Question about Cisco Valet Wireless Hotspot (M10)
I cannot connect my Cicsco Valet through Ubuntu 12.10 Please help
I have a sony Vaio Desktop 3.2 Ghz but cannot get the ubuntu to recognize it
How do I factory reset a Sony Vaio PCG-792L aptop with Ubuntu?
Download the version of Ubuntu you require, burn it to a disc. Start the Sony up, booting from the DVD drive and install a fresh OS.
Dec 29, 2015 | Sony Computers & Internet
How do i install a operating system on a sony old sony viao 600hep with no dos and no operating system and a broken cd rom drive. only have usb.
Check out this:
http://www.ubuntu.com/download/desktop/create-a-usb-stick-on-windows
This gives instructions on how to download, and create a ubuntu bootable USB stick.
http://www.ubuntu.com/download/desktop/try-ubuntu-before-you-install
This will give instructiosn on how to load and install from said USB.
You will need:
A working computer with Windows
A 2GB or larger USB stick
Internet connection
After you've made your USB stick, when booting up the computer you wish to install ubuntu on be sure you have the USB stick inserted when powering it on. When the start screen comes up press ESC to enter the BIOS or boot order. Select the USB stick from within the BIOS boot order menu, or the USB stick from the boot options menu.
Load ubuntu, install, enjoy.
Mar 13, 2015 | Sony Computers & Internet
Install linux drivers ubuntu
I assume your laptop is a Sony VAIO VGN-FW235J? If so : Mobile Intel 4500MHD Total Graphics Memory 1340MB Chipset Mobile Intel GM45 Express Chipset
Take a look here: https://docs.sony.com/release/SPECS/VGNFW235JH_mksp.pdf AND : http://esupport.sony.com/US/p/model-home.pl?mdl=VGNFW235J&template_id=1&region_id=1&tab=manuals#/manualsTab
Nov 28, 2013 | Sony VAIO VGN-FW235J/B PC Notebook
Can I add 1 gig of ram to an old Vaio PCV-RX280DS with Ubuntu Linux installed?
no, i'm sorry the maximum amount of ram the motherboard will recognize is 512 mb, it's not an OS limit it's a MOBO limit
Mar 15, 2012 | Sony VAIO PCV-RX280DS PC Desktop
I cannot get Ubuntu to load onto my Vaio PCV-RZ10. I have already partitioned the HDD with 30 Gig, loaded the OS (Ubuntu) I get a (Not Support) error message. Any ideas?
The problem is your computer is not compatable to run the Ubuntu operational system, it comes up not supported. But you can go online to forums that deal with these types of problems, because there are a lot of people out there that swear by this system.
Mar 10, 2012 | Sony VAIO Digital Studio PCV-RZ10 PC...
Hi, My sony Vaio VPCEA21FX, says that windows registry file is corrupt or missing. Thus am not able to login and it is not booting in to LKGC as well. I can restore to factory setting by but will lose...
try Ubuntu bootable disc or usb to boot from that. Ubuntu is a free operating system. you can use Ubuntu without actually installing it. you can run Ubuntu from a bootable disc or usb ......
such are called live CD or live usb.
running Ubuntu you can access the hard discpartition and hence your data and take backup os that in external media or another partition.
yoy can download Ubuntu freely. also you can order ubantu disc free of cost, even no delivery charges by post. just register and order Ubuntu from www.ubuntu.com
Apr 09, 2011 | Sony VAIO VPCEA21FX Notebook
Have a Sony Vaio PC VGC-RA837G when I turn it on I get the intel screen then the VAIO screen appears and it stops there. I have booted with the recovery disc and it enters recovery utility then gets to...
Sounds like you've got a problem with your hard drive.
An easy way to troubleshoot your system would be to (ON A WORKING COMPUTER)
Download and burn a copy of UBUNTU
Boot the non-working computer with the UBUNTU disc, check the top under PLACES to see if your hard drive and files appear.
If you need more help, let me know. There's a lot to cover.
Aug 07, 2010 | Sony VAIO V2M (VGCV2M) PC Desktop
Sony vaio ubuntu no sound problem
Hi try this, Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Go to start button, control panel, system, hardware and select device manager. Click the + for your sound device and see if there are any problems, if so it will be highlighted with a yellow? right click your audio and update your driver. Or go to Google and search for the latest driver to download. Also check your speeker settings under control panel.
Hope this helps
Jul 12, 2010 | Sony VAIO Notebook
Sony Vaio PCG-K23 LCD Monitor will work with Ubuntu or at c:prompt but the instant Windows loads it goes black. I've uninstalled, fdisked, reinstalled and so on what seems to be 100 times to no avail. I...
hook the laptop back up to the external monitor, once it boots and has settled, I would like you to hold down the Fn key which should be at the lower left of the keyboard and tap the F7 key. This will toggle the video output from external to internal or both at the same time. I have never heard of an issue where Ubuntu will allow a video signal, but now windows. I hope this works for you.
Oct 09, 2009 | Sony VAIO PCG-K23 Notebook
Wont boot up
Could be bad memory, try and get into the bios and turn off the quick boot feature, this will run more complete tests. Also try booting using KNoppix or Ubuntu, make sure u set to boot from a CD in the BIOS. If Ubuntu or knoppix boot's you'll know it's the Hard disk, if they don't, it may be the RAM,
May 08, 2008 | Sony VAIO PCV-W510G PC Desktop
Cisco Valet Wireless Hotspot (M10) Logo
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
