Question about Inland ProHT Bluetooth Headset Red
Headlight blue light is flashing and won't do anything else
    New Friend:
If you hold down the power button (and keep holding!) while wearing the headphones, you will hear three beeps (keep holding! If you lift your finger, you have wait a moment to start over) followed after a moment by two beeps. If you do this while the headset is NOT on, it will enter the "discoverable" mode and the lights should flash red/blue red/blue. If you do this while the headset is on, the second set of beeps sounds a little different, and those tones mean the headset is turning off.
The "manual" (a single sheet of paper) for this device is a joke, and website technical support is nonexistent.
When I first purchased mine, despite the poor instructions, I was satisfied, due to the low price. But I've only had the device for less than a month, and I've only used it three times, and suddenly I can't get it to pair with my laptop or my phone, though it had worked find a couple of weeks ago, last time I used it.
Sometimes you get what you pay for, I guess. Disappointing.
Posted on Jan 03, 2013
My indesit washing machine 12 hundred keeps flashing blue and red lights and won't do anything
Possible that the suspect could be the controller board, you can switch the machine off power for sometime, check the power outlet for the correct voltage. If not the front panel must be removed to check on the board and a possible fault of the processor or memory.
Feb 03, 2013 | Washing Machines
Pioneer vsx 915 blue light flashing
Time for a repair shop to look, clearly the amp is down, it has failed. Have a qualified tech look at and get a repair estimate.
Dec 15, 2012 | Pioneer VSX-915 Receiver
The dimmer switch on my 1999 firebird won't change the headlights from dim to bright, or vice versa. It has a good click to it and the blue light in the dash comes on when they're supposed to
That is a common problem, the switch needs changing if the high and low beams do work, the only problem is that it's an expensive part to replace, try a local wrecking yard they should have a bunch of suitable replacements at a reduced price.
Sep 19, 2012 | Pontiac Cars & Trucks
Left headlight
If the other head light works ,it won't be a fuse
Check every fuse in the car,won't take long &
the fuses will protect a complete circuit,not just
a couple head lights.
The light switch has a circuit breaker not a fuse.
Have you removed & tested the lamp it'self
No owners manual? Need that for fuses & bulbs/lamps
Sep 04, 2012 | 2001 Hyundai Sonata
Dim headlights on 1999 grand marquis
Bulbs -usually burn out, all at once,haven't you had that happen
Blue Bulbs- are illegal in most states & you asked about the most
light. Won't get that from some aftermarket fancy color gimick
So Dim Lights--that is a problem obviously
You will have to have that diagnosed,I won't guess
at it. Only visual inspection & testing will establish why their dim
May 18, 2012 | 1999 Mercury Grand Marquis
Headlights won't go on
Sounds like a loose connection or a bad ground wire
May 05, 2012 | 2005 Chevrolet Aveo
Headlight do not work on 2005 crysler town &country
Sounds like you may have a bad multifunction switch. I can help you figure this out but you will need a test light or voltmeter and a couple of jumper wires. You will also need to be able to remove the steering column cover to gain access to the switches electrical connectors.
If the above is possible let me know and I'll be happy to help.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Feb 03, 2012 | 2005 Chrysler Town & Country
Inland ProHT Bluetooth Headset Red Logo
537 people viewed this question
Top Inland Radio Communications Experts
eradiostore
eradiostore
Are you an Inland Radio Communication Expert? Answer questions, earn points and help others
