Question about Refrigerators
Leaks on floor - Refrigerators
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 09, 2012
  • Keith Bremner Dec 10, 2012
    Hi. WSE6100. Actually i fixed it yesty by disconnecting the water hose underneath and giving it a good blow. It was blocked.....its not now..too easy! Cheers keith
Water leaks out on to the floor.
Floor of the garage, or floor or floor of the car? Normally a broken heater core if inside as they are plastic and deteriorate. Outside of car can be hoses, water pump or a leak in the radiator.
Dec 05, 2016 | Cars & Trucks
After 7 to 10 days, all water leaks on floor.
Does it get heated? If so, Heat makes filter dry and it starts to leak.
Mar 24, 2016 | Humidifiers
2011 Explorer water leak driver floor
The only water leaks I know that appear inside a vehicle is normally from a bad heater core, but that normally leaks onto the floor of the passenger side. I would check your heater core regarding this problem.
Nov 18, 2015 | 2011 Ford Explorer
Brake pad dropped to the floor,brake fluid leaked out
catastrophic failure , DO NOT DRIVE
so find leak, see leak location, that is BAD.
MC (master cylinder)
or slaves (calipers or drum cylinders.
or hoses. (any)
pipes, (aka, hard lines)
junctions.
aBS?
why not post source of leak, or better photos.
or better yet, call a mech. for help .
floor, floor of cab, floor of garage, just a tiny hint on floor
and what 4 corners of car. inside or outside.
,fluid can leak down both sides of any MC
Dec 14, 2013 | 1999 Toyota RAV4
Water leak in floor
when you said water leak in floor do you mean the floor mat or the outside floor? if it is in the car check whether the radiator coolant level is getting low,or if it is not coolant see whether it is air conditioning drainer and the hose went off and the water gets on the carpet. If it is coolant check the matrix if is leaking.
Sep 06, 2012 | 1999 Ford Escort
2002 suburban has leak in driver side rear floor. Cannot see where water would be coming from?
We had same--water on driver side rear floor (soaked!). Driver side front floor seemed dry until feeling UNDER rug, was slightly damp. We found the location of TWO leaks causing this.
Leak #1 was through the parking brake line/cable seal; Recaulked with silicone. Removed plastic trim on floor between floor and door to reveal metal channel filled with water.
Leak #2 was where the door meets the car, near the hinge. It was the accordian-looking tube housing the wiring for the door. The big, rubber, circular plug connecting it to the main part of the car had come loose and water ran down through that, into the SAME metal channel filled with water from leak #1; will seal with silicone.
Note: We found that the channel filled extensively near the front door, BUT the carpet edge from the floor near the rear seat was dipping into it, wicking it up to the rear floor. Also, upon acceleration, the water in the channel gushed toward the back, thus soaking the rear carpet.
These leaks were found by removing all plastic trim (covering edges of carpet by doors), then one of us pouring water into specific areas of the exterior of the vehicle, and the other one watching closely with a flashlight for any signs of dripping.
Feb 18, 2010 | 2002 Chevrolet Suburban
2006 mustang water leaking rear floor
Hi , Its leaking water on the passenger rear floor? It could be the heater core leaking and running down the floor board to the rear of the vehical. Do you smell antifreez or see moisture build up on the windshield ? does the car seem more "humid" inside?
Jan 23, 2010 | 2000 Ford Mustang
Leaking
this is a huge problem for you. when you have a leak coming from the bottom of the dishwasher the machine will have to come out. but first check the door gasket to make sure the leak is not coming from there.
Oct 16, 2009 | Jenn-Air 24 in. JDB4950 Built-in...
Grohe shower assembly leaking
hiit sounds as though the diverter valve is sticking in the mid position although you have turned it to the floor spout as you call it!!
Also it sounds as though the seals are possibly leaking causing the plasterboard (drywall) to get we, or possibly a joint may be leaking. Advice access the pip-work valve etc run shower & check with torch (flashlight) to see where its coming from?
Rectification work replace seals/repair leak...replace diverter valve assembly.
Kindly
Richie (UK)
Dec 17, 2008 | Grohe Home
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
