Question about Haier 14.3 lb. Washer/Dryer Combo
Haier dryer shuts off after 14 minutes and has an error #13
    New Friend:
  • 35 Answers
It means there is no water. Check the hoses are not kinked and the screens on either end are cleaned of debris.
Otherwise these more internal parts are the possible causes:
1. Inspect the pressure tube from the tub to the pressure sensor looking for kinks or leaks.
2. Inspect the electrical connections from pressure sensor to the Control PCB
If you need a new pressure switch p/n: WD-7100-65 you can get it online at: www.encompassparts under 10.00 dollars
Posted on Oct 15, 2013
2 Suggested Answers
  • 22 Answers
SOURCE: My HWD1000 Haier Washer/Dryer combo error EC4
EC4 is regarding: The temperature of air vent.
Within 30 minutes of dry cycle there is 5 minutes in which the temperature is not increasing.
The dryer heater is not working properly. Call a repair technician.
Alternatively, create a custom wash cycle with no dry cycle and hang dry the laundry if you are past warranty and do not want to pay to repair it.
Posted on Aug 14, 2010
Dryer LG 1100 shuts off after a few minutes. If you set it for 54 minutes, you check if after 5 minutes it reads 14 minthen in 5 minutes it starts cooling down. The clothes are still wet.
Clean your lint filter, and clean the entire line vent from the dryer to the outside export port, also look inside the dryer vent hook up for obstructions and remove any lint. Keeping these parts lint free will save you energy and also drying time and maintenance repairs. My dryer is 18 years old.
Sep 29, 2015 | LG Dryers
My Wascomat TD77 dryer keeps shutting down after 5 minutes and shows E 14. What is wrong with it.
Taken from the following: https://www.wascomat.net/pdfs/487032981.pdf
This is for a different model, but the codes are likely the same.
It is related to non-ignition of gas. You may need to switch on your gas supply, or service your ignition coil.
Resetting gas error
When the ignition control fails to detect a flame a error code E14 is displayed. When this condition occurs, the gas valve is shut off and the ignition control must be reset manually.
Resetting
Open the operating panel and press the gas reset button on the back of the user module board for one second.
See the picture of the gas reset button section 21
NOTE! When resetting the system the dryer must operate on a program with heat and when the heat indicator is on.
Error code
Error code 14 is a normal occurrence when first starting up a dryer, since air in the gas line must be purged.
Aug 26, 2014 | Dryers
Dryer shuts off within a few seconds and smell burning
That's a sign your motor is bad. Soon it won't start at all.
Mar 13, 2014 | Maytag MEDC300XW - 29", 7.0 Cu Ft, He...
I have a haier hwd 1600 that is giving a error code 13 what does that mean and can i reset the machine or do i have to call a service tech
I service this machine before. There is no service manual for any Haier products.
You might want to change these parts out in the unit: Main PCB board, Heater Element, Thermostat and the Condenser.
Mar 25, 2013 | Haier HWD1600 13-Pound Combo Washer Dryer
E12 eror on Haier washer dryier
Error 12 means Drainage error, water not emptied within 4 minutes
Solution:
Clean the fi lter and check the drain hose for blockage. If error still exists, please contact the Haier maintenance personnel.
Thanks and have a nice day.
Jul 03, 2011 | Haier XQG50-11 Front Load Washer / Dryer
Jun 11, 2009 | Haier HWD1000
Haier HWD1000 washer/drye
please repost for i have no knowledge of the haier productline
Jan 31, 2009 | Haier HWD1000
Haier 14.3 lb. Washer/Dryer Combo Logo
244 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
