Question about Kenmore Elite Sears & Other Brands Replacement Gas Grill Stainless Steel H-Burner
I have a sears kenmore elite slide in range model number 790.46613500 that has a f13 err can anyone help with this
  • Kenmore Master
  • 5,160 Answers
Unfortunately, the F13 error indicates that the oven control has failed. First unplug your range and wait 30 seconds or more to reset the code.
If the error recurs, this part will need to be replaced. See http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Range-Parts/Model-79046613500/0583/0124160/R0507023/00001?blt=06&prst=0&shdMod=79046613500 for the parts list.
I'm not exactly sure if your unit needs part 97 or 97A.
I hope this helps.
Posted on Dec 08, 2012
SOURCE: Kenmore Elite Range/Oven problem.
My kenmore glass top stainless steel slide in range has an error message code F93. I was attempting to allow my range to self clean when this err message appeared. Now I can't get the door unlocked. Help?? We've had a lot of problems with this range. We've had the service tech come out probably 4-5 times for different things. I think I got a lemon. It just turn a year old-we extended the warranty . I've called to complain but I got no help. They said it had to be for the same problem each time. Even the tech said the oven was a lemon but he couldn't help us. Any suggestions?
Posted on Jun 09, 2008
jyackle5
  • 8197 Answers
SOURCE: F90 Err on Kenmore Elite
the F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board. It is unlikely that you will be able to reset this fault code. You can try to completely disconnect electrical power and leave it off for 5 minutes. After reconnecting power, the fault code will probably reappear since the control will still detect that the oven door is locked. The only way to clear the fault code is to disassemble the range and repair or reset the oven door lock assembly. You will need a service technician to complete this repair.
Good Luck
Posted on Dec 30, 2008
SOURCE: kenmore elite slide in range model 790-4101
how do you take the top off this LG LRG30357ST i cant get a tool small enough to fit the back right burrned orifes to convert it to lpg
Posted on Aug 28, 2009
jsrock516
  • 5911 Answers
SOURCE: I have a Kenmore Elite electric range smoothtop
Yes, you can repair the appliance yourself and save on the cost of labor and services charges. Unfortunately, when these triple burners go bad in the manner you describe, there is no way to repair only the portion that is burned out. The burner is one complete piece and needs to be replaced as an entire assembly. The following link explains how:
http://www.fixya.com/support/r3692628-surface_burner_replacement_electric
Replacements parts can be purchased from any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need. I suspect your model number is actually 790.96593601 or 790.96593602. These are the only two numbers that cross to the model number you provided. If I'm not correct, please post back with your COMPLETE model number.
The part number for the triple burner is 316216702. Keep in mind, this part, alone is not cheap. The cheapest price I found was about $120 at appliancepartspros.com. However, you would spend much more if you included the added price of a service call and labor charges. Use the part number provided to search any other web sources you like to see if you can find the burner listed elsewhere for a better price. Use the part number as some websites may not list your particlar model, but will carry most parts.
If you have any questions please post back and let me know. I hope this helps you.
Posted on Apr 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore model# 790 94463700 serial# VF 735 37589
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 25, 2010
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
www.kenmore.com/kenmore-elite-30inch-slide...electric-range...
Kenmore
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
www.kenmore.com/kenmore-elite-30inch...slide...electric/p-02...
Kenmore
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
How do I get a manual for a Sears Kenmore Elite Slide in Range Model C970-445841 Serial # NF12810048?
Here is a list of the manuals available, the c970-#### are there at the end. C970I think is a model the numbers after are black, stainless, white, etc here is link
Manuals for slide in stoves
Jan 29, 2015 | Kenmore Kitchen Ranges
My Kenmore Elite model #790.4105 fan keeps running after we use the oven. It's our first use of the oven. Is that normal?
I would check in the owners manual under trouble shooting if you can't get an answer their call sears tech support
Aug 27, 2012 | Kenmore 30" Slide-In Electric Range 4102
When turning on oven it says f3 or f13 err and i can erase it
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Apr 06, 2009 | Electrolux Kenmore 30 in. Gas Freestanding...
My kenmore elite electric slide in range displayed error and F13 and the oven won't turn on
i phoned Sears about error code f13 on a gas range, and was told to unplug the range for 30 minutes. i think she meant 30 seconds - to reprogram the microchip. i unplugged it for 15 minutes or so, then reconnected, and it worked.
Jul 09, 2008 | Kitchen Ranges
My kenmore elite electric slide in range suddenly had the word error appear and the code f13. The oven won't go on, but the range top works
Need the model number (specifically the 1st 3 digits ) too determine who manufactured it for Sears then can tell what the fault code means for that brand. You might try shutting the breaker off 20-30 mins see if it resets itself.
Jan 29, 2008 | Kenmore 46123 Stainless Steel Electric...
Kenmore Elite Sears & Other Brands Replacement Gas Grill Stainless Steel H-Burner Logo
255 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
