Question about Cisco linksys E3000 Wireless-n Router
How can i connect to my linksys router
I tried to re-install my router, however i couldnt connect to my router for setting
    New Friend:
The best bet for setting up wireless routers is connecting to them with a wire until all your settings are correct.
Make sure your Router is set to use DHCP and you should be able to get to the routers homepage....(192.168.1.1 or 192.168.0.1)
Posted on Dec 08, 2012
Wrt120bn wireless router cd installation
Are you trying to setup Linksys router?
You can run the installation CD to setup Linksys router or you can do it without installation CD also.
Connect the computer to the router with the Ethernet cable.
Open the setup page of the router.
Change the Internet connection settings.
Create a new wireless network.
Connect to the network.
I will suggest you a website that you can try to setup your Linksys wireless router without installation CD.
May 21, 2012 | Linksys Wireless-G WRT54G Router
Im from d Philippines, im currently seting up my Linksys wireless-G WRT54G Router, after entering the password it says "Setting up router" then the next message would be "checking internet connections" and...
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jul 20, 2010 | Linksys Wireless-G WRT54G Router
Have a Wierless-G router can not install, tried 3 times. While installing it has very limited range , pc is 4-5 feet away & couldnt pick it up. Any ideas ???
check the wireless settings of the router. try to change the channel of the wireless network.
SSID broadcast should be enabld on the router. It depends on the computer also.
If your router is old then upgrade the firmware of the router. firmware is the software of your router.
Click here for more information about the router
Mar 27, 2010 | Linksys Wireless-G Broadband Router
Wireless will not connect to internet after installing XP Service Pack 3. Router is a Linksys WRT54G2, adapter is a Linksys WMP11. Router is set to "mixed".
Try upgrading the firmware for your routher and the linksys WMP11. Also try setting router to 802.11g instead of mixed to see if it connects.
Sep 29, 2009 | Linksys Instant Wireless WMP11 802.11b
Cant connect to linksys
try goin in to the settings for the router it self. ip addres 192.168.0.1 make sure you got the right security key.
Jun 28, 2009 | Linksys Wireless-G WRT54G Router
My WRT54G linksys was connected 3 days ago to the laptop and the ps3. two days ago, i couldnt connect to the internet on the ps3, but could on the laptop. Yesterday, i couldn't connect on either one. I've...
First steps (forgive me if you are already doing this). Hook up the laptop with cat5 network cable to port on router to verify you have internet connectvity. Verify router settings that DHCP is on or off. It should be on unless u are using static IP's on network. Go back wireless and see if you can connect. IF yo do, open a DOS prompt and use ping command (c:>ping 192.168.x.x ) where x.x are the ip setting of router. In most cases the router IP will be set to 192.168.1.1 Check the most basic settings. Sometimes it is a simple thing that is throwing everything off. Also consider if your laptop is at the very edge of your signal area. Try moving laptop right next to router.
Hope this helps.
Jun 09, 2009 | Linksys Wireless-G WRT54G Router
When I try to connect my router to my laptop, the 321 error screen appears after about a minute. It says my ethernet cable is not plugged in properly, but it definitely is. Even the connection lights on...
This is a well documented problem with linksys routers. Go to google and type in "error 321 linksys". You will have to manually configure the router as stated on the linksys forum posts.
Jun 05, 2009 | Linksys WRT54G2 Wireless Router
Limited connectivity
You have to turned on DHCP in your router settings. i think its under the General TAB if its a linksys router
Feb 03, 2009 | Linksys Wireless-G Broadband Router
I tried setting up my network key but I couldnt find the WEP Key setting button so i went to reset key and eventually I lost my connection.... I couldnt even find now my connection. SO I take my router and...
http://www.columbia.edu/acis/networks/aptnet/linksys/index.html.This will explain in detail.with illustrations so you see exactly what is on screen during set-up.i suggest you uninstall all old drivers and go to linksys for currant ones.RICHARDM69
Dec 06, 2008 | Linksys Wireless-G WRT54G Router
My router is locked
Go to the computer that the router is connected to and access the settings. (192.168.1.1) Go to a link where you can restoer the factory settings. Do it and shut down everything. Power everything on in this order. (Wait 1 minute between them)
1. modem
2. router
3.computer
4. other network devices
Then try to connect all of the devices to the network. Then set the router to your personal settings.
Apr 29, 2008 | Linksys Wireless-G Broadband Router
Cisco linksys E3000 Wireless-n Router Logo
50 people viewed this question
Top Cisco Video Game Consoles & Games Experts
James Wishart
Are you a Cisco Video Game Console and Game Expert? Answer questions, earn points and help others
