Question about Refrigerators
I have an older McClary domed door refrigerator and I am looking for a pair of the freezer doors. The model number is R91-50 and I cannot find any information on it. Help please.
Looking for freezer doors
dididsaythat
  • 291 Answers
SOURCE: Refrigerator Compartment Fan
Sounds like they ran it in with your themostate and it is not working.. i would try replaceing themostate
Posted on Oct 14, 2007
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore Frig-bottom freezer/freezer door pops open
Replace a door gasket on a refrigerator....
Replace a door gasket on a refrigerator: The first thing to do when changing a door gasket is to check and see if you have the proper part before taking the old gasket off. Hold the new gasket up to the fridge door to make sure the gasket is the same size as the old one. Next step is to remove the wrinkles in the gasket caused by folding for shipping. Instructions with the gaskets say to soak the gasket in hot water. Another way is to use a hair dryer to heat the gasket and remove the wrinkles. Be careful not to burn the gasket with the hair dryer. Almost all gaskets in use today are magnetic. I am placing instructions here for the most common one. They have strips of magnetized material inside the gasket material to adhere to the cabinet when the door is closed. Therefore there is sometimes no up or down on the gasket. Some fridge's have magnets on only 3 sides and the side without a magnet is the hinge side gasket. But to be safe, check this before installing. You will certainly want to check for this on older refrigerators that have magnetic door latches. Some of these have no magnets on the latch side of the gasket. There are about three different ways of attaching gaskets. All will be addressed on this page. Remove the food from the shelves on the door. Loosen the screws that hold the metal strips that keep gasket in place on the top half of the door. Back the screws out about 1/4 inch. The gasket has a lip on it that seats in a groove under the top part of the metal strip. Pull the old gasket off. Work the groove on back side of the new gasket under the cutout in the metal strips that holds it on the door liner. Straighten and get good install before tightening screws. Run screws back up against the metal holding strip snugly, not fully tight. Go to the bottom and do the bottom half. By doing the top half first and tightening, then doing the bottom half, you will minimize any warping of the door. If there is warping of the door, we have not yet fully tightened the screws. so you can realign the door easily and then tighten the screws. Check the alignment of the door and be sure the gasket is sealing properly before fully tightening the screws. If the door is warped, (see picture) simply warp it back to a sealing position, then tighten the screws. There are instances where the gasket is too tight on the hinge side, and you may have to shim the door hinges out from the cabinet to keep the gasket from scrubbing when closing. .also use a little petroleum jelly on the gasket on the hinge side will allow the gasket to "settle" better. The hinge side must slide along the cabinet edge while the other 3 sides just close up against the cabinet. The jelly will allow the gasket to rub smoothly and also prevent squeaking noises. Maintenance of the gasket is important also. It should be cleaned on a regular basis. Clean the gasket and the mating cabinet surface with warm soapy water, rinse clean and dry it good. Putting a little baby powder on the sides (except the hinge side because we put the jelly there) will prevent the gasket from sticking and tearing. The heaters in the refrigerator used to keep moisture from forming on the cabinet attracts airborne materials and make the gasket sealing surfaces sticky. The powder will help stop this. Probably 75% of the fridge's made a few years ago use this edge under the metal track....some American made fridge's use the U shaped metal strip and the gasket pushes into the metal strip, (see a picture) the screws that hold this metal strip do not have to be removed or loosened. A lot of fridge's also use the metal strips with out the edge. Some Maytag's and Woods come to mind. The screws go through the metal strip and the gasket as well. The screws have to be removed completely to replace the gasket.
Gasket sheet to assist you in replacing a common door gasket.
Freezer door pops open when I shut the fresh food door:
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
I hope this helps, and if you need more information On solutions just let me know, Thanks Sea Breeze
Posted on Feb 06, 2009
  • 63 Answers
SOURCE: is there a kenmore refrigerator recall?
The 800 number is available at:
www.techimo.com/forum/imo-community/145834-lg-electronics-sears-roebuck-recall-refrigerators.html
Posted on May 30, 2009
  • 34 Answers
SOURCE: My freezer door will not stay shut. Dometic Model RM2453.
yes you can.remove two screws from under one side pull it away slightly and it will come away.you will then have one housing on both sides left in the fridge wall,they will have a little pressure on them from the springs. just prise them away. you will need help to replace them, as you need pressure against the spring to keep the door closed. you can buy springs and housings seperately from camec there is left and right housings.give me a call if you need to ..
Posted on Jan 03, 2010
SOURCE: Express Thaw comes on when refrigerator door is closed
We have a GE Profile side-by-side refrigerator which we purchased in 2002, Model PSS25NGNACC. Today we had a repairman come to investigate why the Express Thaw 3lb. light was on and could not be shut off. If shut off, it came on again when the door was closed and reopened. The repairman called GE and learned that this light was an air filter change indicator which turns on at some interval (2 years, they said, although we don't remember ever seeing this before). The air filter involved is for the interior of the fridge and is not critical. GE said that newer master control boards have this function disabled, since people rarely changed the filter and GE no longer makes them. I have read our user manual cover to cover and find nothing on this filter. I guess we just have to pay the $70 dollars to have someone come and call GE to figure it out. But, enough of that. To reset the indicator, simultaneously press the following keys on the touchpad and hold for 5 seconds until it beeps:
Adjust Freezer Temp (Warmer)
Express Thaw
Adjust Refrigerator Temp (Colder)
Lights and functions should return to normal.
Posted on Mar 10, 2010
Where is the model number on a McClary fridge?
Hallo
There are 4 different places no matter which brand fridge it is it will always be one of these 4 but I'll put them in order from most fortunate to least fortunate location.(I'm sorry I don't know where McClary's product info tag is located but surely it will be one of these 4 places)
1) On the inside Left or Right wall of either the refrigerator or freezer.
2) Behind a lower crisper draw.
3) Behind the kick plate.
4) On the cabinet door jamb.
The tag should look something like in the photo I posted for you.
Regards.
Jun 10, 2016 | Refrigerators
ER CF error code on fridge
Sarah can you look in the refrigerator door or around the fresh food section door for a model number that looks like 106.78900 I need that number to be able to tell you what the error code is. Appliance 911 Sea Breeze
Nov 26, 2015 | Kenmore Elite 78722 78729 Bottom Freezer...
How do i remove the freezer door?
one trick I used when moving furniture and this happened was to open the freezer door right back and put the freezer door through the opening first , then the rest of the fridge went through by angling it past the door frame
that saved trying to reset the door when it was through
other than that most doors are hinged from the top first so if you remove the finish plugs there will be screws that you can undo then lift the door of the bottom pivot
Nov 25, 2015 | Refrigerators
Door between freezer and refrigerator will not open
Good Afternoon Friend,
I understand that the door between the freezer and refrigerator on your Frigidaire refrigerator, model# FRS26ZSG, will not open. I will be more than happy to assist you. The model number you have provided pulls up a side by side refrigerator, which only has two doors. So I am able to better assist, please provide me the model number to your refrigerator and elaborate more on which door will not open. Looking forward to hearing from you.
-WP-
Jul 04, 2014 | Frigidaire FRS26ZSG
Freezer fan is noisey and can t find serial number
The number you will need is the model number. On side by side models there are a few places to look. 1- inside fridge on right or left wall. 2- Open fridge door and look up near the top front lip. 3- Open both doors and look on body of fridge under the doors. 4- Fridge door sometimes there is a sticker right when you open. Mostly you are looking for a silver sticker or silver plate. It gives you a model number and serial number. If you need further assistance please mail me back.
May 26, 2011 | Kenmore Side by Side Refrigerator
I have a GE Profile "Artica" side-by-side refrigerator model PSC23MGNA - BB. Recently the refrigerator door has begun swinging all the way open ... 180 degrees ... and banging into the...
if you look down at the bottom of the freezer door you'll see a door stop,two 5/16 inch screws hold it in place,the stop on the fridge door must of broke.you can switch it from the freezer to the fridge door for now until you get a new one.part number is WR02X13425 and it's around 5 dollars.give your parts store the model number and they will take care of you,or go here,pick any topic here,put your model number in,to the right of the model it will as model or part number,pick model and click on it and your machine will come up,click on fresh food door,your part is numer 12 and you can order it from sears if you want.let me know how you make out
Feb 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My friend has a side by side refrigerator. The freezer side works great but the refrigerator side doesn't keep anything very cold. Any suggestions? She doesn't know what brand it is. It has an H on it and...
evaporator is frozen up or fan is not running in freezer to fix you may have to replace heating element or defrost timer or fan motor or defrost terminator
Sep 26, 2010 | Refrigerators
Freezer won't stay shut
If you want a part number for the replacement door gasket please provide a complete model number here so I can give that to you or you can look it up yourself at www.searsdirect.com You must have your model number. (sample 110.XXXXX etc)
The magnet is inside the door seal itself. If the seal is damaged replacement is your only option.
Thanks for using FixYa!
Kelly
Feb 18, 2010 | Refrigerators
We have an Amana side by side. The freezer door
hi. First of all, finding the model number can be a bit of a challenge. here are the places to look:
  • Inside the refrigerator or freezer, on the upper left or right side wall
  • Behind the lower crisper drawer
  • Behind the lower toe kick-plate
  • On the face frame of the refrigerator body
  • Nov 17, 2009 | Refrigerators
    ISO refrigerator door handle
    Your original repairman must have looked up a similar model without the snack door. The handle of couse would have also been listed, but this is difficult since A. You do not give your model number and B. (maybe not as bad) we don't know what model number he used when he ordered your door(s). Please list the complete model number of your refrig. (from sticker inside fresh food compartment) and I'll try to help.
    Aug 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    Refrigerators Logo
    37 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
