Question about Craftsman Garden
Where is the diode located on the craftsman mower. The one that is parallel with the clutch.
  • Craftsman Master
  • 2,239 Answers
The diode is in the loom close to the clutch wiring block, it bridges the live and earth wire.
Posted on Dec 08, 2012
fredcause
  • 51 Answers
SOURCE: My Craftsman G5000 mower chokes off when I release the clutch
bad ropes safety switch under the seat.
Posted on Dec 08, 2008
  • 6 Answers
SOURCE: Mower shuts off when clutch is disengaged.
Check your seat adjustment to make sure you're applying constant pressure to the safety switch under the seat.
Posted on Apr 22, 2009
  • 57 Answers
SOURCE: craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
Posted on May 18, 2009
  • 138 Answers
SOURCE: Craftsman riging mower will not charge. Son hooked
if it is a briggs engine it is in the wiring harness coming off the alternator, where it plugs into the main harness coming out of the dash area. it will appear as a lump in the wire [sometimes there will be two diodes]. if it is a kohler, it will be in the wiring harness under the shroud covereing the flywheel
Posted on Sep 01, 2009
Testimonial: "Thanks for the help. It saved me much needed $$$"
  • 299 Answers
SOURCE: Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
Posted on Sep 30, 2009
Need to locate the safety switch on a craftsman dlt 2000 lawn mower
witch switch do you need the one near the brake/clutch pedal the one on the seat the one on the the one on the trans for mower deck reverse cut out?
Jul 13, 2012 | Craftsman Garden
NO power to pto craftsman gt 5000
could be a clutch switch look at sears parts online for the location
Apr 01, 2012 | Garden
FS5500, electric clutch spins when engaged breaking wires
Not sure of exact clutch retaining method in this model but most clutches are located in position by a pin or a plate bolted or welded under the chassis. Have a close look as the locater has probably broken off. Regards Phil
Apr 17, 2011 | Craftsman Garden
The mower runs fine till you engage the blades then it goes dead
Hi and welcome to FixYa, I am Kelly. Take a look at the pedal switch wiring. Also check the foot switch to make sure it is NOT grounding when you ease the pedal to it's normal resting position. This is the most common problem however..... Underneath in the clutch area make sure that the clutch wires are not grounded. There is a diode in the PTO clutch and if the diode fails it will present this symptom. Read the Black to Purple stripe wire on the clutch in BOTH directions. One way it should read open the other way it should read like a wire. Most of the time it the blade is engaging and the mower dies it is either the foot switch or a wire in the PTO Clutch area that is grounded.
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Sep 30, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman riging mower will not charge. Son hooked cables up wrong and most likely blew the diode. Where is the diode located?
Sep 01, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
136 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
