 3000F Flatbed Scanner Logo
880 people viewed this question
old marine
old marine
